Old 02-02-2010, 01:56 PM   #1
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
Default STi Solid steering column linkage > WRX rack?
ok... search, read stickies, even goofed around on the 9-2x forums... no definitive answer.
Will the solid shaft linkage for the STi work on a WRX rack-n-pinion?
Everything I read says the columns are identical. so the question is if the spline count on the STi rack is different.
Obviously the rack ratio is an improvement. But the rubber-joint versus the solid link would make a huge difference in feel.
thanks
Rob
TXwrxWagon is offline   Reply With Quote
Old 02-02-2010, 09:37 PM   #2
bluemicamatt
Member#: 220246
2007 WRX TR
i'm interested as well...
anyone?
bluemicamatt is offline   Reply With Quote
Old 02-02-2010, 09:57 PM   #3
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
afaik yes it will. i looked into one of'em a while ago, they were $180 from the dealer
romanlynch is offline   Reply With Quote
Old 02-03-2010, 01:16 PM   #4
wrxmuch?
Member#: 196486
2004 WRX
subscribed.
wrxmuch? is offline   Reply With Quote
Old 02-03-2010, 01:20 PM   #5
watkins
Member#: 179872
96 Impreza
ninja turtle green
i had the whole 06 sti steering rack installed on my 96 impreza brighton along with my sti swap.
watkins is offline   Reply With Quote
Old 02-03-2010, 01:24 PM   #6
GHK
Member#: 103886
2005 WRX
and.......? any input towards OP's questions?
GHK is offline   Reply With Quote
Old 02-03-2010, 02:50 PM   #7
romanlynch
Member#: 126684
02 wrx
well the reason i say yes is cause when i called my buddy at the dealer an asked they showed up on the same page for a 04 wrx/sti, i guess take that as a grain of salt tho
Old 02-22-2010, 10:53 AM   #8
eagle98ak
Member#: 49526
2006 20GXTR 6spd Wgn
SGM
Anybody come across the part number for this?
eagle98ak is offline   Reply With Quote
Old 02-22-2010, 04:14 PM   #9
GhostRide
Member#: 3924
I owned a Subaru
once
Just as an update for everyone, just dropped in the 05 sti rack and subframe with the sti solid connector. No issues with anything other than getting my wheel centered again.
C/N: The solid link will drop in place of the wrx rubber bushing piece. GD Body tested.
No part number but I think it is known as the STI steering coupler 04-07 sti fitment.
GhostRide is offline   Reply With Quote
Old 02-22-2010, 05:07 PM   #10
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
I just swapped this part into my WRX and I can't get my wheel perfectly centered. I'm about due for an alignment anyways though. Swapping is pretty easy and if you do it I would recommend doing steering rack bushings with it since you have to loosen the steering rack from the mounts to swap the linkage anyways.
Noah is offline   Reply With Quote
Old 02-22-2010, 05:13 PM   #11
GhostRide
Member#: 3924
I owned a Subaru
once
If you do what I did and swap rack/subframe/coupler. Might as well add the group n mounts, rack bushings, swaybar, and possibly valve cover gaskets with all the spare room.
Aligning is not that hard if you remember to loosen the top (steering wheel side) and remove the bolt from the bottom (rack side), slide the coupler up towards the steering wheel and rotate it a notch or two in the opposite direction the wheel was off. Reconnect and re-tighten. Or just go to get an alignment and tell them to sort it.
Old 02-22-2010, 05:21 PM   #12
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
I'll just get an alignment. Auto-x season isn't that far away.
Old 02-24-2010, 01:34 PM   #13
TXwrxWagon
Member#: 191557
2004 WRX Wagon
thanks all... my '04 Wagon is in the body shop & I have to replace the steering rack, 1 lower control arm, both ball joints (won't do just 1 side), & the sway bar, so I was thinking go full bore.. Sti lower arms, rack, solid shaft, new bushings, & Whiteline adj Sway to round it all out.
I am doing a sedan conversion to the front anyway, so the extra width would be a good thing.
after the workout my wagon got (semi vs me vs concrete barrier 4 times) the alignment from to to bottom is a given.
but thanks for all the input.
Rob
Old 04-28-2010, 02:55 PM   #14
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Any feedback after swapping the linkage? noticeable better response?
Old 07-15-2010, 01:40 AM   #15
fastwrx25
Member#: 126441
03 bugeye
I've been meaning to post this, and was going to do a diy thread but didn't take pics.....
but....the install is very straight foward, its pretty much the same install for steering rack bushings. If you are going to do this mod and don't have steering rack bushings yet, now would be perfect time to do.
unbolt the steering rack bushing clamps, the 4 bolts on the center jacking plate, mark position, loosen both coupler bolts.
drop the rack, slide off old rubber damper wrx coupler, install 04-07 sti steering linkage coupler. You should have someone sit in the car and hold the steering wheel in place, or use bunjee cord, tow straps. Use a towel so the straps wont leave marks on nice leather steering wheel. Nice places to mount straps are "oh shxt handles", door lock mounts on b pillar, ebake, head rest.
I had no problems sliding back in and aligning mine. I might have been off by 1 tooth but I had alignment done soon after.
cn: Good mod, worth doing. More direct and precise steering, less wobble and vague-ness. I also feel there is less "kick back"in the steering wheel, also less dead center feeling
I don't know the part number or how much the price but I got mine cheap for ~35 shipped in the classifieds awhile ago and finally installed in cpl months ago.
If you guys can get this at a decent price i think you guys should try it. I felt much more from this mod compared to steering rack bushings.
fastwrx25 is offline   Reply With Quote
Old 07-15-2010, 09:42 AM   #16
bzbuzz
Member#: 116052
2011 STI ( Sold )
hmm very interesting..let's keep hearing more inputs...
bzbuzz is offline   Reply With Quote
Old 10-12-2010, 10:31 AM   #17
notallama
Member#: 248996
bring back from the dead
i'm looking at 04 diagrams compared to GC and trying to use google but i cant figure out what part exactly you guys are talking about.
can someone link a part number of photo?
notallama is offline   Reply With Quote
Old 10-12-2010, 05:20 PM   #18
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
It looks like this. The car in the pic is actually a Legacy GT, but this is a good shot and it's the same on a WRX.
EDIT: The coupler in this picture is the one WRX owners would want to upgrade to, I posted the crappy stock WRX one below.
Dentt42 is offline   Reply With Quote
Old 10-12-2010, 08:32 PM   #19
notallama
Member#: 248996
i'm curious about the OP comment of "solid" vs "rubber", i havent paid much attention to my own steering linkage but i'm surprised that there are any rubber components to it.
Old 10-12-2010, 09:20 PM   #20
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
The one for the STi has a solid steel shaft between the U-joints like a small driveshaft, the WRX piece has rubber bushings in it to dampen vibration.
Edit: While I was looking for a part number I did find a pic of the one on a WRX.
Old 10-12-2010, 10:43 PM   #21
notallama
Member#: 248996
wow
i dont have that! (01 RS), guess i should feel lucky
Old 10-12-2010, 10:57 PM   #22
mongoosaroo
Member#: 115056
2002 psm now w/ 2.5
jesus tuned my hot rod
i've had an 04' in my 02' for 2 years. w/your 06 i believe any sti rack 05+ will work.
mongoosaroo is offline   Reply With Quote
Old 10-12-2010, 11:22 PM   #23
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
I'm under the impression that the bottom plate of the WRX plastic coupling is one solid metal disc.
Be this the case, the only purpose of the coupling is to dampen motion up and down (axialy).
This is what I thought I saw when I installed my qrack. I was gearing up to find a solid coupling at the time.
Old 10-12-2010, 11:40 PM   #24
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I just looked up the part number for this. For the 05-07 STi, the listed part number is 34170FE050. However, the drawing doesn't draw that coupler any different than the RS or WRX one. Considering how half-assed some of these drawings are, though, that doesn't mean much. Someone needs to order one of that part number and see what shows up.
Also, does this have any impact on the steering column's ability to collapse during a crash?
Old 10-13-2010, 03:02 AM   #25
fastwrx25
Member#: 126441
03 bugeye
I did this swap, I think you guys should also try it. I'm curious to see if you guys like it and can feel a difference.
I've had my sti coupler on for 15k miles. steering feels more direct, less wobble, and less dead spot in the middle.
if anything I think I feel more of a diff with this vs steering rack bushings which I was not too impressed with.
Sti solid steering linkage Vlad Private 'Wanted' Classifieds 0 05-05-2010 10:08 PM
FS Wa: Sti solid steering linkage wrxwagon253 Suspension/Brakes/Handling 9 01-07-2010 10:56 PM
bottom peice for steering column 02-03 wrx jeremywrx15554 Interior/Dressup/Audio & Security 4 12-12-2009 04:17 AM
For Sale 2007 STI ECU, steering column and engine and dash wiring harness syoung0298 Engine/Power/Exhaust 0 11-24-2007 10:12 AM
FS: upper steering column trim 02 wrx LoooseboySTI Interior/Dressup/Audio & Security 7 11-13-2006 05:37 PM
