Old 05-27-2002, 11:59 PM   #1
Scooby02
Member#: 9630
Blue -Completely Stock
Question Egt Temps
What is everyone getting as far as EGT temps , on the highway at 60mph, in town, and everything else? Just installed mine yesterday and checking what everyone else is getting. By the way the Omori EGT is VERY nice!! Fast acting response from the probe and perfect match to stock gauges. Any response is greatly appreciated.
Scooby02 is offline   Reply With Quote
Old 05-28-2002, 08:55 AM   #2
Scooby02
Member#: 9630
hey look at this another BUMP
Old 05-28-2002, 10:12 AM   #3
K-WRX
Member#: 6925
2006 Cayman S
At idle, around 800F; cruising on level road at 70 mph between 1350 and 1400F. I rarely go above 1400F unless partial throttle up a long hill in 4th or 5th. When I had the stage 2 Unichip (since removed) with peak boost at 16.5, I was getting over 1600F frequently at partial throttle acceleration in the higher gears.
Note: I run 93 octane; mods: Vishnu up-pipe and M2 turbo-back, hacked intake silencer. My sensor is in the RH manifold next to the O2 sensor. BTW, I agree, the Omori gauges are great (if for no other reason than they match the other gauges) - should have been what Subaru offered in the first place.
Andrew
K-WRX is offline   Reply With Quote
Old 05-28-2002, 11:07 AM   #4
odyss3y
Member#: 13621
1550 is my max right now under the same conditions: light throttle up hill not at max boost though. everywhere else is somewhere between 900 and 1300.
mods: sti 565 cc injectors, injen intake, mrt turboback, hks evc iv @ 1.15 bar
odyss3y is offline   Reply With Quote
Old 05-28-2002, 01:37 PM   #5
Scooby02
Member#: 9630
ok yeah thats pretty much the temps I am getting, crusing on the highway im at 1400F, in town it varies, 800F at idle, I did hit 1550F (thats where the warning light is set) last night under full boost while downshifting and taking off on the highway at 80mph.
My mods- scooby sport uppipe (jet hot coated) Downpipe (jet hot coated) center forward section, and rear muffler section. I still have the stock center rear section with stock resonator in there till Rally Performance gets in the new center rear section in.
Also have AEM CAI, MBC at 16psi, Samco hoses, and knifed edged the TB and intercooler elbows, as well as took off the radiator lines on the TB for less heat.
Damn car pulls hard as hell now, but really want the center rear section in there to be 100% satisfied.
Stock EGT Temp, Oil Temp and Boost Level? mturmel Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-25-2003 02:55 AM
egt temp boysetsfire Normally Aspirated with bolt-on Forced Induction Powertrain 13 06-09-2002 12:59 PM
Safe EGT temp range and...? BruceC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-12-2001 03:13 PM
EGT Temps, a few questions STiShawn Normally Aspirated Powertrain 3 08-07-2001 05:03 AM
EGT Temps for a N?A Car?? [email protected] Technical Forum Archive 1 06-24-2000 11:21 PM
