Old 02-17-2010, 12:40 PM   #326
STi-MAN
Member#: 70252
05 STI
blue
^arnie i'm on the same page as you as well.
STi-MAN is offline   Reply With Quote
Old 02-17-2010, 01:14 PM   #327
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
You should also note that the dedicated race cars like that ALMS Porsche using low travel set-ups likely do not use the same set-up at a bumpy track like Sebring. Their set-ups are very track dependent and not a one size fits all approach like most of us are stuck with.
- andrew
AndyRoo is offline   Reply With Quote
Old 02-17-2010, 01:45 PM   #328
STi-MAN
Member#: 70252
05 STI
blue
^which is, exactly my point. they must use a low travel setup for certain tracks because there is a need for it.. if massive amount of travel was so important for all situations.. they would use the same setup for sebring as toronto where that picture was taken.
I'd still like to see the longer travel struts which you speak about tho... have a link?
Old 02-17-2010, 01:52 PM   #329
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Consider with those professional race cars, though, that even the Porsche is using significant amounts of downforce. While, by professional racing standards, they don't have much aero, they still have enough sensitivity to height off the ground that even a small amount of change in ride height or especially a small change in pitch can affect the car terribly. They may find that it's more important to reduce total travel and suffer the mechanical loss of grip from bottoming out or coming off the tarmac than it is to suffer a ballistic interlude at the conclusion of which they relieve themselves of excess velocity via an ablative technique because the car had enough travel to pitch up a degree.
It's all tradeoffs. It's just better to start from a condition of excess travel and limit it to make compromises for other systems than it is to have too little travel and not be able to do anything about it.
Old 02-17-2010, 08:30 PM   #330
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
I'm wondering if droop coincides with spring rate in creating a damper. When spring rates get over 500 lbs, you tend to not see as much droop even on expensive setups. Conversely on a soft sprung setup you tend see a lot. Wouldn't stiff springs have to have a lot of preload, so when they unspring (I just made that up) the springs don't rattle around? I'm sure the Forumla SAE team can help me out on this one.
rjrutzky is offline   Reply With Quote
Old 02-17-2010, 10:29 PM   #331
Daishi00
Member#: 78952
2005 WRX
CGM
Depends on if they have helper springs or not. I know my T2's will handle 600lb springs but that's pretty much at the top end limit of the damper and I still have ok travel (not as much as AST but more than any of the cheapo coilovers).
Andrew made a good point about track specific setups. An uber smooth track won't require nearly as much travel as some of the more bumpy track (Sebring to steal Andrews example again). For the street though...the more travel the better.
Daishi00 is offline   Reply With Quote
Old 02-18-2010, 02:27 AM   #332
STi-MAN
Member#: 70252
05 STI
blue
Yes this is what me and Arnie have been sort of thinking the whole time.. the right tool for the right job.
also seeing some picture of the porsche alms car pitted at sebring.. not much more travel noticeable. I'm thinking travel is the same just damper changes and maybe spring changes.
Old 02-18-2010, 02:53 AM   #333
jamal
Member#: 71875
98 Legacy GT
my wheels fit
a stiffer spring will be compressed less at ride height, so there will be less droop. You end up where your droop is almost entirely taken up by the helper or the spring unseating. And adding pre-load will reduce droop travel.
jamal is offline   Reply With Quote
Old 02-18-2010, 06:21 AM   #334
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
I'm curious if T2s with 600lb springs actually have more droop than cheapos like say Teins or BCs with the same spring rate. How much more droop? Sounds like the spring rate impacts droop more than the coilovers. DO the coilovers have much say in the matter at all?
Old 02-18-2010, 07:48 AM   #335
Daishi00
Member#: 78952
2005 WRX
CGM
Most of us have been saying the right tool for the right job just not as eloquently. Spring rates will change at a place like Sebring so droop levels will change as well. I've heard them talk about suspension travel during the 12hrs before and about how it's such a PITA at that track due to the low ride heights and the insane bumpiness as tracks go.
I'd be shocked if they didn't. I'm at 500lb springs in the front and have quite a bit of droop travel just from the helper spring alone not to mention when the spring uncompresses. boost junkie is the only one I know of that's run 600lb springs on the KW's. He did that part of last season before switching to JRZ's.
Old 02-18-2010, 07:51 AM   #336
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
First of all, your question makes no sense as written. "The coilovers" includes the spring. However, I'm going to assume you're mis-speaking and you mean the dampers or struts, rather than the coilovers. Yes, the damper sets the total droop travel from ride height. It's also one of two things that can set the total bump travel from ride height. The droop of a coilover is always the compression of the main spring at ride height plus the total travel of the helper spring. That's why it's impossible to create a coilover with adequate droop travel and a high spring rate without using a helper spring. The damper also can set total bump travel if the damper piston bottoms out before the main spring is compressed to its solid height.
Old 02-18-2010, 09:59 AM   #337
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
its not impossible, it just requires a rate differential greater than what is commonly available on progressive rate springs. In which we at this point have only thought about linear rates from what I can tell. But eliminating the helper spring doesnt yeild much either so thats why its probably not been done to commercial sucess. Then again, lets look at a highly progressive suspension system that is air sprung.. I like air springs. They work awesome! They are applied to mtn bikes, snowmobiles, fourwheelers, dune buggy, etc etc. Why has no one created an air strut? Not talking about airbags here either.
We can choose between open bath like Marvin Shaw shocks, or closed like a Fox float. Open bath gets you a little more volume/stroke = a little more droop when compared to the same pressures as a sealed valve body airsleeve like the float. ie 60 psi in the float yields oh so roughly 180lb spring and currently they can handle 150ish psi. Where as the MSS can run up to 800 psi i think.
http://www.marvinshawshocks.com/
Just imagine.. we have used these extensively in snowmobile racing and every feature abou tthe shocks performance can be adjusted. They even use nitrogen to fill up to resist STP deviations.
Dubstar112 is offline   Reply With Quote
Old 02-18-2010, 10:48 AM   #338
Sk8er
Member#: 129045
2004 Subaru WRX Sti
Tein is the way to go.
Sk8er is offline   Reply With Quote
Old 02-18-2010, 10:59 AM   #339
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
While I value your opinion, and I recognize your right to have your own opinion I must respectfully disagree.
Old 02-18-2010, 12:34 PM   #340
cessna152
Member#: 7523
1999 Impreza 2.5 RS
Gutted and custom revalved Tein bodies are the way to go.
cessna152 is offline   Reply With Quote
Old 02-18-2010, 12:58 PM   #341
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
How does this contribute anything to the discussion?
Old 02-18-2010, 01:12 PM   #342
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Because we all know TEIN is teh shizzle fo hizzle!
Arnie is offline   Reply With Quote
Old 02-18-2010, 01:14 PM   #343
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
No way bro, TEIN is just another Megan wannabe.
Old 02-18-2010, 01:17 PM   #344
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Ouch!
Old 02-18-2010, 01:19 PM   #345
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
But I can't bash too much on Tein, I have a set of Basics on my Festiva. Only things made that will fit.
These actually have more droop than the original post by TIC.
Old 02-18-2010, 01:20 PM   #346
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
nothing like a tein shout out to kill a thread.
edit: need more pics arnie!
Old 02-18-2010, 01:21 PM   #347
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Dude, someone needs to pay you better if you can't afford wheel studs
Old 02-18-2010, 01:22 PM   #348
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Got a raise!
BTW, that red painted caliper added a buttdyno proven 5hp. Just need to put my TEIN stickers on the car for an added 10hp.
Old 02-18-2010, 01:25 PM   #349
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
What the hell, since we are taking a bit of a commercial break for our sponsors:
Fetus Mobile Racing
Apologies for the completely off topic random image posting guys!
Old 02-18-2010, 01:29 PM   #350
Blown95ImpalaSS
Member#: 87629
me want that festiva...my neighbor has a disassembled EDM turbo escort block...mmm
what will its motorsport of choice be arnie?
Blown95ImpalaSS is offline   Reply With Quote
GC Kit and droop jeisen Brakes, Steering & Suspension 7 02-15-2010 08:18 AM
back to stock sale coilovers and other parts cheap mrguppy MAIC Private Classifieds 14 10-13-2008 02:46 PM
Springing options for coilovers - attacking stroke and droop travel Scooby921 Brakes, Steering & Suspension 7 05-10-2007 11:41 AM
FS: Brand New Coilovers and Shocks Cheap! wildchild Private 'For Sale' Classifieds 2 08-01-2004 07:46 PM
Cheap coilover kits on eBay B-Kerr Brakes, Steering & Suspension 11 05-31-2003 12:40 AM
