Old 01-30-2010, 02:21 PM   #1
Spookpur
Member#: 218621
11 WRX
Default AccessPort AFR Question
Hey guys, I just installed a stage 1 93 octane map on my 09' WRX. Flash went fine and everything seemed normal. I took it out today and was playing around with the live data tools, I noticed that when I depressed the clutch or let off the gas all the way, the AFR would jump from the 12-14.8 up to 20.5 for a couple seconds and then back to normal. Is that a normal thing as the engine is cutting fuel briefly? Also, are the Cobb OTS maps suppose to eliminate the hanging rev feature during low speed shifts? It's still there and wanted to confirm this. I made sure the map is correct, shows the stg. 1 93 octane as both reflash and realtime, also did the AP firmware updates before the initial flash.
Thanks!
Spookpur is offline   Reply With Quote
Old 01-30-2010, 02:30 PM   #2
arghx7
Member#: 232940
Yes
What is this feature you are referring to?
arghx7 is offline   Reply With Quote
Old 01-30-2010, 02:34 PM   #3
Spookpur
Member#: 218621
11 WRX
The 08-09 WRX's have a tune issue where the factory ECU briefly causes RPMs to hover around 2000 when your in 1st or 2nd gear and depress the clutch. Annoying as hell but it's there for people that are just learning to drive and to help prevent stalling. I thought a reflash would make it go away....
Old 01-30-2010, 02:55 PM   #4
Spookpur
Member#: 218621
11 WRX
Actually just found some info on here at http://forums.nasioc.com/forums/show...1643806&page=3 post #58 sounds like me. Also, a few posts down, they start talking about what may be causing it and why a reflash may not be eliminating it.
On a side note, stage 1 is great from what I can already feel driving. Starting to feel closer to my EVO IX I sold.
quick AFR question imma_stocker AccessPort 14 08-03-2007 05:54 PM
noob AFR question in regards to stock Downpipe vs. Bellmouth DP Ski Bum Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-20-2005 02:56 PM
Quick AFR Question Killian Maynard Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-13-2005 12:35 PM
bov and afr questions azn2yunr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-15-2005 08:44 AM
AFR questions turbohardtop Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 08-31-2004 02:35 PM
