Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 02-03-2010, 04:19 PM   #1
scoobynoobEMT
Member#: 199206
2002 WRX wagon EJ257
Default cruise control lights dont turn on.
In my 2002 WRX, the cruise control lights, (the one in the cluster, and the orange one on the button) don't work.
Setting the cruise control, while driving, I hit the button and it turns orange.
I hit the set lever, cruise control initiates, however, the button doesn't turn green and the lights in the gauge cluster don't turn on..
Does anyone have any ideas on what the problem could be?
scoobynoobEMT is offline   Reply With Quote
Old 02-04-2010, 02:36 AM   #2
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
far as i know... they don't do any of these things. It's just on when it's on, and the light on the switch is just on when the system is armed and that's it.
ProdriveDreams is offline   Reply With Quote
Old 02-04-2010, 09:21 AM   #3
scoobynoobEMT
Member#: 199206
That's what I'm asking.. When I'm USING my cruise control the button doesn't turn green, and the light on my gauge cluster doesn't turn on.
Trying to figure out why.
Old 02-04-2010, 10:12 AM   #4
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
no that's my point. the button doesn't change and there is no light on the cluster.
Just looked at the service manual and there is no such light on the cluster, and if you've ever opened up the switch you know that there is only two lights: the switch illumination light, and the indicator light.
Old 02-04-2010, 10:58 AM   #5
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Check the switch adjustments on the brake and clutch pedals for the CC system. They are a common trouble source for CC problems.
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Reverse lights dont turn on MJBrowny21 Transmission (AT/MT) & Driveline 6 03-22-2010 05:25 PM
HELP! Check Engine light on & Cruise Control Light Blinking STiURBO Southern California Impreza Club Forum -- SCIC 21 03-15-2007 01:54 AM
Reverse Lights Dont Turn On - Help michyous Legacy Forum 5 04-16-2005 10:54 PM
Check engine light on and cruise control light flashing mpadovano Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 01-23-2005 02:04 PM
