Old 01-29-2010, 12:18 PM   #1
Nickarub
Member#: 230509
06 vf39 wrx
ugm
Default economy mode with stage 2?
i just switched my downpipe and am stage 2 now. i am LOVING IT. but i am a big fan of the Economy feature. can i run the regular economy feature on the new TBE?
Nickarub is offline   Reply With Quote
Old 01-29-2010, 01:26 PM   #2
Cobb Tuning
Member#: 4803
Yes you can run your car in economy mode with a full TBE, but, DO NOT get into boost. Drive it like it's your grandma's caddy.
Travis
COBB Tuning
Old 01-30-2010, 11:57 PM   #3
quick4dr
Member#: 229938
2005 Legacy 2.5GT
Default grandma indeed
Drive like grandma even without economy mode will save you gas. Ive always been taught that the cars most powerfull tune will result in the best fuel economy if not beating on it. I hear the economy map helps by cutting boost levels, but just drive with a light foot will help too.
quick4dr is offline   Reply With Quote
Old 01-31-2010, 12:51 PM   #4
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
Yimi Tuned 296AWP/322TQ
get a boost gauge and stay out of boost and you'll get much better mileage AND have power on tap when you need it.
Tahoe SC is offline   Reply With Quote
Old 01-31-2010, 01:44 PM   #5
lando
Member#: 149637
2010 STI SE
Eh..running stage 2, tried the economy mode. Did nothing. I get 19mpg no matter what or how i drive my car :X
lando is offline   Reply With Quote
Old 01-31-2010, 05:25 PM   #6
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
i get 24-25 mpg all year. stage 2 mods and mapping. even have a perrin tmic. no highway driving at all. id say some of you step are on the go pedal too much!
424wrx is offline   Reply With Quote
Old 02-09-2011, 11:38 PM   #7
black civic
Member#: 28948
Travis
COBB Tuning
I also have a TBE and just changed from a pro-tune to the economy map for my commutes. Is there a danger to going WOT on the economy map? I'm sure I will forget I'm on the economy map when accelerating on the on-ramps or during passing.
Thanks
black civic is offline   Reply With Quote
Old 03-15-2011, 11:30 AM   #8
newscoobboob
Member#: 119956
2006 wrx waggin
Lexus White w/ Pink pearl
My grandmas caddy can haul some a**.
When I was stage one using my accessport to monitor mpg I could get 31mpg cruising and 14.5mpg while passing at full throttle.
newscoobboob is offline   Reply With Quote
Old 03-17-2011, 12:56 PM   #9
Borjaq
Member#: 4812
04 STi
Blk
Stock and Stage 1 I get about 21 mpg, economy I get about 25 but ONLY after being on the highway for 15 mins or so. Hopefully a protune might help sort it out though and net me some more mpg's.
Borjaq is offline   Reply With Quote
Old 03-17-2011, 03:12 PM   #10
static-psi
Member#: 237649
04 STI
blue
I drive 1 mile to work each day. My sti gets a new tank of gas every two weeks. I get so frickin pumped to go and waste gas when I get my chance. Idk if I will ever use my eco mode. Heck I dont even really know what its doing? What is it doing?
static-psi is offline   Reply With Quote
Old 03-17-2011, 03:46 PM   #11
Cobb Tuning
Member#: 4803
Thanks
Well, that kinda defeats the purpose. The economy mode basically sets WGDC to 0 to seriously curtail boost. The econo mode is for cars with stock intakes etc so if you are running anything more than just a turbo back, then your other parts won't be tuned for so, if you DO go WOT then you would be doing so without the proper tune essentially. If you just have a turbo back, the only consequence is that you will just not get full boost and you will also be using up your gas!
Travis
COBB Tuning
[email protected] with stage 2 wrx? Sparconx88 Proven Power Bragging 43 05-23-2009 11:40 PM
FEELER: (CNJ) Cobb AP V 2.0 With Stage 2 Protune map PartySTi Engine/Power/Exhaust 4 11-11-2008 11:29 PM
Mileage worse with economy map vs stage 2 ? subieslo AccessPort 12 08-07-2008 09:59 AM
Using Economy mode with AP. Badmunky Newbies & FAQs 17 11-22-2007 11:31 AM
Cobb stage 1 reflash with stage 2 hardware - problems? jroberts Engine Management & Tuning 4 02-03-2004 01:28 AM
