Old 02-03-2010, 09:28 PM   #1
morrocco88
Member#: 104098
1997 LGT 2.1 stroker
Rotated S200SX-56 6speed
Default AP Newb, Just updated the AP and lost some features?
I bought the APv2 from Surgeline about a year ago and I'm just now to the point of using it on my project. This was due to a long build process of swapping an 05' wrx motor and wiring into a 97' LGT.
Anyways, I got the break in map from Surgeline and started using the AP and liked the ability to raise the idle and pull timing for bad fuel with the "ECU Settings" on the Menu. I decided to update the AP today since it was purchased a year ago, and now that feature seems to have dissapeared from the menu?
The original info before updating:
serial #: 1110003313
Dongle: v0.41
Firmware: v. 1.2.8.1-7013
Is this no longer available?
Also, I have a question as to what parameters does an 05' wrx ECU need to go into OPEN LOOP? I was driving on the break-in map for the new motor and setting my Mechanical boost pressure on the EWG, and it was holding the AFR's in the mid 14's even at 10 psi, so the car was kinda not happy and surging just begging for more fuel. I stayed in it long enough to see the info on my scanner switch to Open Loop at like 5k and then it immediately dropped to mid 12's and smoothed out and ran really good. So it seems it is staying in closed loop for too long and causing it to run leaner than it needs for 10psi. Shouldn't it go to Open Loop when you get into boost?
What parameters makes it switch into Open Loop other than a certain RPM?
Can you change those parameters to make it go to open loop when you want?
I called Surgeline and left a message with a non-technical guy and he was going to have someone else get back to me about that on my map. I have the stock long block in the car now, because I wanted to test the wiring job, set my mechanical boost pressure, and make sure everything is perfect before I swap in the built long block and start break-in. I didn't want to start the new, expensive motor with any unknowns or bugs to work out. In my mind mid 14.5:1 AFR at 10 psi with the car bucking a little is not going to work for breaking in my new motor.
Any thoughts on these issues?
morrocco88 is offline   Reply With Quote
09 wrx have test mode cables? or just plug the AP in? chads09 Newbies & FAQs 2 05-14-2009 04:28 PM
I just slapped the isht out of some kids hand awilson529 Off-Topic 41 11-01-2006 11:21 AM
Just bought a block and need some advice- 2.0 or 2.2? BLUETURBOWRX Factory 2.0L Turbo Powertrain 28 12-22-2003 01:22 PM
('93-'01) Need to annoy the neighbors and burn some rubber... chump_driver Impreza Forum 7 05-20-2001 07:12 AM
Fun in the snow, and lost both headlights.. was an intresting day (Pics) Fish New England Impreza Club Forum -- NESIC 12 12-31-2000 08:39 AM
Message Board Statistics All times are GMT -4. The time now is 04:51 PM.
