#1 |
Member#: 228856
South East
Car details:
2002 WRX (stock motor and turbo)
Tuned on 93 octane (gray lines) Tuned on E85 (red lines) Boost: 24.5psi (peak mid-range) tapering to 18psi (redline) We tuned this car a few weeks ago and I promised the owner that I'd through it up. I want to say first that it takes a lot to impress me these days. I say this because power, quickness, etc is all relative you know ![]() For example, our 2005 shop Evo recently put down 720whp at only 35psi on E85. That was only shakedown numbers as we're going for 900whp at 45psi and C16 when everything is said and one. So anyway, back to the little TD04 powered car. The initial pull on my OTS map showed a really disappointing 192whp on pump gas (93 octane) at lower boost. I new we were going to need to work on this one a bit to get my normal numbers of 235-245whp that I see on most 2.0L WRXs. Fast forward to the final number on pump gas of 252whp. We then dumped 10 gallons of E85 on top of an empty. Loaded our tweaked pump gas map to run on E85 and we were off. The first pull was about 260whp with little done except to scale the injectors. We then continued run after run to the final numbers seen here. This was one of the stronger WRX motors I have seen and thought you might like to see it too. The initial peaks in the torque curve is where the boost hits hard and then stabilizes. ![]()
#2 |
Member#: 167739
Vehicle:04 WRX |
Soooo want E85. What IDCs were you running at peak?
#3 |
Member#: 228856
South East
#4 |
Member#: 201827
International
Vehicle:1998 Impreza GT Blue |
is this possible for gt?
#5 |
Member#: 228856
South East
What exactly does the "GT" have in it? An EJ205? If so then yes. Do you have access to ethanol in Latvia?
#6 |
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
#7 |
Member#: 54060
Vehicle:205 + td04=12.4@109 V8 207+VF37=12.3@111 |
Nice results, wish we had E85 here. What correction factor was used?
#8 |
Member#: 133418
Vehicle:2006 DOM3 XTR WRX TR SRR 407whp 365wtq ppg'd |
wish we had e85 in jersey we have one station and its over an hr away from me. I bet i can make 400whp well until then i'll just have to dream.
#9 |
Member#: 26568
NESIC
Vehicle:2003 Yellow Bugeye Version 8-Vf37 |
thats alot of foot lbs of torque for the 5spd tranny....but i want e85 too
i heard it even smells nice when it burns haha. |
#10 |
Member#: 220246
Vehicle:2007 WRX TR WRB |
So glad to see people are experimenting with E85 and the TD04...I've been thinking about trying this, so many gas stations are selling it in the St Louis area now, and its 50 cents a gallon cheaper than 93 octane.
Definitely gonna get an E85 map with my Stage II tune. If it works, definitely a better option for me than swapping turbos. |
#11 |
Member#: 217423
RMIC
Vehicle:02 wrx E85 psm |
If you don't mind- What kind of timing and afr's are you seeing?
#12 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
u got a PM
#13 |
Member#: 228856
South East
Replied, Juan!
AFR were in the 12s |
#14 |
Member#: 228856
South East
#15 | |
Member#: 228856
South East
That's how we roll at Motion Lab. Although, I'd still prefer 120 leaded octane any day of the week if it was affodable. That's the beauty of E85 though. You get a nice fuel for the price of unleaded crap gas. Can't argue with that. |
#16 | |
Member#: 201827
International
1liter of premium gas - 1.49usd normal - 1.44usd disesel 1.35usd e85- about 1.15$ vin decoder says - EJ20G Last edited by Arr; 01-31-2010 at 08:14 AM. |
#17 | |
Member#: 228856
South East
Actually that's not a bad motor. I believe it came in a couple if different flavors. IIRC there was a closed deck 20g and an open one. No idea what you've got. How would you tune for the difference in fuels? Are you running stand-alone EMS or piggyback? Shoot me over a PM and I may be able to be of some assistance. We've literally done over 75 unique tunes over the years between Evos and Subarus. There's a lot more to just tuning for power on ethanol that many other tuners are just staring to realize. |
#18 | |
Member#: 79858
South East
Vehicle:2002 WRX Black |
This is my WRX by the way. Its absolutely INCREDIBLE! The kick this thing has is wicked! Also the motor, tranny, and turbo are the stock untouched units with over 110k miles on them. Todd got all the power mods, really dont have many mods in terms of power, just the right ones . Really I think the only power mod he forgot was a gutted WRX up-pipe. But thats it! Here are some vids and photos.....![]() ![]() ![]() ![]() ![]() Dyno vid Last edited by speedin; 01-31-2010 at 01:18 PM. |
#19 |
Member#: 150647
NWIC
Vehicle:98 Impreza 2.5RS Ej20G hybrid |
Wow, I wish you guys lived closer to me...
I need a pp6 tune + I just got 800cc injectors + I need that UEGO! Some bad ass numbers you guys put up there. |
#20 |
Member#: 228856
South East
#21 |
Member#: 133146
#22 |
Member#: 79858
South East
#23 |
Member#: 228856
South East
Yeah that's right, Mark decided to go the boost 'pill' route. Works ok but our 3-port BCS would've been considerably better
#24 | |
Member#: 4414
If you put a ball / spring style MBC there's NOTHING pushing on the wastegate to open it. And in that situation, the TD04 normally still only holds 12-14ish PSI @ redline in every setup I've ever seen. It simply runs out of breath. You can't make the turbo give boost there with boost control. It's like someone posting a 10.x 1/4mile timeslip with a stock STi and then saying they were able to go faster than every other STi by cutting the stop on on their gas pedal so they could push it down further than anyone else... it just doesn't work like that. I just don't believe that 18psi @ redline from a normal WRX TD04 happens just with boost control. I've seen too many counter examples to believe you just cranked the boost and got 18. Are you positive your gauge is reading correct? Last edited by Concillian; 02-01-2010 at 04:34 AM. |
#25 |
Member#: 147637
International
Vehicle:HJ's Ask Hobbs. He knows. |
^I was thinking the same thing. The graph looks like it's a correction factor change. I believe a little more torque and maybe a slight spool increase can be had from E85 and a td04. But like a few have said before the turbo just runs out of breath. I guess some extra timing could help a little for the top end, but the turbo only moves so much air.
| Thread Tools | |
| Display Modes | |
| fs: TD04 and stock WRX injectors | ocelot21 | NWIC Private Classifieds | 0 | 07-15-2009 12:37 AM |
| Fs Ported td04 and ported wrx header | Digmaster | Engine/Power/Exhaust | 10 | 10-19-2008 10:04 PM |
| FS: Cheap TD04 and stock WRX TMIC | minhha2006 | Engine/Power/Exhaust | 7 | 10-08-2008 07:32 PM |
| FS: td04 and 06 wrx intercooler | seventhsign | NWIC Private Classifieds | 3 | 09-04-2008 04:52 PM |
| FS----->619: td04 and 06 wrx tmic | rendog24 | Engine/Power/Exhaust | 19 | 03-17-2008 01:03 PM |
