Old 12-24-2012, 12:12 PM   #51
SubiMashinTime
Member#: 312930
2006 WRX
06 WRX, 52,xxx miles. I have P2433, P2431, & P2444 all showing right now. I haven't taken it to the dealer after reading that they want $1300-$1600 to fix. Also seen that it will prolly fail again even if they do 'goodwill' warrenty fix on it. I've found blocking plates for about $40 and if I can get someone to delete the codes I'm hoping this eliminate my problem. Any thoughts or advice would be cool, this thread is old so PM me with any responses.
SubiMashinTime is offline   Reply With Quote
Old 12-24-2012, 12:17 PM   #52
evrich
Member#: 323104
2007 wrx
sgm
I got both valves on ebay for like 275. did the job myself. You can do it without taking the intake manifold off if you have a lot of extenders and what not. theres a decent vid on youtube of a guy doing it.
evrich is offline   Reply With Quote
Old 01-19-2013, 12:41 AM   #53
Cheech00TS
Member#: 123479
00 Impreza TS
2007 WRX, 160xxx km, no parts mods just a tune. I've been dealing with this for a while, although I've been somewhat lazy about it because it happened right before the winter hit and my garage isn't heated... I had the codes come up for the secondary air system (don't recall which ones) so instead of going to the dealer about it I had a tune done by a local guy with a great rep. Bumped me up to 200whp, and deleted all related codes while he was tuning. I have not yet removed the system but i have disconnected the wiring harness to the pump. Awesome, until my cruise light came on without a CEL.
Cruise light now flashes almost daily, feels like my car is a little limpy, and will not throw a code for diagnosis at all. Cruise light flashing goes away if the engine is shut off for a few seconds and then restarted. I'm at a loss here so if you have any thoughts, I'm all ears. Thanks.
Cheech00TS is offline   Reply With Quote
Old 07-17-2013, 03:16 AM   #54
gunman-13
Member#: 271873
2006 2.5 STI HKS
light silver
Originally Posted by cut2cure View Post
I have a 2007 WRX which I bought used with 30k (now ~34k) that began throwing the CEL with code P2444 3 weeks ago. Even thought it was not covered under the extended warranty I bought, I dutifully took it into the local dealership for evaluation. Similar to others' stories, they wanted over $1600 to replace the air pump and both valves. The service advisor claimed there was no way to more specifically diagnose the fault, and all 3 components needed to be replaced.
Stealerships...
pfhhh
you can check the pump by putting your finger into the exit pipe after removing the tube ( even without taking it out, but make sure the ignition is OFF and the carkey is out of the lock...just for security), and see if the scoops inside move around freely...if they don't, the blower is jammed.
You can also hook the blower up to a car battery after taking it out... if it runs, it's supposed to be ok.... it' s best compared to an almost unnessecary, but pretty expensive 12v hairdryer .
So that's one check you can do yourself.
gunman-13 is offline   Reply With Quote
Old 07-17-2013, 03:22 AM   #55
gunman-13
Member#: 271873
2006 2.5 STI HKS
light silver
Stealerships...
pfhhh
I hope you laughed out loud in his face.. which , I suppose, you didn't...
you can check the pump by putting your finger into the exit pipe after removing the tube ( even without taking it out, but make sure the ignition is OFF and the carkey is out of the lock...just for your own security), and see if the scoops inside move freely...if they don't, the blower is jammed.
You can also hook the blower up to a car battery after taking it out... if it runs, it's supposed to be ok.... it' s best compared to an( almost unnessecary, but in this case pretty expensive 12v ) hairdryer like you use when to heat up your bbq
Old 07-22-2013, 12:25 AM   #56
techno111
Member#: 362980
Hi Everyone. I've run into a strange problem on my '06 9-2X Aero with the P2444 Code and I'm wondering if anyone else has had to deal with the same issue on any of the Subaru vehicles. I traced the problem to a power loss from the ECM at the air pump relay. This causes the air pump not to turn on and registers the P2444 Code. But there is a strange twist to this: the power is lost only after the relay is plugged in.
Here is how I got to the diagnosis .. After both secondary valves seemed to check out ok, I traced the problem to the air pump not running. I pulled the connector off and found no power to the pump. I then checked the relay and fuse and found that both were ok. That leaves just the power from the battery and the relay signal power. I pulled the relay off and checked both power sources on the relay connector (Pins 4 & 3); both checkout at ~12V. I then checked all the contact locations, and again, everything checkout. I'm a bit perplexed at this point: how can this be, relay is good, power in is good, but nothing comes out of the relay when I plug it in. Turns out that when I plug the relay in, the power supply to the relay is lost on Pin 6 (this is the power signal from the ECM that tells the relay to turn on the pump). So, I'm again perplexed. Why is the power lost when the relay hits the contacts??? As I said, the relay tested fine on the bench - I connect it directly to the battery and the switch flips. I'm thinking that there is either a problem with the ECM or the wiring from the ECM to the relay.
Has anyone run into this problem? Would really appreciate your thoughts!
Thank you!
techno111 is offline   Reply With Quote
Old 07-22-2013, 01:52 PM   #57
left footed whooten
Member#: 44652
06 WRX
17 Colorado Duramax comin
Again, if you contact SOA, arrange a diagnosis so they have documentation, they will likely grant you the good faith deal and pay for 40-75% of it depending on your situation and mileage. They paid 50% of mine. Pumps, relays, the whole bit. Casually mention that through online forums, you heard of a possible good faith repair. thats what I did. It cost some cash, but in the headaches and time and trouble of trying to get around it or remedy it myself, I still came out on top. My cars been solid ever since and it took until 145k to break in the first place. Now im at 170k and going for my first clutch finally.
left footed whooten is offline   Reply With Quote
Old 07-22-2013, 01:54 PM   #58
left footed whooten
Member#: 44652
06 WRX
The flashing cruise control light is a sympathetic error light. Meaning that because there is a CEL going, it will disallow things like the cruise control. Nothing wrong with your CC, thats how its supposed to work. When the problem is fixed, the CC will resume function and stop blinking.
Old 07-27-2013, 08:19 PM   #59
BLK BUTY
Member#: 358485
2013 WRX Premium
I also had the CELs for the secondary air pump. I bought the pump and the the 2 other parts for a complete "overhaul". When I took the system apart the valves for the other 2 parts were stuck in the open position due to dirt and grease. Replace just those and the car worked liked a charm. Didn't need the pump and the dealer won't take it back. Still sitting in the box.
BLK BUTY is offline   Reply With Quote
Old 07-27-2013, 08:36 PM   #60
left footed whooten
Member#: 44652
06 WRX
May as well put that sucker on then, likely only a matter of time before it takes a crap too. From what I understand they all go, one as a resut of the other
Old 07-27-2013, 09:00 PM   #61
BLK BUTY
Member#: 358485
2013 WRX Premium
Sold the car I have a 2013 now
Old 11-18-2013, 05:32 PM   #62
Teddybaby
Member#: 368397
2006 WRX Wagon
I also have a 2006 WRX Wagon which started throwing a few of these codes. I brought it to the dealer and he told me it would be $1800.00 to fix. After finding this thread and buying a block off kit and Cobb tuner I was able to remove both pumps and reprogram the ecu. I started by deleting the codes one by one but found a new one would pop up in a few days. Someone posted all the codes that needed deleting and I did that 2 months ago and has been fine ever since. I also went thru NJ inspection with no problems.. Here are the codes I deleted . 06/07 WRX:
P0410 P0411 P0413 P0414 P0416 P0417 P0418 P2431 P2432 P2433 P2440 P2441 P2442 P2443
P2444
Props to the person who posted them..
Teddybaby is offline   Reply With Quote
Old 05-29-2014, 03:37 PM   #63
awelch85
Member#: 392184
I've searched and didn't come up with anything. I want to delete these codes, I have a Cobb Tuner. How do I delete them? I can reset the ECU and the CEL comes right back. I need my cruise control!
awelch85 is offline   Reply With Quote
Old 05-29-2014, 07:50 PM   #64
left footed whooten
Member#: 44652
06 WRX
Aint gonna happen until you fix the problem.
Old 05-29-2014, 08:16 PM   #65
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
You need to download Accesstuner RACE from Cobb. Google it. Then you will take whatever map you have (OTS only, most tuners lock theirs) and go through and delete the codes.
Old 07-16-2014, 02:34 PM   #66
cklin
Member#: 259693
2006 WRX Ltd
My 2006 WRX posted P2444 and P1410. Called up Subaru dealership for repair quote. Was told my model year doesn't have a secondary air pump or associated valves, that my usual mechanic wasn't using a "Subaru" reader so had just pulled the generic codes, and that it's probably something else with the EGR. Was told Subaru only started putting in secondary air pumps into the '08 STI.
This thread seems to tell me differently. Can anyone reconcile this? Or is this dealership totally bogus?
cklin is offline   Reply With Quote
Old 07-16-2014, 02:41 PM   #67
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Secondary air injection began on WRX and STI in 2006.
Old 05-08-2015, 10:53 AM   #68
Padawan
Member#: 406834
Does anyone have experience with the "Secondary Air Eliminator" from Associated Global?
It appears to disable the system electronically to suppress any of the related secondary air codes, but I can't find any information or testimonials other than what's on the manufacturer's website, and the fact that there is no US contact information makes me hesitant to spend $350 on this.
I imagine one could accomplish the same thing with a Tactrix Openport for less money, but this would be a plug-and-play solution if it actually works.
Padawan is offline   Reply With Quote
Old 11-03-2015, 11:23 PM   #69
Montero_33
Member#: 428138
Default Help please.
Hey guys so long story shorts something's wrong with my 2006 wrx. And happens to be with the secondary air pump. So let me explain what happened. It was at night about 40 degrees Fahrenheit turned my car on and a couple seconds later my check engine light turns on. So I turn the car off and back on. Just to see how things started again. And car started with no problem. But about a min later I started smelling fumes. Like a smokey scent. So I panic and turn the car off and take the keys out. That's when I hear a loud noise coming from the engine bay so I open my door and open the hood. And air pump was still running. And it was pretty loud and getting warmer. So I open up my fuse box and take out the air pump relay and it quickly turns off. I put the relay back in after a couple mins later and it stays off. Now my car turns on fine but the lights still on. Is it the relay that gets stuck? Or is it the pump itself.
Montero_33 is offline   Reply With Quote
Old 11-04-2015, 02:07 AM   #70
left footed whooten
Member#: 44652
06 WRX
So, did you read the CEL for the codes?
Old 03-15-2016, 08:40 AM   #71
alchow
Member#: 442593
Default eliminator
Hi did you found out this eliminator work ? I am looking into getting one.
alchow is offline   Reply With Quote
Old 03-15-2016, 11:50 AM   #72
aerostar
Member#: 103512
2015 M235i
Do not replace it.
Do the blocking plates and delete the CEL codes.
aerostar is offline   Reply With Quote
Old 03-16-2016, 11:08 AM   #73
alchow
Member#: 442593
Default eliminator
I have a 07 Forester XT have the same problem , p2441 , p0410 and so on. The blower and valves actually replace 3 times for the same stupid water issues cost me thousands of dollars.
Did anyone have experience with this product ?
Secondary air system eliminator
And this is a module that can simulate the secondary air system . No need to remove any hardware or tune the ECM.
This is their Web site.
Secondaryair injection. Org
Old 04-04-2016, 03:11 PM   #74
kashirat
Member#: 137638
I am getting something slightly similar - getting P2441, P2443 and P2444 consistently after I reset the codes and start the car a few times. Could this just be a fuse issue?
2441 and 2444 says bank 1 is stuck open and closed??
And bank 2 is stuck closed.
Would love to do the block off but there are no tuners in my area. Any easiy to check things before I am forced to bring it in to subaru?
kashirat is offline   Reply With Quote
Old 04-04-2016, 03:32 PM   #75
YNRY
Member#: 407737
2006 STi
wut car
YNRY is offline   Reply With Quote
Plugging Secondary Air Pump BlueSubeDude Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 08-03-2013 08:36 PM
CEL p2444 secondary air pump?? tcr04 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 07-27-2013 07:12 AM
WTB: Secondary air pump baro sensor 07 WRX ronzogonzo Private 'Wanted' Classifieds 0 11-25-2009 05:37 PM
Secondary Air Pump Solutions? JonJ Service & Maintenance 7 09-29-2009 10:13 AM
