Old 01-28-2010, 01:38 PM   #1
Barnt
Member#: 161824
15 WRX. Pro-tuned
Way too blue...
Default New to tuning. will a dp force me to run stage2 with the Cobb AP??
A guy totaled his STi and wants to sell me one of the DP's he has for it. (has two, megan racing 3" and a Turbo XS 4")
If my car (05 wrx w/only SPT exhaust) now has a turboback, does that force me to go to stage 2. how will that effect my fuel economy?
can i still run a less aggressive map some of the time for better fuel mileage or does it not work like that....?
if its flexible then i'm going to go ahead and buy one of his downpipes
(not sure which is better but he only wants $75 for either of them)
285hp sounds nice when compared to stock!
i'm new to this; help me out please.
Barnt is offline   Reply With Quote
Old 01-28-2010, 02:05 PM   #2
rockle3
Member#: 167573
09 spec B
u get better fuel economy at stage 2
and u need a tune w. a dp
rockle3 is offline   Reply With Quote
Old 01-28-2010, 04:27 PM   #3
Barnt
Member#: 161824
15 WRX. Pro-tuned
Way too blue...
you get better fuel economy? wow i didn't know that. why is that?
and doesn't the AP take care of the tuning aspect with a dp?
Old 01-28-2010, 05:36 PM   #4
SilverWagonRX
Member#: 76159
2006 Acura TL 6spd
If you have an AP already. Go for it. Fuel economy is fine with mine. Can't exactly quote it as better, but certainly no worse. You will be very happy you did. COBB has a fuel economy map you can use at times if you really wanted as well.
SilverWagonRX is offline   Reply With Quote
Old 01-28-2010, 10:36 PM   #5
CEGLEX
Member#: 201976
2003 WRX Sedan PSM
Stage 2
The downpipe lets the exhaust gas flow more easily (in simple terms) so you increase power, and yes, you should use the Stage 2 map (that's the "tune" aspect to this). If you manage your right foot, your gas mileage is not going to drop like a rock. The risk is that you will notice more immediate power and response, so if you get addicted to the rush, you will hurt your fuel economy, but it's not the stage 2 map's fault ;-).
I can't speak to the Megan vs. TurboXS downpipes, but there are a bazillion threads you can read about on those (just search). Either way $75 is a deal. Heck, buy both of them, pick one, and sell the other for a profit.
CEGLEX is offline   Reply With Quote
Old 01-29-2010, 04:32 PM   #6
Barnt
Member#: 161824
15 WRX. Pro-tuned
Way too blue...
thanks!
and does it matter whether one's a 4inch vs a 3inch?? for any practical reasons such as volume?(sound)
he claims both taper down to 3" at the end....
Old 01-29-2010, 04:41 PM   #7
impreza914
Member#: 199499
2007 ford f150
subau coming soon
you have a 2.0 you wont see 285hp with just a turboback
impreza914 is offline   Reply With Quote
Old 01-30-2010, 03:51 PM   #8
Barnt
Member#: 161824
15 WRX. Pro-tuned
Way too blue...
just going by what cobb said...
Old 02-02-2010, 09:54 PM   #9
AeolusWRX
Member#: 120949
2011 Forester XT
Gray
I may be wrong on this, but I am pretty sure that you can use a DP without a tune. You will not be utilizing the full capabilities, but I do not believe it is harmful to your car. All it does it make the exhaust flow more freely.
AeolusWRX is offline   Reply With Quote
Old 02-05-2010, 03:02 PM   #10
Got Groceries?
Member#: 25323
2003 WRX Wagon
Not sure how the '05 wastegates respond, but 02-03 models could get some unwanted wastegate opening with a catless DP and no engine management.
Got Groceries? is offline   Reply With Quote
Old 02-09-2010, 02:21 AM   #11
Jayknux
Member#: 236450
09 WRX HB
Dark Grey Met
stay away from megan products....shoddy work/production at best...there is a reason why they are the CHEAPEST. a preset map from cobb or perrin will adjust your ecu good but a pro tune will; have your car dialed for there are many slight variations such as elevation, fuel type, air intake etc....a pro tune will further enhance the performance of your pre set tuning maps to get the most out of your turbo back exhaust
Jayknux is offline   Reply With Quote
Old 02-09-2010, 02:58 AM   #12
arghx7
Member#: 232940
fuel economy has everything to do with how you drive the car
arghx7 is offline   Reply With Quote
Old 02-10-2010, 01:10 PM   #13
TRturbo87
Member#: 200493
2004 U R A BUS
blackd out
Ive been running a full turbo-back with catted DP for 2 monthes, and didnt see any change in fuel economy. I ordered a cobb AP and am planning on going with a stage two map.
TRturbo87 is offline   Reply With Quote
Old 02-11-2010, 07:06 PM   #14
jasontee1
Member#: 111428
2006 wrx vf43 swap
wrb
with stage 2 i was getting 30mpg on the highway 25 in the city hwy mix
jasontee1 is offline   Reply With Quote
Old 02-12-2010, 02:18 PM   #15
crash60068
Member#: 209218
2005 WRB WRX 4EAT
93 MR2, 2008 Yaris
No but youll see that with a stage 2 tune with a AP you will
crash60068 is offline   Reply With Quote
Old 02-27-2010, 11:31 AM   #16
fb_stud_77
Member#: 236125
2004 WRX
It is not a good idea to run a dp without a tune. This does cause better flow which causes the car to take in more air which then leads to a leaner mixture. That then leads to higher EGT's and possible piston damage, especially with the close/open loop issues that 04-05's have.
fb_stud_77 is offline   Reply With Quote
Old 03-01-2010, 12:35 PM   #17
cgravat
Member#: 235360
2013 WRX Ltd. Sedan
PBP
Can you please provide factual evidence of this?
cgravat is offline   Reply With Quote
Old 03-01-2010, 01:13 PM   #18
crash60068
Member#: 209218
2005 WRB WRX 4EAT
93 MR2, 2008 Yaris
thats just what cobb says youll get its right here on there website. http://www.accessecu.com/accessport/...04WRXMaps.html
Old 03-01-2010, 01:51 PM   #19
cgravat
Member#: 235360
2013 WRX Ltd. Sedan
PBP
Sho-nuff does say that. Must be bhp, not whp...
This link shows the dyno results (Stage 2, See modification requirements)
http://cobbtuning.com/products/Default.asp?id=4505
DO I have to run stage 2 with the Cobb ap? Corpuz04 AccessPort 9 03-05-2010 12:41 PM
Does disconnecting the battery interfere with a Cobb AP tune? DJS_02_WRX Newbies & FAQs 12 11-05-2009 03:44 AM
Wife forces me to shop with her...but... Jack Off-Topic 45 12-01-2008 03:44 PM
The Science Channel is going to force me to drill a hole in my head chkltcow Off-Topic 7 04-30-2007 05:19 PM
Quietest Catback & Will Helix DP mate up to Cobb Catback? blindstuff Newbies & FAQs 21 05-25-2006 01:14 PM
