Old 01-29-2010, 09:16 PM   #1
Legacymun2k6
Member#: 170710
2015 WRX Limited CVT
Diamond Grey Mettalic
Default Check engine light, VDC light is on, and cruise control and sport light is flashing
I was driving home on my way from work, about half way during my commute the cruise control light starts flashing along with the sport mode [s] light. The check engine light along with vdc symbol for off appears on the dash. I can't even switch to I nor S# mode. I hope its not something serious, just in case I kep the car under 2,000 rpm's and listend to make sure the turbo wasn't making any unusal noise. I have the gold plus extended warranty til 60k. Car was purchased new from Subaru of Nashu, back in august of 08 and it currently has 47,859 miles.
Legacymun2k6 is offline   Reply With Quote
Old 01-29-2010, 10:05 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
get
the
cel
codes
read
and
post
the
codes
here
and
just
the
codes
Old 01-30-2010, 01:06 AM   #3
05redrex
Member#: 86665
2005 WRX SRR 2.5/20g
2010 FXT SWP Cobb Stg2+
Sounds like O2 sensor or something died, either way it's the dealer's problem if it is under warranty.
05redrex is offline   Reply With Quote
Old 01-30-2010, 12:23 PM   #4
Legacymun2k6
Member#: 170710
I called the service dept at the dealer today, told them my problems. They asked me if I had at least a half of tank of gas. They said the gas cap might be loose to check that. Drive for a day or two and see if it changes things. Than if not to make an appointment. I'll check the gas cap, and maybe reset the battery see if that changes things. I also might swing by autozone to pull some codes.
Old 01-30-2010, 12:36 PM   #5
05redrex
Member#: 86665
Loose gas cap will set off check engine light. But your car seems like it is in limp mode - doubt the gas cap will do that.
Old 01-30-2010, 12:47 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
get the ****ing codes read
THAT is THE answer
the ONLY answer
blind pissing in the dark may just blow it up for ya
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Engine light on and cruise control flashing. 07silver2.5i Texas Impreza Club Forum -- TXIC 14 01-04-2010 10:00 PM
CEL came on, and Cruise Control light is flashing 07Wagon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 12-31-2007 12:12 PM
Check engine and cruise control light on TENAZ Engine Management & Tuning 6 03-13-2007 01:16 PM
Check engine light on and cruise control light flashing mpadovano Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 01-23-2005 02:04 PM
