Old 02-04-2010, 12:46 PM   #1
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
Default STI cams in 2.0 heads on 2.0 block?
Did a search and found a lot of stuff relating to hybrid builds, but I don't know how applicable any of that is to using sti cams on a 2.0 block.
I've got a lead on some cheap sti cams, slightly bigger than wrx cams with the same duration. would these be a direct swap on a 2.0 or would I have to change anything else?
OUScooby is offline   Reply With Quote
Old 02-04-2010, 01:15 PM   #2
fastlanerex
Member#: 133391
2004 boosted saleen
white
http://forums.nasioc.com/forums/show...s+in+wrx+heads
The search button is your friend.
Here ya go
fastlanerex is offline   Reply With Quote
Old 02-04-2010, 01:39 PM   #3
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
Default Re: STI cams in 2.0 heads on 2.0 block?
Here ya go
that's about a hybrid, reread OP and try again.
Old 02-04-2010, 01:46 PM   #4
fastlanerex
Member#: 133391
2004 boosted saleen
white
um its still putting sti cams into a set of wrx heads its the same thing hybrid or not, wrx heads are still wrx heads on a 2.5 bottem end ect... on a hybrid
therefore in that thread lies the answer to your question
Old 02-04-2010, 01:50 PM   #5
Longshot55
Member#: 164121
2005 WRX EvoIII 16G
EFI Logics Tuned
wtf
You want to crack your block just to put STi cams in?
Longshot55 is offline   Reply With Quote
Old 02-04-2010, 02:41 PM   #6
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
basically if you plug the oil ports on the sti cams that final lobe wont try and force oil into the AVCS that aren't there.
some people on here believe that you still need the actuators for teh avcs cause they are part of teh sti cam. If you run the sti cam blocked/plugged, on wrx heads it's a drop and play. Just set valve clearance in spec with the right buckets and slap the valve covers on and rip. I'm not sure if the sti cams have a steep enough lobe to require a bumped idle to stop from "caming" but you shoud know after some time.
I did a lot of looking into this, but decided the sti cams were not really a big increase over the stock wrx ones, and frankly I didn't care enough I wanted my car back together.
greenspeed is offline   Reply With Quote
Old 02-04-2010, 02:48 PM   #7
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
thank you for the info. I've actually heard the are good for between 40 to 60hp at the top end with no lose at the bottom end. I'm still trying to find info to back up those numbers.
Old 02-04-2010, 04:29 PM   #8
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
if you got the engine out or you're doing a build and have the time. Not a bad thing to add in, however I was time crunched. Another thing you should look at is a P&P on the heads the wrx heads can squeeze a bit more hp out of them making that came number into the 75-80hp range if your numbers are right.
Old 02-04-2010, 04:33 PM   #9
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Another 40-60hp? Not even close on any setup small enough to not pop the stock motor. Maybe on a 35R, but the gains, although there, will be somewhat minimal on most 'normal' setups (i.e. 18G or smaller).
Audiosavvy is offline   Reply With Quote
Old 02-04-2010, 04:38 PM   #10
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
I thought it was a bit high too.
Old 02-06-2010, 10:05 PM   #11
02 Scoob-TN
Member#: 176010
2005 WRX sdn ver8'ed
Phat-Tuned RIP Bugeye
+1mm valves would be about the same cost and free up 30-40hp.. I bought Ferrea's for like 230. Stock stem diameter(no need to machine guides) so its just about having the heads machined for the +1 mm valve heads.
Specs on these valves are as follows:
  • F6078 (Intake Valves):
  • Head Diam: 37mm
  • Stem Diam: 5.97mm
  • Overall length: 104.6mm
  • Tip Length: 3.5mm
  • 19 Super Flo Radius Groove 1mm oversize
  • F6076 (Exhaust valves)
  • Head Diam: 33mm
  • Stem Diam: 5.96mm
  • Overall length: 104.75mm
  • Tip Length 3.5mm
  • 25 Flo Radius Groove 1mm oversize Special Alloy
02 Scoob-TN is offline   Reply With Quote
Assembly: 2.0L Heads on 2.5L block Kingpin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 110 09-26-2014 06:58 AM
2.0 heads on sti block crpwrx Subaru Conversions 8 09-28-2008 07:55 PM
USDM 2.0 heads on a USDM STi Block? NicktheBrit Built Motor Discussion 5 03-06-2008 04:11 PM
2.5RS Heads on a EJ20 block? jayfressh Subaru Conversions 8 07-10-2005 10:29 AM
('93-'01) 2.5 heads on 2.2 block? Murray Impreza Forum 4 06-22-2002 02:13 PM
