Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 01-27-2010, 11:38 PM   #1
MiCaHSTi
Member#: 175721
06 STI
Default Need help from RMIC: boost issue
I recently bought a 04 fxt. When looking at the car it had a dp on it. The Kid i was meeting to buy from said he had purchased it like that. I knew i should find another but had been looking for ahwile and made the purchase.
On my way home i got a cel, i assumed it was the dp. I removed it and put my stock 06 sti on. The cel came back i used my AP V1 from the sti to read the code. It was p0011, did some research and removed the filters in the banjo bolts and the problem was solved.
The car also had a mbc ( turboxs ) that i also removed. I accidently removed the pill with it. Ran the car for about a week, boost was steady but low around a solid 7 lbs. I realized no pill found it and installed it only to overboost and fuel cut. I got the correct pill from subaru, had a slightly larger hole.
Now the current issue. wot 1st and second is fine, 75% of throttle everthing is fine all gears. If i go wot 3,4,5 it jerks for a sec then the boost jumps to about 13lbs than falls to about 10 lbs and kinda holds. Im guessing boost spike?
Is there anyway there could still be a map on the ecu from previous tuning im not aware of?
There is a staight pipe from mid pipe on
Thanks everyone for your input
MiCaHSTi is offline   Reply With Quote
Old 01-27-2010, 11:41 PM   #2
JON-E25WRX
Member#: 225389
03 WRX MBPwidebody
rotated 35R VOLTEX bugeye
hm... clueless here, but nice fozzy
JON-E25WRX is offline   Reply With Quote
Old 01-28-2010, 01:40 AM   #3
skatevolcom06
Member#: 199522
2004 Impreza STi
PsM
Well if the previous owner had the downpipe/exhaust on it you would hope he was running a correct map for those items. It could be that it is on a tune and the boost tables aren't right due to it previously running a MBC. I have no idea how to tune nor what goes along with it but flashing it back to a stock map wouldn't hurt to try.
Also nice fxt!
skatevolcom06 is offline   Reply With Quote
Old 01-28-2010, 09:51 AM   #4
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
When medamullett gets back in town I am sure he would be down to log it for you and see what is going on. Did you replace the mbc with an ebcs? If so those all need to be tuned for as each handles the boost and duty cycles differently. what all did the car have done to it and what all did you do to it?
06HAWKMAN is offline   Reply With Quote
Old 01-28-2010, 12:05 PM   #5
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
stock cars usually taper.
Did you buy that car from somebody in the Clearfield/ Roy area?
bhhamblin is offline   Reply With Quote
Old 01-28-2010, 06:33 PM   #6
MiCaHSTi
Member#: 175721
06 STI
I hooked it back to the stock ebc. And yes i bought it in the Clearfield/ Roy area, By any chance do you know what setup they had going on?
And thanks for the comments
Old 01-28-2010, 07:07 PM   #7
oxox55
Member#: 217423
02 wrx E85
psm
This is my old fxt, although I think it has changed hands a few times since I sold it. When I sold it it was running perfect. Who knows what has been done since then. p.m. me if you have any questions I might be able to answer
oxox55 is offline   Reply With Quote
Old 01-28-2010, 08:08 PM   #8
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
It's hard to diagnose the car without any logs, sounds like the wg duty tables may not be set up correctly, but again without logging it's hard to say whats going on.
PM me if you need some help logging/diagnosing.
907Bum is offline   Reply With Quote
Old 01-28-2010, 09:09 PM   #9
Indifferent
Member#: 186250
2004 FXT
i wish my fozzy was black, and definitely get a log soon.
Indifferent is offline   Reply With Quote
Need Help Pls: Possible boost issue on stock engine Kean Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 05-14-2010 12:43 PM
Boosted needs help from OT....again boosted06 Off-Topic 11 10-28-2009 10:23 PM
need help reading my boost controller can somebody help stiking87 Newbies & FAQs 3 06-11-2006 12:12 PM
I need help from anyone w/ the post recent issue of Cargo Magazine RacerinLSL Off-Topic 1 07-29-2005 10:05 PM
Help! Need help installing my Boost Controller Sagalyn New England Impreza Club Forum -- NESIC 8 07-10-2001 08:12 PM
