Old 02-02-2010, 10:46 PM   #1
Geoff
Warden of NASIOC Timeout
Super Moderator
Member#: 592
'08 X3 3.0si 6MT
'03 330xi 6MT & '08 STi
Default 2004 FXT, FP68HTA, E85, PDXTuned
Thanks to Jarrad of PDXTuning for the work on my Forester, Johnny Tran at JTran Studios in Houston for strapping down the car for a dyno, and Gillman Subaru SW for doing the tranny work and maintenance There's likely more in the car, but I wanted to keep it at 21psi. Car drives great.
Car: 2004 Forester XT
Turbo: Forced Performance 68HTA
Downpipe/exhaust: TurboXS Stealthback & JDM Pink STi Axleback
Boost Control: Grimmspeed EBCS (Thanks, guys!)
Injectors: DW 850s
TMIC: 2005 STi
Fuel: E85
Oil: Royal Purple 15w40
Dyno Type: Mustang 500
Pull info: 2007 STi 6-speed, center diff locked, 3rd gear
WHP: 324
FT-LBS: 316
Boost Target: 21psi
Geoff is offline   Reply With Quote
Old 02-02-2010, 10:50 PM   #2
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
It must feel good, but why so conservative? Nice setup...
juanmedina is online now   Reply With Quote
Old 02-02-2010, 10:57 PM   #3
Geoff
Super Moderator
Member#: 592
'08 X3 3.0si 6MT
It's my daily driver, and the car drives excellently. Didn't feel the need to add aftermarket boost control to go over 21psi.
Old 02-02-2010, 11:02 PM   #4
juanmedina
Member#: 133146
07 FPgreen 7.37@95
you have a Grimmspeed EBCS??
Old 02-02-2010, 11:04 PM   #5
Geoff
Super Moderator
Member#: 592
'08 X3 3.0si 6MT
Yes. The EBCS is still limited by the ECU's ability to read no greater than 21psi. I'd need an MBC to switch between 21 for pump and 24 for E85. I don't feel like running a piggyback ECU either.
Old 02-02-2010, 11:14 PM   #6
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
do you have any plans to upgrade the tmic in the future? also seems a little laggy for a 68? as long as she drives good on the street - who cares!
wrxtremeWGN is offline   Reply With Quote
Old 02-02-2010, 11:15 PM   #7
juanmedina
Member#: 133146
07 FPgreen 7.37@95
I didn't know that, I always had a MBC
So how is this car boosting 24.5psi on stock EBCs? is it because of the pill?
http://forums.nasioc.com/forums/show....php?t=1924123
Old 02-02-2010, 11:18 PM   #8
Geoff
Super Moderator
Member#: 592
'08 X3 3.0si 6MT
Not laggy at all, in every day driving. I'm running the stock headers though. Might do those later to open up breathing a bit more.
Old 02-02-2010, 11:19 PM   #9
Geoff
Super Moderator
Member#: 592
'08 X3 3.0si 6MT
From what I gather, he can't be using the ECU to control boost, or he's doing something else. I'm not knowledgeable enough on boost control to say more than that.
Old 02-02-2010, 11:23 PM   #10
vinnyd
Member#: 148219
ex FXT. 6spd, IAG
built, 35r Jorge tuned
yay!!!!, fast red forester excite me. now u need more intercooler and boost and u will be more happier. why spend all that cash on the 6 speed to leave so much on the table
vinnyd is offline   Reply With Quote
Old 02-02-2010, 11:27 PM   #11
modaddict
Member#: 95840
sold to a good bud
awaiting next car
I use the stock boost control solenoid at 25-30psi on my 35r with my Ecutek stock ECU. It's magic though.
I take it Jarrad was in Texas on a tuning trip?
modaddict is offline   Reply With Quote
Old 02-02-2010, 11:35 PM   #12
Geoff
Super Moderator
Member#: 592
'08 X3 3.0si 6MT
Because I bought the 6-speed as much for handling as I did for strength. I'm not in a number competition with anyone, and I'm happy with how the car runs, and I'll be keeping it for awhile. Brembos, exhaust header, and done.
Old 02-02-2010, 11:35 PM   #13
Geoff
Super Moderator
Member#: 592
'08 X3 3.0si 6MT
Yep, he makes it down here periodically.
Old 02-02-2010, 11:52 PM   #14
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Whats the IDC of the injectors?
Old 02-02-2010, 11:59 PM   #15
Geoff
Super Moderator
Member#: 592
'08 X3 3.0si 6MT
~80 percent
Old 02-03-2010, 09:07 AM   #16
vinnyd
Member#: 148219
ex FXT. 6spd, IAG
which header are you going to go with? IWG or EWG? and why was my post edited?
Old 02-03-2010, 09:21 AM   #17
captain spaulding
Member#: 104639
'06 WRX Wagon
Red
This dude was strapping your car down?
Sorry couldn't resist..
Nice numbers btw, interested to see what I can get w/new injectors on basically the same setup (I did 336whp on 93oct w/stock injectors on dyno dynamics dyno)
captain spaulding is offline   Reply With Quote
Old 02-03-2010, 09:28 AM   #18
Geoff
Super Moderator
Member#: 592
'08 X3 3.0si 6MT
Mod mistake. Hit edit instead of quote. They're right by eachother.
Going with a Perrin, IWG.
Old 02-03-2010, 09:35 AM   #19
vinnyd
Member#: 148219
ex FXT. 6spd, IAG
sounds like a plan, you gonna do a retune after the header?
Old 02-03-2010, 10:14 AM   #20
Geoff
Super Moderator
Member#: 592
'08 X3 3.0si 6MT
If necessary. We'll put the wideband on it and run it, to see what it does, and make adjustments where necessary. The tune's conservative enough that it may take the header without any modifications...we'll see.
Old 02-03-2010, 05:01 PM   #21
CatfaceType-R
Member#: 81102
Not laggy at all, in every day driving. I'm running the stock headers though. Might do headers to change the power more to the right
fikksd
CatfaceType-R is offline   Reply With Quote
Old 02-03-2010, 05:06 PM   #22
SkateAndDestroy
Member#: 133893
2004 JBP Lesbian XT
68HTA 12.20@113
Unless I missed it, your still on stock airbox?
Not bad considering stock airbox, XT exhaust manifold, STI TMIC, and STI catback...our exhaust manifold is a bit more restrictive than the STI one too...
SkateAndDestroy is offline   Reply With Quote
Old 02-03-2010, 05:22 PM   #23
Geoff
Super Moderator
Member#: 592
'08 X3 3.0si 6MT
Actually, the power band will be improved on the bottom-end as well. Consulted with PDXTuning before considering it. Don't fix what's right, plskthx.
Originally Posted by soon2bblackongold View Post
fikksd
Old 02-03-2010, 05:24 PM   #24
Geoff
Super Moderator
Member#: 592
'08 X3 3.0si 6MT
Yup, running the stock airbox, though it's not an STI cat back. It's a TXS Stealthback with a JDM Pink Forester STi axleback.
The Perrin wrapped headers that I'm picking up from PDX should give me a bit more torque across the board. Contrary to popular belief, in this scenario with my setup, I won't be giving up any low-end power.
Old 02-03-2010, 05:53 PM   #25
Airelpaso
Member#: 139566
2004 Forester XT
Gold
Nice! Pics of the car please!
Airelpaso is offline   Reply With Quote
08 Fxt + 20g + E85 modliving Proven Power Bragging 34 11-12-2010 09:28 PM
2004 FXT Front Tophat=2004 STi Tophat? kharris4 Brakes, Steering & Suspension 1 02-04-2010 02:08 AM
08 Fxt+vf48+e85 modliving Proven Power Bragging 18 06-08-2009 12:34 AM
2004 FXT-funny smell, strange whine, maybe you need a rear diff? wadejg Forester Forum 9 03-24-2004 02:06 PM
2004 FXT stock wheels and tires for sale wadejg Forester Forum 2 03-09-2004 07:49 AM
Message Board Statistics All times are GMT -4. The time now is 05:52 AM.
