Old 06-20-2012, 08:03 AM   #101
mpggomd
Member#: 74167
2011 WRX Sedan WRB
Cobb Stage 2 OTS
Originally Posted by honestabe View Post
I've had the exact same problem, very strange vibration through the clutch pedal after hard acceleration, particularly after reaching high rpms
I've been having the same issue! Ripping through first and second, I then get the vibration, notchy feeling of the clutch. If I pump the clutch a few times, it goes away. My car has about 19k miles on it, stage2, so I'm afraid to bring it to the dealer because they will think I "abuse" the car, even though I've driven my past 2 wrx's into the 120k mile territory on the stock clutch!
So, bump, hopefully people have more insight to this problem.
mpggomd is offline   Reply With Quote
Old 10-05-2012, 03:38 AM   #102
garzdos
Member#: 333423
2012 WRX Hatch
Dark Gray Metallic
No one has discovered the cause of this problem? I have no squeek but starting yesterday I had a vibration mid travel when pushing the clutch both in and out. '12 WRX with 1950 miles. Seemed to be decreased the next day. Pumping seems to help but I don't want this to continue!!!
garzdos is offline   Reply With Quote
Old 11-12-2012, 07:54 PM   #103
den9
Member#: 268957
2011 WRX 5 door
gray
Originally Posted by den9 View Post
30k miles and i noticed the problem hasnt happened in the last 3k miles or so, i been beating the **** out of it too.
43k miles now and havent had the issue since it randomly stopped. still get the clutch noise when depressed when its cold outside.
den9 is offline   Reply With Quote
Old 11-12-2012, 11:35 PM   #104
Tpowell
Member#: 281510
2009 Rex
Just a shot..but have you checked the spot welds that secure the pedal assembly to the firewall ?? These have been coming apart like crazy and this causes a nice squeaky popping noise .. Might help with one of ur squeaks
http://www.wrxforums.com/forums/84-d...t-style-5.html
Tpowell is offline   Reply With Quote
Old 11-13-2012, 03:24 PM   #105
swpshgnwgn
Member#: 150494
11 WRX
SWP Torqued Stg II
Just bought a 2011 wrx and have both issues as well. At 30k miles right now. The pedal vibrating is the one that worries me.
swpshgnwgn is offline   Reply With Quote
Old 11-16-2012, 12:51 AM   #106
Scotty_WRX
Member#: 313930
Looking into this problem aswell on my 09
Scotty_WRX is offline   Reply With Quote
Old 11-16-2012, 03:55 PM   #107
KillerRabbit
Member#: 184772
2004 Crazy Slow WRX
World Rally Blue
I just fixed a buddies 09 WRX, 3 spot welds broke on the bracket. He had just over 60k so warranty was out of the question. We drilled out the oem spot welds and put grade 8 bolts, washers and nuts on to fix it.
We found this out after removing the wiper cowl and having someone press on the clutch pedal. You could see the spot welds moving almost 1/4 inch.
KillerRabbit is offline   Reply With Quote
Old 11-17-2012, 07:39 PM   #108
etothen
Member#: 221885
09 Ivory Tower
Ivory...duh
Since I saw the thread just thought I would update, squealing noise went away about a year an a half ago, nothing since.
etothen is offline   Reply With Quote
Old 11-18-2012, 01:14 PM   #109
zakeswrx
Member#: 337169
I haven't had this problem on my subie but I heard of this a few times already and it seems to me like previously stated above that it's the spot welds and they should be a cheap and easy fix
zakeswrx is offline   Reply With Quote
Old 11-19-2012, 10:45 AM   #110
DNM10
Member#: 307355
2009 WRX Hatch
I had the firewall welds repaired under warranty, and had a new clutch installed the same time around 300 miles ago. Today I started feeling vibration in the clutch while getting off of the freeway....needless to say I am frustrated. Has anyone found out the cause of the vibrating clutch pedal? Is it serious? I will go take a drive on my lunch today to see if it has changed. Any info is appreciated.
DNM10 is offline   Reply With Quote
Old 11-19-2012, 02:06 PM   #111
DNM10
Member#: 307355
2009 WRX Hatch
Went for a drive and the vibration is gone.....not sure what is up
Old 02-05-2013, 05:55 PM   #112
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
SWP Bilstein'd COBB Stg2+
Subscribed. I have a squeaky clutch but no noticeable vibrations. Yes, I would call my clutch pedal stiff. I read they changed that in 2011+.
Might make a call to the dealership and see if they can do some investigating. Last time I tried to make a warranty claim (battery died), they gave me a load of crap for my mods. (I have an extended warranty).
QwaktastiK is offline   Reply With Quote
Old 02-07-2013, 11:30 AM   #113
honestabe
Member#: 261730
2011 WRX hatch
Squeaky-ness and stiffness (imo) have to do with the throw-out bearing. I went in due to squeaks and the head tech said it looked like there was very little lubricant on the bearing. Many people have mentioned this in this thread. Busted firewall welds also contribute
The clutch assembly seems to be finicky and I think it just doesn't allow for sloppy driving. I also experienced pedal vibrations after a hard pull... but I don't get it anymore. A couple people hinted that mistiming clutch release and throttle position can cause this vibration.
The easiest first step is to take it into the dealer if you have a constant issue like squeaking. For the vibration issue, I think its mostly in shifting technique. A lot of us new-gen wrx owners are first time wrx drivers so perhaps it takes time to get used to shifting properly. I honestly don't get any of the vibrations in the clutch pedal anymore.
honestabe is offline   Reply With Quote
Old 04-16-2013, 11:20 AM   #114
entr0py
Member#: 280297
I posted in this thread before and just came across it again so I'll post a follow-up.
I'm up to almost ~120k miles on my 08 WRX now.
I had the clutch "clicking" sound for the longest time when releasing the clutch pedal. I found it to be associated with the clutch linkage as stated above. It went away eventually. The odd time it came back, I found that kicking the clutch pedal laterally in the direction of the brake and gas pedal made the problem go away. Now that I see it could be popped welds, I'll look into fixing it myself.
I also had the vibrating clutch pedal problem intermittently but it hasn't happened in the last 6 months. When it did happen, I only felt it at the top 1 inch of travel.
My clutch has always been stiff unlike many of the newer subies I drove. I have not replaced any clutch-related components on the car (mostly because I went through the warranty period in under 2 years). I found it more annoying than anything and I'm glad the problem went away.
entr0py is offline   Reply With Quote
Clutch pedal vibration Dave99 Transmission (AT/MT) & Driveline 18 12-10-2010 12:07 PM
Clutch pedal vibration Cinna696 Transmission (AT/MT) & Driveline 0 10-27-2008 11:54 PM
06 WRX Clutch Pedal Squeaking suBooneru Warranty Issues & SOA Problems 4 02-08-2006 08:56 AM
clutch pedal vibration HS WRB-rex Transmission (AT/MT) & Driveline 5 12-28-2002 04:49 AM
clutch pedal vibration OMAHA2.5RS Transmission (AT/MT) & Driveline 0 03-08-2002 03:52 AM
Message Board Statistics All times are GMT -4. The time now is 02:20 AM.
