Old 01-29-2010, 10:12 PM   #1
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Default Is ABS an OBDII readible parameter?
I want to know when the car activates ABS.
I know that ABS goes active well before you can hear the "brakes pulsing" and in many cases you can't even hear/feel the pulsing due to road noise and other vibrations.
Is ABS active a "live data-able" thing via OBDII such that AP2 could potentially make a gauge out of it?
Also... if yes, then is ABS active distinguished by each wheel?
chimchimm5 is offline   Reply With Quote
Old 01-29-2010, 11:16 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
You can't read it with an obd2 scan tool.
Where is the connector for an OBDII scanner? tad_02Wgn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-19-2004 12:23 PM
Is ABS really an advantage? SgWRX Brakes, Steering & Suspension 28 02-24-2002 02:31 PM
Is it possible to use an OBDII tool to log EGT's? LiquidForce Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-04-2001 06:01 PM
neone have an OBDII scanner? m750 New England Impreza Club Forum -- NESIC 10 05-19-2001 06:05 PM
