Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 05-24-2002, 04:32 PM   #1
listen
Member#: 16837
Default We have STI parts,what do you want?
We have just been given notice of STI parts being availiable through the dealership.
We can get the following parts,
Fog lamp covers mesh with STI logo.
Strut tower brace(rear). Polished aluminum construction
Radiator cap. Pretty Pink with STi logo. High pressure cap.
Radiator hoses (set). Silicone hose's. Pink with STi logo
Clutch disc (high performance 230 mm dia. 5 mm thick 1050kgf
Clutch disc mid level performance 230mm dia 8.0 mm thick 1050kgf
Timing belt More rigid than stock provides more precise valve timing.
Brake hose set. For two pot front and one pot rear (set) Braided Steel.
Flywheel lightweight Chrome molybdenum.
We are looking to see what you would like to get. Also we are looking to be as competitive as possible on pricing. So if you could review this list and tell us what you would like to see us get for you, and if possible approx retail value of items through other suppliers we would appreciate it greatly.
If you have any Questions please feel free to contact me at
Hodges Imported cars. (248)-547-8800
Thank you,
Greg, Jeff, Ben
listen is offline   Reply With Quote
Old 05-24-2002, 04:34 PM   #2
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
2005 Chrysler Town & ****
Oh and Sherif. Please no post Whoring. At least keep it to a minimum
Old 05-24-2002, 04:44 PM   #3
WRB_WRX
Member#: 9442
03 WRX Sedan
The New "03 WRB"
Default STRUTS
I would KILL for the Latest version of the STi Struts for the WRX!
Also you could put the Group-N Motor and trany mounts, Group-N Strut tops (F&R) to your list too.
Karl
WRB_WRX is offline   Reply With Quote
Old 05-24-2002, 04:47 PM   #4
sherifx
Member#: 10780
---- BRZ
Galaxy Blue Silica
I'm interested in these parts...
prices etc...
I wonder if Greg would slip an STi clutch disc when I get mine worked on
sherif
sherifx is offline   Reply With Quote
Old 05-24-2002, 04:57 PM   #5
sherifx
Member#: 10780
---- BRZ
Galaxy Blue Silica
Default Re: STRUTS
Karl
ditto
sherif
Old 05-24-2002, 04:58 PM   #6
listen
Member#: 16837
pm'ng you
Old 05-24-2002, 05:24 PM   #7
sherifx
Member#: 10780
---- BRZ
Galaxy Blue Silica
sooo... where's my pm?
btw ben, jeff has a "body part" for you to look at
sherif
Old 05-24-2002, 06:13 PM   #8
WRB_WRX
Member#: 9442
03 WRX Sedan
The New "03 WRB"
Question
PM? What PM...
Old 05-24-2002, 06:18 PM   #9
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Sti front brakes with rotors, can you guys sell SPT/STi struts with out springs?
DoctorNick is offline   Reply With Quote
Old 05-24-2002, 06:38 PM   #10
Godmal
Member#: 4934
2007 White STI LTD
Grey Mazda 5
Sounds good, how much for the front strut brace?
BTW, please explain the T-belt. I don't understand how a high performance timing belt can help w/ anything and provide more precise valve timing. I'm not flaming, I'm just curious.
Godmal is offline   Reply With Quote
Old 05-24-2002, 07:00 PM   #11
Vipre
Member#: 15484
2007 Mazda3 sedan
05 Legacy 2.5i Sedan
As you rev the engine higher, the belt will tend to stretch a little from the input torque as you change speed. A good belt shouldn't stretch much to begin with, so I don't see that it'll help all that much, but it will help a little. It might not help enough that you'd really notice though.
--Vipre
Vipre is offline   Reply With Quote
Old 05-24-2002, 07:48 PM   #12
Section 8
Member#: 821
STi in tank combination fuel pump/surge tank. I run out of gas on turns with 1/3 tank left now $#!%$!# :monkey:
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 05-24-2002, 11:43 PM   #13
Hondaslayer
Member#: 4562
1995 Legacy LSi
If you are referring to the strut brace in this post its for the rear. As far as pricing goes we are in the process of determining that. And I have to agree with Vipre on the T-belt.
Old 05-24-2002, 11:44 PM   #14
Hondaslayer
Member#: 4562
1995 Legacy LSi
Sorry Neal no brakes yet. I believe the STi struts can be sold seperately ( fairly certain actually) I will check on tues.
Old 05-24-2002, 11:46 PM   #15
Hondaslayer
Member#: 4562
1995 Legacy LSi
Default Re: STRUTS
Karl
No word on the strut tops, mounts, and struts at this point in time. I will personally ask about the mounts and strut tops though next time I see the area Rep.
Old 05-25-2002, 03:49 AM   #16
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
they are jus ta stronger belt...supposedly don't stretch(don't tell anyone but they STILL use a hydraulic tensioner to take the slack out).
OH and by the way you might want to fill out a vendor sheet.
jeremy
Old 05-26-2002, 12:36 AM   #17
Hondaslayer
Member#: 4562
1995 Legacy LSi
Jeremy Thanks for the Suggestion. I will try to talk them into it later this week. Would'nt it make more sense to have HodgesSubaru as a Screenname for this stuff. I thought so too
Old 05-26-2002, 06:25 PM   #18
obyone
Member#: 16523
Depending on the price, I'd be interested in the Hoses, radiator caps, and the Rear strut bar.
Something tells me the flywheel is out of my price range right now.
obyone is offline   Reply With Quote
Old 05-27-2002, 08:57 AM   #19
Tuning Factory Inc.
Vendor
Member#: 3600
cheeRS,
Greg
Did you change the pump? If so did you change the strainer bag and use the stock one? If not, that's your problem. Other than that maybe make your own surge tank. The STi one is ridiculously expensive.
The timing belt is same as the Power Enterprise super strong timing belt. I wouldn't be surprised if it IS a PE belt in an STi box. It still uses tensioner like stock. Just lasts longer and doesn't loosen up with heat. It's highly recommended when yo go bigger camshafts since that puts strain on the belt.
Is the pressure plate available seperately from the disc? How much retail price? I need one badly. I'm going to use a stock disc.
Tuning Factory Inc. is offline   Reply With Quote
Old 05-27-2002, 01:14 PM   #20
Fred Zaplitny
Gone... But not forgotten
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
I would like an STi Version V. All parts except the body and wheels. What do you think, can I get one?!
Fred Zaplitny is offline   Reply With Quote
Old 05-27-2002, 10:53 PM   #21
Hondaslayer
Member#: 4562
1995 Legacy LSi
Sure you can get in line right behind me!
Old 05-29-2002, 04:29 PM   #22
listen
Member#: 16837
what i am looking for is your interest in what has become availiable, i have to get a order together by friday. i have e-mailed the guy handling this program about other parts being availiable. i will let you guy's know as soon as i find out. strut , engine, trans mounts etc. just to name a few.
greg
Old 05-29-2002, 04:41 PM   #23
listen
Member#: 16837
doctor nick,
the strut and mount only come together.
ben wanted me to let you know.
greg
Moore Performance 08+ sti downpipe/catback.....what do you want?? Moore Performance Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 12-26-2009 06:30 PM
What do you want in '07 STI/WRX hwy61 General Community 50 07-14-2005 10:16 PM
what do you want a local auto parts to carry invisibleman Bay Area Impreza Club Forum -- BAIC 11 01-08-2002 01:14 AM
what do you want in the STi model? scoobybrande News & Rumors 7 01-02-2002 12:39 PM
