Old 05-25-2002, 04:03 PM   #1
Tensecgn
Member#: 2102
Default ecu programming
looking for some info on programming my own chip for a subaru.
Does anyone have any info on doing that.
Tony
Tensecgn is offline   Reply With Quote
Old 05-25-2002, 05:04 PM   #2
Gerry
Member#: 1829
First..your going to need a rom reader. You will also need a map for your car. Also depending on what kind of car you have you will have to de-solder the ROM off of the ecu.The maps are a series of zeros and ones..Also it can't be done with the new WRX "yet"....Gerry
Gerry is offline   Reply With Quote
Old 05-25-2002, 06:05 PM   #3
Tensecgn
Member#: 2102
I`m still working on the 94 impreza with the full throttle bog problem.I think the problem is in the ecu with the programing.
I read somwhere that the ecu will retard the timing at full throttle due to no knock sensor on the 1.8L.So I`m thinking of tinkering
with the chip side of things.
Is there a special binary code to read the maps.
Tony
Old 05-25-2002, 09:51 PM   #4
Gerry
Member#: 1829
Yes Tony there is. I'm not sure what the code id for a 1.8 though..If you wanted I have the maps for STI V5 and others..Did you try changing your ECU?..Gerry
Old 05-25-2002, 11:48 PM   #5
Tensecgn
Member#: 2102
That is next on tuesday.
I talked it over with my partner and we are going junkyard hunting for a 2.2l legacy harness and ecu.
Will be swapping the whole think over.
Import shootout is next Saturday and I need to get this project
running correctly.
Gerry if you could guild me on how to remapp the ecu that would be very helpful.
Tony
Old 05-28-2002, 07:18 PM   #6
milkman
Member#: 8066
Y2K RSt
Sedona Mars Red Pearl
Default WOW
Wow, that's so wow. I wish I was as smart as you guys. Could you guys build me a chip adapter and a EZ windows based program so people who aren't so cranial endowed could pretend they could reprogram there own ECU?
milkman is offline   Reply With Quote
03 ecu w/ ecutec flash and easy ecu program 123mara Engine/Power/Exhaust 25 01-04-2009 11:29 AM
Ecu programming language? ges311 Engine Management & Tuning 15 02-13-2003 02:10 PM
Interesting - Cobb Tuning ECU Programming nickgomez Texas Impreza Club Forum -- TXIC 15 12-17-2002 09:57 AM
ECU Programming rally_wannabe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 09-11-2002 04:42 PM
Japanese Automotive ECU programming john wilfley Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 05-07-2002 12:48 PM
