Old 02-02-2010, 06:20 PM   #1
Foxhound
Member#: 170336
06 Impreza 2.5i
CGM
Default NGK Spark Plug Question!?
Hey fellas, I have searched around and figured out that the general population on this forum says to double check your gap on pre-gapped spark plugs. Well, I want to purchase a pre-gapped NGK FR5AP-11 and wanted to confirm whether or not this matches EXACTLY with our engine specs (I drive a 4eat 06 2.5i, auto I know). The manual tells me that this is the exact OEM Model # and I was curious if I will need to make any modifications before the install.
Thanks ahead of time!
Foxhound is offline   Reply With Quote
Old 02-02-2010, 06:28 PM   #2
dr3w
Member#: 222318
1993 RHD GC8
Always recheck your gap.. it takes all of 5 seconds and zero skill.
dr3w is offline   Reply With Quote
Old 02-02-2010, 07:02 PM   #3
Foxhound
Member#: 170336
06 Impreza 2.5i
CGM
What is the gap for my car's application? I think the -11 at the end of FR5AP-11 indicates that it is 1.1mm, or in other words .43-.44''. Is this the gap I want?
Old 02-02-2010, 08:51 PM   #4
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
FR5AP-10's are actually what the 06+ requires. the owners manual is F'ed, kinda. it specifies a gap that contradicts with the gap of the plug that they specify by P/N. The -10's have the correct gap and will stay in the acceptable range longer than the -11's because they start right on spec and grown instead of starting just high of spec and getting worse as they wear.
Chk it out
RaceFaceXC is offline   Reply With Quote
Old 02-02-2010, 09:58 PM   #5
Foxhound
Member#: 170336
06 Impreza 2.5i
CGM
Thanks a mill! Good to know this kinda stuff PRIOR to installing rather than AFTER
Old 02-02-2010, 11:25 PM   #6
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
haha, anytime! thats what NASIOC is here for... amongst other things. But, like you guessed, you should always chk the gap before installing and on iridium/plat plugs regapping is very risky because the cathode is just coated or plated with platinum/iridium and even a scuffing with a gapping tol can damage it. If you have to re-gap, only touch the anode (the finger that reaches from the top if the threaded barrel to over the center electrode and dont touch the electrode that is inside the center of the ceramic insulator). even using feeler gauges can scuff the center electrode that is coated with the soft platinum/iridium, so be super careful when measuring gap.
NGK Spark Plug & meth injectrion question. TypeOne Service & Maintenance 13 01-29-2009 04:54 PM
FS 4 NGK Spark Plugs - Stock STi plugs, PN# 22401AA630 joe-6STi TXIC Private Classifieds 6 06-07-2008 12:04 PM
FS: Houston : 4 NGK Spark Plugs - Stock STi plugs, PN# 22401AA630 joe-6STi Engine/Power/Exhaust 4 04-25-2008 05:32 AM
Spark Plug Question NGK BCPR7EIX drkwtsn Service & Maintenance 2 01-19-2005 10:09 PM
NGK Spark Plug Wires subarumantoo General Forum Archive 1 01-11-2001 12:43 AM
Message Board Statistics All times are GMT -4. The time now is 04:38 PM.
