![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#126 |
Member#: 131379
Vehicle:2003 354 ftlb@3k rpm justablue hatch |
somewhere nasioc there's a spec the hub is bad or good depending on inside diameter. sorry cannot remember where. might even be this thread.
#127 | |
Member#: 1026
Vehicle:'00 RS/WRX Stg5 '98 RS Stock |
I thought I might add this for any future reference..(I don't know why I'm posting this in a rear wheel bearing replacement thread, but there it is) |
#128 |
Member#: 354655
I have a bit of advice, it might just be my wariness about applying force through the balls for install-
There is an adapter in the HF kit that will push on the outer race but will not push on the inner race. I use this to get the bearing in to the point where the adapter bottoms on the outer part of the housing, then I remove the tool and use the old outer race cleaned up with the bearings removed to push it the rest of the way. The housing is larger than the race until after the snap ring groove, so it does not get stuck. I think some of the early second failures are from putting the install force through the balls and inner race. A trick for a stuck race on the hub is to take a stick or mig welder and run a bead on the race, it'll pop right off. Standard install info on any snap ring (it might have been said already) is to put the sharper edge against the part of the groove it holds force against, in this case towards the outside. |
| Thread Tools | |
| Display Modes | |
| comments on DIY rear wheel bearing replacement | Carbon888 | Tire & Wheel | 4 | 12-19-2006 12:58 AM |
| Anyone know a good place to get a rear wheel bearing replaced for a good price | evoq007 | New England Impreza Club Forum -- NESIC | 13 | 06-30-2006 07:22 AM |
| rear wheel bearing replacement | nosajh9 | Brakes, Steering & Suspension | 0 | 01-03-2006 02:34 PM |
| rear wheel bearing replacement | cptomes | Service & Maintenance | 8 | 01-04-2005 10:33 AM |
| Rear Wheel Bearing Replacement? | Bob O | Mid Atlantic Impreza Club -- MAIC | 8 | 06-06-2002 09:43 AM |
