Old 09-03-2010, 08:20 PM   #251
jr4284
Member#: 192336
2006 STiPad
They want to me to change the design of that area, on the back side. It's doable, certainly, but it's a non-tool safe change they're talking about. I've sent in an inquiry regarding higher pressures or longer hold durations... hope to hear back on Monday.
Great way to start the long weekend
jr4284 is offline   Reply With Quote
Old 09-03-2010, 08:25 PM   #252
Web Foot STi
Member#: 39086
2004 STi
Adding feeder ribs, or some small local ribs to increase surface area? These are tricky because they also increase the local mass. Bosses in the middle of nowhere are usually a problem with shrink.
Web Foot STi is offline   Reply With Quote
Old 09-04-2010, 09:35 AM   #253
xazzu
Member#: 129036
2006 WRX Sedan
Originally Posted by jr4284 View Post
Seriously, find 180 of your friends that are interested in it and then I'll take on the risk of the rest. I wish it were as easy as "design it and we're good," but financially it's not worth the risk.
I understand about financial risk, but I'm a little surprised that there isn't at least 178 other people with the manual controls out there that want this. Could always make a thread with check boxes to see what kind of models people have and what version they're interested in.
Either way, I'm watching progress with interest and hope you continue to do well!
xazzu is offline   Reply With Quote
Old 09-04-2010, 04:38 PM   #254
jr4284
Member#: 192336
2006 STiPad
They were asking to reduce mass in an area = add mass to the mold. We're going to try opening up the gates and increasing the pressure first. Hopefully that goes well. I'll update after the next sampling. The molding guys are relatively confident that it will work w/o retooling.
Thanks! 178 isn't my break even point, it's just a level where if all failed after that, I'd (only) have an extra car payment a month.
The thing is, the people have to:
1) Want an iPad
2) Want to put it in their car
3) Have a subaru
4) Have an impreza/wrx/STi
5) Have a model year 2005-2007
6) Have manual HVAC controls
7) Know of NASIOC or my docking solution
So it's a pretty damn small slice.
Old 09-07-2010, 11:23 AM   #255
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Spent a few hours this weekend hanging all the accessories off the Alpine CDA-9886. I said goodbye to the stock head unit and Sirius kit so had a big empty space to work with.
Oddly enough the XM tuner box shares a hole pattern with part of the dash so I used those screws for the bottom and a piece of steel bolted across the top using a couple of dash studs. I then sandwiched the digital adapter with DS tape and zip ties to finish that part. Not sure I will even use XM Radio, but it's there if I do.
Closer view:
For the Bluetooth adapter I bolted a piece of aluminum across the two lower mounting holes that used to secure the head unit cage. More DS tape and a wire tie finished that.
I really like the Bluetooth input capability. Play any audio on your iPhone and it sounds great on the car's speakers. Also tried the incoming call audio mute and that works very well with Caller ID displayed on the Alpine. The audio ramps back up after the call.
Since Justin is having problems with the mold, I'm going to take a shot at a temporary mounting for the iPad to cover that unsightly double-DIN hole in the dash.
SonicWRX is offline   Reply With Quote
Old 09-08-2010, 12:18 AM   #256
jxkim
Member#: 239150
2003 WRX Sedan
1) Want an iPad
3) Have a subaru
true you are gearing towards a small market. but you will have domination of that market
i wish there was something as cool for my HTC incredible. off topic but anyone know any cool android apps? would be awesome to see something similar to what JR showed off on the iPad
jxkim is offline   Reply With Quote
Old 09-08-2010, 10:07 AM   #257
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Was looking around for a temporary solution to my gaping double DIN dash hole and may have come up with a solution for Imprezas with manual controls. In no way do I want this to take away from Justin's efforts as I think his solution is far superior, but it could work. I don't have these parts so can't say for sure.
To do this you would need to remove your stock deck and cover the hole with a double DIN blockoff plate like this one:
To this plate you would bolt a Wallee mounting disk:
You would then put your iPad into a Wallee and rotate it into the mounting disk in either portrait or landscape mode:
Pros:
- Fairly cheap ($70 or so)
- Very easy to install
- Offers both orientations
- Quick release
- Retains stock hazard button location and vents
- Can be reused elsewhere if Justin makes a manual control bezel later on
Cons:
- No hidden charging or audio out (this is a show stopper for me)
- Looks bad when the iPad is removed
- May have issues with mounting angle and clearance
- Not nearly as OEM and professional looking
Old 09-08-2010, 01:24 PM   #258
jr4284
Member#: 192336
2006 STiPad
BAM! Sampling #2.
Small venting issue still needs to be worked out, but that's nothing compared to what just got fixed.
Old 09-08-2010, 01:34 PM   #259
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Old 09-08-2010, 01:52 PM   #260
Web Foot STi
Member#: 39086
2004 STi
BAM! Sampling #2.
What was the major fix?
Scratch vents are nothing.
Old 09-08-2010, 01:53 PM   #261
jr4284
Member#: 192336
2006 STiPad
See post 248
Old 09-08-2010, 02:01 PM   #262
jr4284
Member#: 192336
2006 STiPad
When it rains, it pours. Update from the cosmetics guys:
Cutting Die:
Sampled Fiberboard:
Ring and 2 pieces make the "i", the other crescents go behind the retainer tabs on the side pieces, so the iPad is all sandwiched nice and safe.
Old 09-08-2010, 02:27 PM   #263
b00st3d
Member#: 9891
2015 RC-F
Ultra White
b00st3d is offline   Reply With Quote
Old 09-08-2010, 03:47 PM   #264
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
So Justin, it looks like things are coming together nicely. If you get a chance can you give a rundown on what the supply chain logistics look like for this part? I'm interested in the technical details of how to get a part made in China as you're the only person I "know" who's done it on a small scale like this. If you would prefer to PM, that's cool.
Any updates on when you will actually have initial parts in hand?
Old 09-08-2010, 03:49 PM   #265
BenGSX
Member#: 210061
Originally Posted by T WRX rawr View Post
Oooooo I found the perfect mount. BAHAHAHAHA Maybe this has been posted already...
Hahahaahahahahaahah
Gotta be a hoax. If it isn't, I demand camera's to be mounted in the vehicles it is installed in.. I wan't to witness the first person to get a face full of ipad when the airbag deploys.
BenGSX is offline   Reply With Quote
Old 09-08-2010, 03:58 PM   #266
jr4284
Member#: 192336
2006 STiPad
The last job I worked for I was a hardware designer and worked with many different fabrication houses. I still have all of that contact information. Molders, extruders, casters, rapid prototypers, finishers, 1-off shops, plastics gurus, sheet metal gurus, etc etc etc.
Once I had finished the basic design, I posted it up on here (and mp3car, and clubWRX, and iwsti), got a kinda ridiculous amount of positive feedback, so I decided to look into manufacturing it. Got in touch w/ my contacts, looked at some other molding houses, got quotes in, ball started rolling. Talked with the guys over at mp3car to potentially do the sales. Agreed in principle on how we'd proceed with the business end of things, and then I get to focus on what I do - the engineering.
Getting a part made in China is no different than going to a shop down the road to rebuild your engine. Call them up/e-mail them, provide a basic drawing package, they give you an approximate quote. If you like what they have to say, you go ahead with them, submit a detailed drawing package and usually 50% down. They spend the next few weeks designing the mold (really freakin' cool, btw), send those drawings to you for approval, and the cutting begins.
Just because it's in China is no different than if it's in the US. Shipping costs are more, and depending on what you're doing, you may need an importation license. You can learn more about that with a quick google search.
No idea on the date and I'm starting to get gunshy on making my predictions 'cause they keep slipping one after the other. I should just change my sig to "about 6 weeks."
Old 09-08-2010, 04:04 PM   #267
BenGSX
Member#: 210061
Hey, quick question...
About how much force would it take to break those retaining tabs?
I regularly launch items into my back seat via roll-ons in first gear.. I have a vent mounted I-phone holder on the drivers side defrost vent.. Managed to snap it's claws off on a bit of heavy footed acceleration..
I doubt a stock-ish car could generate that kinda force, but your target market might have a bit more "juice".
Old 09-08-2010, 04:13 PM   #268
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
OK, thanks for the info. I figured you had to have some sort of background in the industry to nail your suppliers so quickly.
I deal with China on the manufacturing plant side of things and it can be a hassle to get things done. The government requires that regulated engineering like civil/structural/electrical be done by one of their local design institutes. It adds another layer of complexity where communication lines are already thin.
Old 09-08-2010, 04:20 PM   #269
jr4284
Member#: 192336
2006 STiPad
Here's a cross section of the tab. I beefed it up for this specific reason:
Units are in mm, so that's .114" thick. It's decent, but absolutely would not take all the force on its own.
That's why we're using the iPad docking station. When/if the iPad were to fall out, the 30 pin connector in the dock actually serves as a pivot point. Since the tabs are 3.5" above that pivot, they can take a good deal of force before they yield.
While I haven't done an FEA on it (wouldn't be too hard to... maybe tomorrow), I really find it extreeeemely unlikely you'll be able to shear them on a launch.
The foam pieces on it also help... when they compress with the acceleration, that increases the impulse duration and lowers the overall peak force.
Old 09-08-2010, 04:27 PM   #270
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Did your molder send pictures of the back side of the part? If so, can you post it up?
Old 09-08-2010, 04:28 PM   #271
jr4284
Member#: 192336
2006 STiPad
Not on this email. I'll wait for them to finalize the last little changes and post all the pics when it's done. This was just a major victory and I was kinda happy, so I felt like sharing.
Old 09-08-2010, 04:47 PM   #272
BenGSX
Member#: 210061
Ah, didn't see you were planning on some foam in there. What material are you using? I could also forsee some hamfisted folks prying the ipad away while not quite clear of those tabs.
* Edit - not the foam material, the plastic.
Old 09-08-2010, 05:51 PM   #273
JPM Coachworks
Member#: 190108
2008 WRX STI
LR
I'd be curious to see what we could do about wrapping a piece like this, or even adding stitching down the sides, embroidery, etc. It looks like an excellent candidate for some Alcantara from the photos
JPM Coachworks is offline   Reply With Quote
Old 09-08-2010, 07:33 PM   #274
b00st3d
Member#: 9891
2015 RC-F
Ultra White
i was thinking the same thing! some black alcantara and red stitching!
Old 09-08-2010, 10:13 PM   #275
JPM Coachworks
Member#: 190108
2008 WRX STI
LR
Win!
