Old 01-30-2010, 07:37 PM   #1
pmatty
Member#: 114100
2002 Subaru wrx
Default NEED HELP! check engine lights all fuel related
okay i threw p0453,p0463,p0183 and now my gas gauge stoped working and says iam on e, i have a walbro i put in probly about a year ago with no issues and this all happen basically at the same time any ideas?
pmatty is offline   Reply With Quote
Old 01-31-2010, 07:00 PM   #2
pmatty
Member#: 114100
2002 Subaru wrx
Anyone ?
Old 02-01-2010, 12:53 PM   #3
Haelan
Member#: 151045
2013 Subaru STI
CBP
Inspect the electrical connector on the fuel pump port cover. I had a mouse nest on top of mine at one point and they chewed the labels off the wires to make bedding.
The other suggestion is to check the joint shield connectors. I also believe there is a rear ground in your trunk that you can check.
Haelan is offline   Reply With Quote
Old 02-01-2010, 02:24 PM   #4
m_alva02
Member#: 192398
the p0463 and p0183 should be in tank pull the fuel pump and check all connections ...ill pm you some more info for shooting wires if you need it. the p0453 might just be that you need a new gas cap check the oring on you current cap if its hard or cracked replace it.
m_alva02 is offline   Reply With Quote
Old 02-01-2010, 05:42 PM   #5
pmatty
Member#: 114100
2002 Subaru wrx
everything looked fine i orderd a whole sending unit see if that solves the problem i hope so it sucks driving around not being able to see how much gas you have
1994 Subaru Legacy Check Engine Light and Fuel Odor Inside Car Modog100 Service & Maintenance 5 04-01-2006 11:32 AM
HELP!!!!!Check engine light and cruise light on joe198219 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 01-17-2006 08:07 PM
help check engine light and abs light??? greentre Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-15-2002 06:11 AM
Need help- check engine light coming on, think I am pushing around 20 psi scoobydoo02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-04-2002 10:01 PM
Need Help-Check Engine light is on AndyHidley Technical Forum Archive 3 05-19-2000 02:35 PM
