Old 04-20-2010, 07:23 PM   #1
saabaru_aero
Member#: 238937
05 Saab 9-2x
black
Default sedan sways and endlinks on a wagon?
buddy of mine totaled his car and sold it to me he had a set of whiteline swaybars and endlinks on his car i want to put them on my car only problem is he had a sedan and i have a wagon any way to mod them to work or should i just get rid of them
saabaru_aero is offline   Reply With Quote
Old 04-20-2010, 07:39 PM   #2
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Use his control arms too.
bushflyr is offline   Reply With Quote
Old 04-20-2010, 07:46 PM   #3
saabaru_aero
Member#: 238937
05 Saab 9-2x
black
thanks
Old 04-20-2010, 08:08 PM   #4
saabaru_aero
Member#: 238937
05 Saab 9-2x
black
this should definitely make the endlinks fit but will the sways also fit and will this cause any other problems just wondering why they used diff control arms to begin with
Old 04-20-2010, 08:26 PM   #5
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
The sedan has a wider track than the wagon, thus the difference in the control arms.
Sedan swaybars will fit a wagon. There is no difference in the rear. Up front, the only difference between a wagon bar and a sedan bar is that the sedan bar is flared out slightly at the ends. That's it. How do I know? We installed my old 24mm Whiteline sedan bar into my friend's wagon.
You may or may not need the spacers up front if you're using Kartboy endlinks. The KB spacers are $4 for four from KB http://www2.kartboy.com/x4/product.p...cat=253&page=4
Are the Whiteline endlinks fixed or have spherical ends? I know that if you use Kartboy endlinks you have to have the ones for a wagon for the front bar. The mounting cup on the control arm will not accomodate the sedan endlink.
Old 04-21-2010, 10:18 AM   #6
Boxer4Dad
Member#: 137226
2005 Saabaru 2.5i
OBP, or Black
If you use Sedan control arms, you can use sedan endlinks and a sedan bar. That's what's been on my Saabaru for a couple of years now, and it's all good. If you don't use the sedan arms, then you need to somehow compensate for the narrower track of the wagon and wider sedan bar. We're all kind of saying the same thing, but it DOES depend on which pieces you have and can use.
Boxer4Dad is offline   Reply With Quote
Old 04-21-2010, 10:41 AM   #7
saabaru_aero
Member#: 238937
05 Saab 9-2x
black
Thanks for the help luckily nobody has bought the control arms yet ill will definitely be trying this this weekend
Old 05-09-2010, 02:32 PM   #8
saabaru_aero
Member#: 238937
05 Saab 9-2x
black
got it to work but it threw my alignment off badly it made the wheels point inward i was able to fix this by adjusting the tierods its not perfect but atleast i can get it to a shop thanks for the help
Old 05-10-2010, 07:57 AM   #9
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
Thats normal when going from wagon track to the sedan track.
Honest Bob is offline   Reply With Quote
Old 05-10-2010, 08:09 AM   #10
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Yep, normal. It works out to 9* of toe, in fact.
I had to drive (very slowly) a 1/4 mile like that, because i couldn't loosen my tie rods. My shoulder would fall out every time i tried. Cars don't handle well with that much toe.
sniper1rfa is offline   Reply With Quote
Old 05-11-2010, 12:13 AM   #11
silvervagon
Member#: 110015
2002 WRX wagon
I also have an '02 wagon and a Whiteline sedan 24mm fsb, with Kartboy solid endlinks, and the swaybar hits the lower control arms unless it's exactly centered. Was wondering if longer endlinks would move it far enough away, or if maybe just adding some rubber hose/ hoseclamps to keep it centered would work.
On the sedan control arm option - anyone have any issues with tire rub after the swap?
Thanks!
silvervagon is offline   Reply With Quote
Old 05-14-2010, 12:51 AM   #12
silvervagon
Member#: 110015
2002 WRX wagon
Swapped the Kartboys out for the stock endlinks, and the clunking is gone. Anyone know why Kartboys would be 1/4" shorter? That's just enough to move the swaybar into contact with the control arms, unfortunately.
Old 05-14-2010, 01:04 AM   #13
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
I used the string method to fix up toe/thrust angle many times with relative accuracy/ease and did it better than most alignment shops. When you tell them to get exactly zero, they still do a halfway job and get it semi-green screened.
As for the stuck tie rods, long wrench or crowfoot on a breaker bar + rubber mallet does lots of good. You can also try heat and PB blaster, but for me it wasn't necessary.
This is on a Chicago car that has been here since bought new from the dealership. Lots of rust.
formula91 is offline   Reply With Quote
Old 05-14-2010, 09:51 AM   #14
Boxer4Dad
Member#: 137226
2005 Saabaru 2.5i
OBP, or Black
Are the KBs for Sedan or wagon? They should match whatever control arms you have. You haven't provided any details here...
Old 05-14-2010, 11:23 AM   #15
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
Thanks!
We did the swap on my friend's 2002 WRX wagon. He has 17"x7.5" 48ET wheels and 225/45-17 tires and there is still enough space to clear the front fender. The car is lowered on a set of 2006 STI springs w/Tokiko D-Spec struts.
With this set-up of lowering however there is a rubbing issue at the back. We're going to have to roll the fenders for about 30-degrees on the center-line to effectively eliminate the rubbing issue.
Old 05-14-2010, 02:52 PM   #16
silvervagon
Member#: 110015
2002 WRX wagon
I bought them new via the classifieds here from a private owner, and was told they're for a wagon. Are the sedan endlinks shorter?
Old 05-14-2010, 02:55 PM   #17
silvervagon
Member#: 110015
2002 WRX wagon
Good info, thanks. I'm on Swift sport springs w/ D-Specs and '06 wrx 17's, which I believe are 17x7 with 225/45-17's, no rubbing thus far.
Old 05-14-2010, 03:20 PM   #18
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
The 2006-2007 OEM WRX wheels are 17x7 55ET, so they're 'more inside' the wheel-well.
Old 05-14-2010, 08:11 PM   #19
jdmboy
Member#: 240161
2002 wrx wagon R.I.P
87 bmw e30
wouldnt you need axles too?
jdmboy is offline   Reply With Quote
Old 05-15-2010, 06:24 AM   #20
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
You can get away with wagon axles, it supposedly shortens their life span.
WTB Sway bar 20mm bushings and endlinks 02 WRX Wagon DeathKing Private 'Wanted' Classifieds 0 06-08-2009 03:54 PM
WTB: 04-05 tails, WRX sedan LCAs, rear sway and endlinks racerpat94 Private 'Wanted' Classifieds 10 06-05-2009 06:35 PM
Wagon (2004) stock struts, springs, sways and endlinks MikeCee Suspension/Brakes/Handling 18 05-15-2007 10:07 PM
FS: Stock '02 WRX Wagon Sways and Endlinks brendan_mac VIC Private Classifieds 5 04-19-2007 10:44 AM
2006 Sedan Front Endlinks on 2004 Wagon jjbehren Brakes, Steering & Suspension 5 04-04-2007 10:29 PM
