Notices
Old 02-04-2010, 09:06 AM   #1
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default Cyclone Steam Engine Pushes Closer To Land Speed Record
Steam engines. For most of us, they conjure images of horseless buggies, paddle ships and classic locomotives, but soon they may be setting new speed records and hitting new benchmarks for efficiency--potentially in passenger cars.
Cyclone Power Technologies today announced it has completed and shipped a full scale model of the engine being built for the U.S. Land Steam Record Team. At 180 horsepower and peak torque of 850 pound-feet--at 1 rpm--the engine promises to deliver a steam-powered speed record with a marriage of old and new technology. Being the powertrain nerds we are, we took a closer look at the system.
Defined by Cyclone as a Rankine Cycle heat regenerative external combustion engine, the Cyclone Engine uses a six-piston radial layout to extract power from supercritical steam. Supercritical steam is water heated to 1,200 degrees Fahrenheit, existing in a phase state that's not really a liquid or a gas, but can behave like both. The supercritical steam is contained within a tubular coil system and then released into the cylinders, compressing the pistons and rotating the crank shaft through a unique spider bearing.
Once the steam has done its job, it enters the cooling phase to return to its liquid state before heading back up to be superheated again. Water also serves as the lubricant for the system, eliminating the need for oil or oil changes.
Heat for the whole process is created in an atmospheric pressure combustion chamber, meaning almost any fuel can be used, without producing many of the harmful by-products of high-pressure internal combustion engines, such as oxides of nitrogen. Because the fuel circulates in the combustion chamber until it's all consumed, and much of heat generated is contained within the closed-loop system, Cyclone says their engine can convert up to 46 percent of the fuel energy into torque, a figure about 15 percent higher than the most efficient internal combustion engines, including diesels.
The Cyclone engine packaged in a passenger car format
Enlarge Photo
There are other advantages to the technology as well, from a packaging standpoint. Weighing in at just about 200 pounds, it's lightweight and relatively compact, especially when you consider that the engine requires no gearbox due to the high initial torque. Torque slowly decreases as engine speed increases, though the prototype engine being developed for the steam-powered speed run still produces 262 pound-feet at 3,600 rpm. It's an elegant way to extract power from fuel and deliver it to the ground, and it's a way Cyclone hopes to eventually push into the passenger car segment.
Its ability to run on almost any fuel, high efficiency and low emissions mean it may well be even better suited to the task of propelling the cars of the 21st Century than rusty coal-fired boilers were to building the infrastructure of the 19th Century.
Check out the video below for a quick explanation of the engine tech from the man behind it, Harry Schoell. And when you're done, head over to the U.S. Land Steam Record Team's site to learn more about their attempt to break the 148-mph record.
[Cyclone Power Technologies]
video at link
http://www.motorauthority.com/blog/1...d-speed-record
Old 02-04-2010, 10:01 AM   #2
boxerinside
Member#: 191994
850 lb/tq!!! .
This is the typical "to good to be true" stuff we'll never hear off again.
boxerinside is offline   Reply With Quote
Old 02-04-2010, 02:41 PM   #3
BlaineWasHere
Member#: 165271
2013 FR-S
lol... 850TQ @ 1 RPM...
Edit: ... opps.
BlaineWasHere is offline   Reply With Quote
Old 02-04-2010, 04:06 PM   #4
boxerinside
Member#: 191994
torque not HP
Old 02-04-2010, 04:20 PM   #5
Wrxtuner251
Member#: 135150
2006 WRX Sedan
Intresting read! Kinda curious since it doesn't seem to have any accessories. How would it drive an AC compressor to cool people in the vehicle also would it work in very cold conditions running off water an all?
Wrxtuner251 is offline   Reply With Quote
Old 02-04-2010, 05:40 PM   #6
Tim-H
Member#: 65751
'10 VULVA
well they're only using it to set a record for now. Depending on what they use for the heat source, maybe use it to power accsesories as well.
Tim-H is offline   Reply With Quote
Old 02-04-2010, 05:47 PM   #7
Hites
Member#: 138997
0000 Nothing
Originally Posted by boxerinside View Post
850 lb/tq!!! .
Sadly yes, for one reason or another.
Hites is offline   Reply With Quote
One step closer to the DEI engine (seriously) Wagon Of Fury Off-Topic 3 07-27-2008 11:30 AM
Land-speed record, drag-racing legend Art Arfons dies NYCshopper Non-Subaru News & Rumors 1 12-04-2007 10:10 PM
I just broke the land speed record! ExpO Off-Topic 16 06-20-2006 07:30 PM
flooring pedal vs. slowly pushing down to get speed up? wontwon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-21-2006 11:40 AM
Subaru Justy Land Speed Record... Zahnster Motorsports 10 03-10-2002 10:27 PM
