Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Old 02-03-2010, 01:49 PM   #1
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
Default low noise exhaust - downpipe and catback exhaust?
Hello,
I am looking into improving the exahust system of my 06 WRX wagon and then finally tune it at a shop. I want something simple, produces an improvement in power and does not produce a lot of noise compared to stock.
After doing some research on NASIOC, although kind of had a hard time searching for exhaust threads, I am looking into getting a downpipe (no brand yet) plus a Magnaflow catback exhaust system.
Does anyone have any comments on my proposed set up? Any recommended down pipes, alternative catback systems?
FYI, I have a relatively simple set up on my car: K&N typhoon Air Intake, STBs front and rear, 25mm front and 22mm rear swaybars, Kartboy endlinks all around, Kartboy short throw shifter, wider and lighter wheels and performance tires. Once I install a new exhaust system, I'm going to tune it to get the most gains.
kenliu84 is offline   Reply With Quote
Old 02-03-2010, 02:31 PM   #2
seest
Member#: 136005
2007 WRX
While i dont have experience with that cat back, if you are looking to stay quiet just replace your DP.
I run just the cobb catted DP with the AP on my car, keeps me quiet and gives me most of the power in a full TBE (-1 or 2 hp).
seest is offline   Reply With Quote
Old 02-03-2010, 02:38 PM   #3
wrxchase
Member#: 138910
2006 WRX LTD 4EAT
steel gray matalic
i ran a greddy evo2 with a catted downpipe. and its was super quiet. but you have a 4in tip on the exhaust. it gave me all the power i wanted with out the big sound while just cruising. if you step on the gas it will scream.
wrxchase is offline   Reply With Quote
Old 02-03-2010, 02:54 PM   #4
kenliu84
Member#: 107618
2006 OBP WRX Wagon
Seest, what's an AP?
chase, not sure what you mean "you have a 4in tip on the exhaust". You referring to the Magnaflow? maybe you were talking about the greddy evo2. if that is the case, I don't want to "scream" or go too loud when I step on the gas, I want a system all around that won't be much louder than stock.
I am assuming a catted downpipe is a downpipe with a cataylic converter integrated with it.
thanks for the quick replies, guys.
Old 02-03-2010, 09:08 PM   #5
buzzword
Member#: 123353
2006 AW STi
FLI tuned - 280/300@15psi
Having used magnaflow mufflers in the past on a variety of applications, I feel qualified to tell you that it will probably be louder than what you're shooting for. Think: LOUD drone at 70 mph.
buzzword is offline   Reply With Quote
Old 02-03-2010, 09:09 PM   #6
scotty144
Member#: 85343
2005 STI
When I had my 02 wagon, I had a HKS hi power. It was ungodly loud in the wagon...any exhaust in the wagon will be much louder than the sedan version. I bought an 'exhaust auger' which quieted things down nicely and did not impact on the performance.
scotty144 is offline   Reply With Quote
Old 02-04-2010, 03:18 AM   #7
subaragnarok
Member#: 211986
Currently running a catless downpipe, with the stock catback, and its hardly ANY louder than before. You won't lose much from it either in terms of hp. Maybe 1 or 2
And an AP is an AcessPort, which basically gives you an off-the shelf tune from COBB, allowing you to run a new DP and gives your car a nice boost. It's what many people refer to as "stage 2"
subaragnarok is offline   Reply With Quote
Old 02-04-2010, 03:57 AM   #8
kenliu84
Member#: 107618
2006 OBP WRX Wagon
thanks for your great input and answers, guys, especially buzz as he personally used Magnaflow before.
I intend to still get a catted downpipe with a cat-back exhaust system. I don't want a catless DP because of inspection and I want to help our problem on earth.
after your posts, I went on some websites to shop around some more and read a little more on exhaust systems. anyone used the HELIX catted DP from Gruppes? What about the Greddy SE catback exhaust system? any recommendations on DPs or CBE systems for low noise?
It seems like a DP is a must if I want performance increase with low noise. thanks in advance.
-Ken
Old 02-04-2010, 09:48 AM   #9
woody06967
Member#: 110330
4" APS DP with Fuji RM01A exhaust is really quiet but it's catless.
woody06967 is offline   Reply With Quote
Old 02-04-2010, 10:50 AM   #10
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
Im looking to do the same as the OP, I want a quiet exhaust to go stage 2. I've heard that the borla or SPT exhausts are relatively quiet. I'm considerind doing just a downpipe but I want to explore all my options
2010 WRX Limited is offline   Reply With Quote
Old 02-04-2010, 11:56 AM   #11
fistandauntilus
Member#: 145533
2004 STi
i have an invidia catless dp mated to an SPT catback, and it sounds great. nice and deep, and no drone on the highway.
fistandauntilus is offline   Reply With Quote
Old 02-05-2010, 12:25 PM   #12
RiceRooster
Member#: 127550
2004 WRB STi
2004 ZX10R
-Ken
I'm running a Helix catted DP with WBR exhaust. Gives it a stock look that has a nice rumble at idle and its pretty quite when cruising...
RiceRooster is offline   Reply With Quote
Old 02-05-2010, 01:30 PM   #13
csmithwrx'05
Member#: 171293
'05 WRX Hybrid
EJ257 w/Blouch 18G 8cm^2
quiet exhausts:
Maddad Whisper
Vibrant StreetPower
Stromung
Borla Hush
Haywood & Scott (I heard they are quiet, but have no 1st hand experience w/them.)
Also having a catted DP will keep the noise down a bit more than w/o the cat.
http://www.daddysscp.com/category_s/21.htm (sells all the exhausts I listed above, except the Vibrant).
Link to the Vibrant: http://www.crucialracing.com/product...ds/exhaust.php
csmithwrx'05 is offline   Reply With Quote
Old 02-05-2010, 02:36 PM   #14
DirtyBanana
Member#: 211802
2003 Wrx
Sonic Yellow
I believe the cobb exhaust is fairly quite. Sounds really nice in person as well.
DirtyBanana is offline   Reply With Quote
Old 02-06-2010, 09:34 PM   #15
kenliu84
Member#: 107618
2006 OBP WRX Wagon
thanks for all of your input, I'll do more research and then purchase.
hey csmith, you have experience with all those you listed except the last?
did you ever run a dyno on any of them that showed it increase HP while keeping the noise down?
Old 02-06-2010, 10:27 PM   #16
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Originally Posted by scotty144 View Post
When I had my 02 wagon, I had a HKS hi power. It was ungodly loud in the wagon...any poorly designed, fartpipe exhaust like the hks in the wagon will produce poor results
Uncle Scotty is online now   Reply With Quote
Old 02-07-2010, 04:09 PM   #17
ChronicPoe
Member#: 185255
2007 STI
Just make sure that whatever downpipe you get is catted, that will reduce the noise greatly. I have a full Cobb TBE, and it is not much louder than stock.
ChronicPoe is offline   Reply With Quote
Old 02-07-2010, 11:58 PM   #18
livinglegend629
Member#: 233167
2009 FXT & 98 RS
Yea I have my exhaust set up with an SPT and its great. Not very loud when cruising around and sounds great when you hit the gas. My neighbor has an 06' sti as well and he has an Apexi GT and I can hear him coming from a block and a half away.
Just my .02 cents
livinglegend629 is offline   Reply With Quote
Old 02-09-2010, 07:46 PM   #19
Bandit00
Member#: 199820
2008 WRX STI
I ran the Greddy Ti-C on my 2006 wrx. sounded sweet to me. The Cobb downpipe is always a good choice as well. Fitment is the key to a nice sounding exhaust.
Bandit00 is offline   Reply With Quote
Old 02-09-2010, 08:17 PM   #20
Jayknux
Member#: 236450
09 WRX HB
Dark Grey Met
Once you did the typhoon you should have been tuned because of the air/fuel ratio... you dont want to run too lean. The cobb maps do not have that in the mapping to adjust your air/fuel ratio. I suggest getting your turboback done asap and getting tuned. It will be like day and night after the tune. I just installed on my 09 wrx the invidia high flow cat dp and the invidia q300 exhaust.....big deep rumble and cops wont hear you from a block away...good luck
Jayknux is offline   Reply With Quote
For Sale: Stock Downpipe and Catback exhaust 08-10 wrx Kings028 Engine/Power/Exhaust 1 05-28-2010 09:56 AM
FS: Used 08-09 Headers, Downpipe and Catback Exhaust anthonydb80 Engine/Power/Exhaust 53 04-15-2010 04:07 PM
Moore Performance Divorced Wastegate Downpipe and Catback Exhaust Group Buy!! Spun Autosports Vendor 'Group Buy' Classifieds 27 12-03-2009 07:48 PM
FS: MD Invidia Catless Downpipe and Catback Exhaust combine for Turboback PonyRazor MAIC Private Classifieds 31 12-05-2007 12:22 PM
OH: Cobb Access Port, Downpipe, and Catback Exhaust For Sale enjoyrth Private 'For Sale' Classifieds 6 08-22-2006 10:02 PM
