Old 02-02-2010, 08:35 PM   #1
white02_WRX
Member#: 186087
PPG & ewg FP td06 20g
Default MY20G Bugeye Build Thread
Hello NASIOC!! I just got a new WRX, I had an Aspen white 02 for 2 years up until october of 08 when I had to sell it due to financial problems
Sorted everything out, waited and found a sweeet car for an amazing deal, a blue 2002 WRX 5spd with 147000kms on it and lots of mods.
In the future Im thinking built block and a jdm gearbox for when mine turns to mush..
This Thread is going to get BIG! and I know Ill have to post up some pics asap! But for now heres a mod list
FP 20g Turbo setup
Tial 44mm WG w/dumptube
TurboXS full catted stealthback exhaust and Uppipe
large Topmount IC painted black
spec C TGVless intake manifold
Greddy unequal headers painted with a sealer wrapped then painted again
785cc UR injectors w/module
Ported throttlebody
HKS SSQV BOV
Silicone inlet hose
AEM CAI
GM boost solenoid
Tuned by NEETRONICS in Oakville to run on 94oc but tuned a little light to 285-290whp
Timing, tensioner, pulley done 2 years ago w/ water pump , thermostat w/ full engine flush
light crank pulley and mount behind IC
Fuel system flushed w/ new fuel filter
brake system flushed
NGK iridium plugs fresh & newer coils
DK rust module
newer alternator
brand new gel battery
Xact ultralite flywheel
ACT stage 2 clutch w/shockproof koolaid mix
Brand new shifter bushings and new TWM SS and knob
Klunk killer bushing kit and all bushing around
Diff fluid changed with shockproof koolaid mix and mounts upgraded
Stainless clutch line
KYB AGX all around with SPT springs
Ladder brace underneath
new pitch mounts front and back
Brakes done 2 years ago and new rotors for rears ready to go w/ Cross drilled coated and painted black
Stainless brake lines and flushed brake fluid
Rota lightweight wheels w/Pzero's on them (1 season left) rims in great shape
toyo winters on stock gold painted 16s
Custom cluster w/LED's blue and white
Carbon fiber dash pod
cluster pod holder painted blue
4 Prosport blue gauges, (boost, Exhaust temp, A/F, Coolant temp) coolant temp needs adapter for top of rad hose though
Apexi Turbo timer
blacked out the headlights
newer front grill
SEIBON CF hood and trunk w/CF STi scoop
white02_WRX is offline   Reply With Quote
Old 02-02-2010, 08:36 PM   #2
white02_WRX
Member#: 186087
Totally just posted in the performance 2L category for some odd reason... whatever lol
Old 02-02-2010, 11:44 PM   #3
El Guapo
Member#: 234937
2004 STi
20G'd Blue
whats a DK rust module?
Are all these parts in hand or a wish list? Good luck on the build
El Guapo is offline   Reply With Quote
Old 02-03-2010, 03:00 PM   #4
white02_WRX
Member#: 186087
dk rust module is a negative charge sending device which is wired up to the body and frame where is helps fight against corrosion. I live in southern ontario.. the weather can get pretty bad, they spread salt night and day here.
I DID however say i just bought this car already modded?!
Old 02-03-2010, 03:05 PM   #5
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
285-290whp on a 20g? whats the point.
happs subi is offline   Reply With Quote
Old 02-03-2010, 04:06 PM   #6
white02_WRX
Member#: 186087
Build the block and then up the boost.
Old 02-03-2010, 07:36 PM   #7
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Not to be a jerk, but how is it a "build" if you bought it already done?
Maybe you could bump his build thread?
CKxx is offline   Reply With Quote
Old 02-03-2010, 07:45 PM   #8
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
what is a Model year 20g?
build the block already.
greenspeed is offline   Reply With Quote
Old 02-03-2010, 10:19 PM   #9
white02_WRX
Member#: 186087
well its got stock internals and stock gearset. ugly grille I dont like and quite a few other things Ill be changing and upgrading, so yes it is a build Im just starting where the last owner finished and making it my own.
Old 02-03-2010, 10:37 PM   #10
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
build thread... with no build or pics
please remove spec c from your member info, too. more misrepresentation.
LatentWagen is offline   Reply With Quote
Old 02-04-2010, 05:11 PM   #11
white02_WRX
Member#: 186087
Im quite proud of my tgvless SpecC i.m. so, No. I would have also put in GReddy unequal but it wont fit lol
Ill post pics soon, dont be jealous I paid less than what the parts are worth for my car lol
Old 02-04-2010, 06:07 PM   #12
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
nobody runs tgv's anymore, they were so 1990
Old 02-04-2010, 07:03 PM   #13
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
Up the booooost!
Honest Bob is offline   Reply With Quote
Old 02-04-2010, 08:02 PM   #14
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
this thread belongs in noob section
AWDWRXLOVER is offline   Reply With Quote
My GT3076R Bugeye Build... CKxx Member's Car Gallery 166 08-24-2010 02:24 AM
WI Bugeye build thread/my first 'motor build' CrashTest Mid West Subaru Owners Club Forum -- MWSOC 1 05-11-2010 11:00 PM
bugeye build.. Pike Alaskan Impreza Club Forum -- AKIC 55 04-03-2009 06:07 PM
Wh'appen to Tai Chih left the building thread? blaster88 Mid Atlantic Impreza Club -- MAIC 12 11-09-2001 04:26 PM
