#1 |
Member#: 226841
Vehicle:2002 WRX Silver |
What is the easiest way to take out the bottom 2 19mm bolts on struts? Because i was trying to take out the struts to put in new ones. i been working all day and i think i stripped the head of one of the bolts already. and i can take the top bolt off but the bottem one is always the hardest one. I used PB blaster and also WD40 but it still wont move. i haven't tried air tools yet though. can anyone help with some advice. Thanks
#2 |
Member#: 183717
TXIC
Vehicle:1999 2.5RS BRP |
3-5 ft breaker bar.
![]() but yea, if you've stripped the bolt head, then that might only make things worse. You should get a replacement bolt handy in case you need to cut it off or if it is unusable after removing because you can't torque it down properly. |
#3 |
Member#: 106225
Vehicle:02 WRX STied PSM 11 Taurus SHO daily |
Don't try to turn the bolt. Try to turn the nut.
#4 |
Member#: 226841
Yeah the breaker bar stripped the bolt head actually. How would you cut it off if it is stripped?
Also, do you know where i can get an extra bolts? and Would you actually know where i can get some studs for the 5x100 wheels too? |
#5 |
Member#: 32459
Vehicle:02 WRX VF34 Junior Tuned 301whp |
Corded impact wrench. See if you can rent it from home depot.
Worked amazingly well on my car which has been driven in salty road for years. |
#6 |
Member#: 226841
#7 |
Member#: 226841
#8 |
Member#: 32459
I bought one from Home depot for $190 and it has worked amazingly well. Used it to replace struts, springs, knuckles, etc.
#9 |
Member#: 226841
damn im not really trying to buy it, do you remember how much was it to rent it?
#10 |
Member#: 197418
NESIC
Vehicle:07 WRX Ltd The Mighty Evo |
When I did mine, I sprayed a ton of pb blaster on it overnight.
Then use a wrench, a rubber mallet, and slowly hammered it loose. As for tools, buy it on CC, use it then return when you're done. |
#11 |
Member#: 32459
using mallet is another excellent idea... renting tool is free; you will need to pay full retail which will be refunded upon return of the tool.
#12 |
Member#: 209358
Vehicle:06 Sti WRB |
#13 |
Member#: 226841
#14 |
Member#: 226841
does anyone know where i could get extra 19mm bolts?
#15 |
Member#: 209358
#16 |
Member#: 32459
#17 |
Member#: 200288
BAIC
Vehicle:2002 Impreza WRX World Rally Blue |
but a set of camber bolts, they are like $20 but you can find nuts and bolts at ACE if you have one around you.. as for taking those bolts off, you really had a hard time? i can usually break those loose very easily lol they have plenty of metal to grab onto, im surprised you stripped them |
#18 |
Member#: 226841
yeah they were rusted hella bad stock suspension from back in 02. i only stripped 1 and tried another and it was bad news so i didnt even attempt to fully do it. 5hours = 1strut gone. :O
#19 |
Member#: 207366
SCIC
Vehicle:2009 WRX Sedan SWP |
#20 |
Member#: 226841
do you know how much it would be from a dealer by anychance? cause i was just thinking of winchester
#21 |
Member#: 200288
BAIC
#22 |
Member#: 226841
ohh i did trust me half can is gone :O
#23 |
Member#: 152042
NWIC
Vehicle:2002 WRX WRB |
Hammer on an 18 mm an use an pneumatic impact gun. done deal
#24 |
Member#: 226841
@newbuggy you think so?
#25 | |
Member#: 188593
NESIC
Vehicle:2004 Impreza WRX 18L |
http://www.sears.com/shc/s/p_10153_12605_00952166000P PB plaster it take a little while to penetrate - I would give it at least 30 minutes to soak in. For replacement bolts the dealer or a place like autozone or napa would be the place to go - the guys at the desk will be able to help you find what you need and make sure it is a high enough grade for your application. |
| Thread Tools | |
| Display Modes | |
| easiest way to take apart the hawkeye headlight?? | scooby1320 | Interior & Exterior Modification | 17 | 03-03-2012 02:36 PM |
| is there a way to take off the side moldings off the 08 sti? | swizz977 | Interior & Exterior Modification | 1 | 08-13-2009 09:32 PM |
| Whats the best way to figure out the mortgage you can afford? | Padge | Off-Topic | 15 | 02-13-2007 03:18 PM |
| whats the easiest way to make the radio and lighter work w.o the ignition on | swingkid | Forester Forum | 1 | 02-16-2004 12:50 PM |
| Requesting the easiest way to take out rear spaeker on 99 RS | gerardchau | Car Audio, Video & Security | 1 | 05-30-2002 07:44 AM |
