Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2013
Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 02-07-2010, 02:33 AM   #26
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Stock sensor moved to bellmouth, vs PLX SM-AFR (Bosch LSU 4.2?) in bellmouth:
Old 02-07-2010, 11:02 AM   #27
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Originally Posted by gabedude View Post
I tuned a v8 twinscroll that had the stock 02 post turbo. It was a few years ago, so it would be interesting to compare my logs of my WB vs the stock one.
I was thinking the same thing. The JDM twinscroll setup puts the o2 sensor there I would assuem due to the isolation of exhaust gasses from the twinscroll headers.
Tony
Old 02-07-2010, 02:16 PM   #28
gabedude
Member#: 10108
07 STI
25G build in progress
Tony
I didn't notice anything different in the mapping as far as O/L C/L fueling goes. You might think that Subaru might have tried CL fueling into boost.
gabedude is offline   Reply With Quote
Old 02-07-2010, 08:46 PM   #29
NSFW
Member#: 140444
05 Stage Free LGT
They do that in 07 STIs don't they?
There's a CL enrichment table that seems like it ought to allow staying in closed loop at AFRs well below 14.7, has anyone messed with it yet? For my car it showed up in Merchgod's last set of definitions. (Others may have gotten it sooner, others might not have it.)
Old 02-07-2010, 09:00 PM   #30
69subaru360
Member#: 159682
1995 WRX
The stock sensor, moved to the downpipe is accurate. I tuned both of my 02 WRXs that way. I had an aftermarket wideband, it read comparably to the stock sensor moved post turbo. The aftermarket one broke, I never got another one, no need. On the 02 wrx at least, you can rescale it to read down to 10.5 to 1 if you want to.
Old 02-07-2010, 10:07 PM   #31
gabedude
Member#: 10108
07 STI
Just 3/4 of a second into high loads is all at 14.7:1.
I have that table. I would limit the AFL and AFC corrections first though. You don't want a big AFR swing at high loads.
Old 02-07-2010, 10:19 PM   #32
van_dutch
Member#: 198633
2004 WRX
I cut out your images
Couple questions. First, what is the equation for the regression you did on the data? What is the R value? How did you handle the x intercept? Ideally this would be zero. I don't know how the sensors will react in that area of the graph, but it will have an affect on the regression.
van_dutch is offline   Reply With Quote
Old 02-07-2010, 11:57 PM   #33
NSFW
Member#: 140444
05 Stage Free LGT
Beats me. I just logged both, made a scatter plot, and used Excel's polynomial fit thing. I played with the poly order until it looked about right. That's 4th-order.
Why do you ask?
Old 02-08-2010, 02:23 AM   #34
van_dutch
Member#: 198633
2004 WRX
Why do you ask?
I'm an engineer and when I see data plotted without that kind of stuff, it rings bells. Playing around until it looks right doesn't really cut it. I'm just curious about the comparison. Without stuff like the equation and the R (really R^2) value, a comparison like that is pretty useless. You can draw numerous shapes that look right. Without an R^2 value, you have no way of judging how well a given curve fits. The equation is telling for a comparison of how they line up.
Old 04-07-2010, 05:14 AM   #35
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
The comparison isn't useless, it's just statistically not sound. From eyeballing the graph (as an engineer, you still remember how to eyeball something? ), I would say the stock sensor tends to underreport the AFR by 0.2 to 0.6 units. This is pretty important of course in tuning, but I would think that after having seen that graph, you could just absorb a 0.4 unit offset in your tuning and get about the same level of precision in the tune as with using other sensors.
Frank A is offline   Reply With Quote
Old 04-07-2010, 11:54 AM   #36
arghx7
Member#: 232940
The problem here is that you assume the aftermarket wideband must be the "true" value simply because it's aftermarket and because it's advertised as being more accurate. You really need to use a completely different instrument (5 gas analyzer) that isn't subjected to the same limitations of the normal wideband design.
FYI I've since been tuning with the factory wideband relocated post turbo. Seems to work well enough, and I will acquiesce on the location issue. I do trust it more when it is post turbo.
arghx7 is offline   Reply With Quote
Old 02-28-2013, 10:26 AM   #37
arthurtoo
Member#: 268250
Hi there,
I have a JDM blob eye twinscroll. by default the a/f sensor is post turbo at the bellmouth of the downpipe. do i need to recalibrate the sensor voltage table before i use it to tune?
thanks buddy!
arthurtoo is offline   Reply With Quote
Front O2 sensor vs Rear O2 sensor (MY00 RS) Jewbaru Service & Maintenance 3 07-29-2012 10:14 PM
Front O2 Sensor, one NIB and the other used. 2 stock headers full. 2ndGearFling Engine/Power/Exhaust 3 10-27-2008 05:41 PM
FS: front O2 sensor, stock uppipe(7,000miles), stock front emblem jimtweet Private 'For Sale' Classifieds 7 03-14-2005 09:01 AM
does anyone need the stock front exhaust sensor off a... motorswapsleeper Legacy Forum 3 08-03-2003 09:36 PM
What type of sensor is the stock WRX O2 sensor? Patrick Olsen Factory 2.0L Turbo Powertrain 7 08-06-2002 05:17 PM
Message Board Statistics All times are GMT -4. The time now is 03:32 AM.
