Old 02-11-2010, 01:21 PM   #201
antonch
Member#: 170384
2006 Sti
Tracks times are by far more dependent on the skill of the driver. Driver skill can show a variation of as much as 10seconds. Hardware variations are more on the order of 2 seconds tops.
It will be very hard to say that a car is faster due to a particular part rather than the driver himself.
antonch is offline   Reply With Quote
Old 02-11-2010, 01:28 PM   #202
Daishi00
Member#: 78952
2005 WRX
CGM
Originally Posted by JVD View Post
I just find a lot of people are trying to compare 1k coils to 2k+ coils. Rather unfair. And yes, I know there are 1k spring/strut setups... but those aren't height adjustable which is important to many people.
Not at all trying to defend the cheapo coils btw. When I buy, it won't be those.
You can do GC sleeves to get height adjustment and not spend much more than $1k on a full package.
The point of this thread is not to compare $1k to $2k systems. It is to show the massive limitations in terms of travel that the $1k options have. If you have $1k to spend you are much better off going with a spring/strut combo with GC sleeves if you need the height adjustment rather than go with the $1k coilovers.
There are guys running the crap coilovers and doing quite well on them on track (Phil from Element). But in his case...at least initially he was running custom valved units with very different spring rates, not to mention all the other modifications. I can't find them (and I'm not spending hours looking for them) but some of Phil's shots on track show the limited suspension travel he's got going on. If he swapped out that suspension for say...a JRZ setup I am 100% sure he would be faster.
Most of these $1k coilover manufacturers are not targeting track guys. They are targeting the street guys who think they need to have coilovers. The vendors that push these $1k coilovers do it because it's a great profit margin. The suspension focused vendors don't touch them because they have values when it comes to improving the handling of a car
Daishi00 is offline   Reply With Quote
Old 02-11-2010, 01:48 PM   #203
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
double post..
Kenji815 is offline   Reply With Quote
Old 02-11-2010, 01:48 PM   #204
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
yes those 1k coilover are focus on street.
In fact most coilover you see on the market are marketed for street use.
If you want real track coilover you should be getting penske shocks.
http://www.penskeshocks.com/
Old 02-11-2010, 01:52 PM   #205
Daishi00
Member#: 78952
2005 WRX
CGM
Everything sub $2k is marketed for street use. From $2k-$4k it's usually a combination and can perform quite well for just about anybody. Above $4k is when you get into the really good track stuff.
Old 02-11-2010, 01:53 PM   #206
JVD
Member#: 213130
Originally Posted by Arnie View Post
Even cheap coilovers would be 100% faster around a track compared to stock suspension (assuming that both were optimized as much as possible). The lower CoG, stiffer spring rates, better camber management of even a cheap coilover will trump a stock suspension. No question.
but it would be an interesting comparison between a BC/Megan and say, a DSpec/RCE spring (and some method to generate equal camber to the BC/Megan like double bolts/camber plates). Set all suspension to the same alignment/ride height specs, same tires, swaybars, etc. and see what happens. Actually, scratch that, I say simply optimize the setup for both systems independently. For example, one may need more neg camber on the DSpec/RCE setup with its softer spring rates, etc. etc.
Word.
I'd also be interested to see this. Tons of people seem to be talking about quality(or lack there of) just based on looking at the coilovers.
I'd love to see some direct comparisons. I had megan's on my S14... and I can tell you they sucked horribly... although still better than my eibach/tokico setup prior to that.
EDIT: Oh, and Dashi, I forgot about the GC sleeves. I was never really interested in them though because from what I remember height adjustment is only done from adjusting pre-load. Maybe I'm wrong...
JVD is offline   Reply With Quote
Old 02-11-2010, 02:18 PM   #207
antonch
Member#: 170384
2006 Sti
I've heard of a lot of cases of GC sleeves freezing up which IMO doesn't make them a good option. Even in areas w/o snow or salt. It's one of things you can adjust only once.
Old 02-11-2010, 02:22 PM   #208
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
And we've seen just as many posts around here and IWSTI showing BC/Megan/Ksport/CCC's all bound up, never to be adjusted again. With any CO, you should be taking steps to prevent contamination of the threading. Some metal choices and treatments just give you a shorter or longer time before it matters.
Old 02-11-2010, 02:26 PM   #209
ritky
Member#: 72285
2005 STi Wingless
FLA Turnpike > I-95
Originally Posted by williaty View Post
Both of you, go watch the video that was posted into this thread. It shows my car using that much droop just driving down a normal road at the speed limit. It also shows me running out of droop travel and lifting a rear wheel pulling into a gas station.
Real life just uses way more suspension travel than you guys think it does!
I'll concede since I'm tired of arguing and the normal roads I drive on are way different than the one you show in the video. My roads are flat and straight with long vertical and long horizontal curves. If I find some free time I'll try and get a video like yours showing the roads I consider normal and how much suspension travel is used.
ritky is offline   Reply With Quote
Old 02-11-2010, 02:57 PM   #210
gagliano
Member#: 39541
2002 WRX & 2004 STI
WR Blue
Don't forget that the rules of the racing venue can make a coil over choice attractive. For example, last year a Subaru in the NASA TT series, coil overs under a certain dollar value and no external reservoir were a no point upgrade. If you were on the bubble, then BCs would be attractive. This year I believe that has changed and any coil overs are assessed a spring upgrade penalty. Please any rule experts chime in to correct me.
Arnie makes a great point though, it would be interesting to see a comparison (obviously using the same driver).
gagliano is offline   Reply With Quote
Old 02-11-2010, 03:00 PM   #211
JVD
Member#: 213130
Ya, my Megan's seized but I had them on for a full Canadian winter.
I think it's common with most coils and isn't really something I think about when buying suspension. I'm gonna make sure to clean my next set more frequently and apply some sort of anti seize. It seemed to be sand and dirt that get lodged in the threads that caused the problem.
Old 02-11-2010, 04:17 PM   #212
Murphdog
Member#: 75414
2004 STi
Its the Blue one
Thought this was an interesting review on the Bc's
http://www.i-club.com/forums/vbartic...e&articleid=10
Murphdog is offline   Reply With Quote
Old 02-11-2010, 04:22 PM   #213
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
yup, i've seen lots of coilovers with seized adjustment collars. Always use some anti-seize on the threaded surfaces and make sure you clean the threads before attempting to adjust them. Once you get that fine sand wedged in the threads, it doesn't matter how much heat or lube you use, it won't be coming loose.
Arnie is offline   Reply With Quote
Old 02-11-2010, 04:30 PM   #214
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
As far as I know, no coilovers, springs, or really any other suspension mods have ever been no-point mods in NASA TT.
boost junkie is offline   Reply With Quote
Old 02-11-2010, 05:20 PM   #215
gagliano
Member#: 39541
2002 WRX & 2004 STI
WR Blue
Camber plates and strut bars are no point mods.
Old 02-11-2010, 05:27 PM   #216
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
This actually makes VERY good sense. There's no point to them.
Old 02-11-2010, 06:52 PM   #217
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
Zing.
Old 02-11-2010, 07:47 PM   #218
gagliano
Member#: 39541
2002 WRX & 2004 STI
WR Blue
No zing to me, I don't own BCs and could care less. I'm just relaying why a buddy of mine went with them on his TTA car; kept him from being bumped into TTS where he would have gotten crushed based on his available budget.
Old 02-11-2010, 08:09 PM   #219
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
This is all very interesting reading.
I was told somewhere once (in person at the track, not interwebs) There are 2 ways to accomplish the same thing (body roll). Stiffer sways and softer springs, or softer sways and stiffer springs.
I DD my car more than I track it. Koni inserts and springs with 27mm front and 22mm rear whiteline ways is a better fit for me and my budget than 2k+ CO.
medamullet is offline   Reply With Quote
Old 02-11-2010, 08:10 PM   #220
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
There's a 3rd option: change the geometry. Which, frankly, is the best way to go.
Old 02-11-2010, 08:13 PM   #221
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
explain?
Old 02-11-2010, 08:24 PM   #222
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Move the roll center, move the center of gravity, etc
Old 02-11-2010, 08:48 PM   #223
STi-MAN
Member#: 70252
05 STI
blue
maybe i should just read thru this whole thread. but what kind of car are we talking about here? a street car or a track car?
STi-MAN is offline   Reply With Quote
Old 02-11-2010, 09:22 PM   #224
Daishi00
Member#: 78952
2005 WRX
CGM
Street. Although it applies just as much to a track car.
Old 02-12-2010, 09:05 AM   #225
jeisen
Member#: 27258
who dat be dat was?
Well,its a general discussion on droop/zero droop in regards to front and rear but one of the posters wanted to simplify the discussion by talking about the front wheels.
And though it is talking about formula fords, not exactly apples to apples, I think the basic principles may apply.
Agreed, it is a discussion for racing vehicles. But, that is the gist of my point. Where did this low droop design aesthetic come from on the cheap coilovers? They most likely copied from higher end race setups. So the discussion is: what is the purpose, benefit of the low droop setup?
Even Subaru built low droop suspensions. My friend had S202 takeoffs on his car and it only took 2-3 pumps on the jack to get the wheels off the ground. A stock GD was around 11 pumps.
jeisen is offline   Reply With Quote
GC Kit and droop jeisen Brakes, Steering & Suspension 7 02-15-2010 08:18 AM
back to stock sale coilovers and other parts cheap mrguppy MAIC Private Classifieds 14 10-13-2008 02:46 PM
Springing options for coilovers - attacking stroke and droop travel Scooby921 Brakes, Steering & Suspension 7 05-10-2007 11:41 AM
FS: Brand New Coilovers and Shocks Cheap! wildchild Private 'For Sale' Classifieds 2 08-01-2004 07:46 PM
Cheap coilover kits on eBay B-Kerr Brakes, Steering & Suspension 11 05-31-2003 12:40 AM
