Old 01-31-2010, 12:08 AM   #1
DoucheBag Doug
Member#: 210987
02 STi
MBP
Default Having issues with DBW in my 02 STI swap... NEED HELP!
Ok so im swapping a 04 STI into my 02 WRX and it is pretty much done. Every part has been pulled from the STI and placed in the WRX including all wiring and sensors. The only issue I'm having is when I turn over the car it starts right up but jumps to 1500-3000 rpm range, different every time, then dies shortly after. Also I'm getting no throttle response. We've already removed the TMIC to see If the butterfly opens when the car idles, which it does but barely and won't open any farther when the pedal is applied. Im guessing it has something to do with the DBW controller on the pedal assembly but not sure. Any trouble shooting information or advice would be much appreciated. Thanks
DoucheBag Doug is offline   Reply With Quote
Old 02-01-2010, 01:00 AM   #2
chaweleon
Member#: 236647
Default Re: Having issues with DBW in my 02 STI swap... NEED HELP!
what about the immobilizer? sounds like its not finding the key and turning off right after..
chaweleon is offline   Reply With Quote
Old 02-01-2010, 09:52 AM   #3
GLD247
Member#: 207789
2003 WRX EJ257 Swap
i had the same problem... my throttle relay was missing, make sure you have the relay on the harness
GLD247 is offline   Reply With Quote
Old 02-01-2010, 10:51 AM   #4
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
the immobilizer shouldn't even let the car start without the key to match.
ProdriveDreams is offline   Reply With Quote
Old 05-28-2010, 09:45 AM   #5
TheLordChesterfield
Member#: 234539
I know this is an old thread - dunno if you got it worked out.
It cannot be the immobilizer if it truly is an '04 - they were not included until '05.
Let's see some pictures!
TheLordChesterfield is offline   Reply With Quote
Attn 06/07 WRX owners with 06 STi swap...NEED HELP!!! jester696 Transmission (AT/MT) & Driveline 3 08-03-2008 05:53 AM
sti swap need help please gc8v6 Normally Aspirated Powertrain 3 04-07-2008 09:02 AM
Deciding on wheels for my 02 WRX wagon....need help TurkWRX General Community 3 01-24-2008 11:58 PM
my 02 hesitation situation, need help frankobra Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-07-2007 06:51 PM
Help! Small under hood fire in my V7 sti swap! sith Subaru Conversions 7 06-26-2007 12:14 AM
