South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 02-04-2010, 11:51 PM   #1
2TG8V
Member#: 67335
2015 wrx
Default Ford specialist
I need help with a 97 expedition with a no start condition after a heater core replacement.I have not checked if its a no spark or no fuel or both condition.Does anyone know if the factory security system needs to be reset ?
2TG8V is offline   Reply With Quote
Old 02-06-2010, 12:03 PM   #2
thegreg
Member#: 105429
2004 WRX STi
hmm If the tech who pulled the dash to replace the heater core didnt reconnect something relating to the fuse box, that could cause an issue.
thegreg is offline   Reply With Quote
Old 02-06-2010, 02:43 PM   #3
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
Does it turn over? Is there an aftermarket alarm? Run an OBDii scanner and see if there are any codes. Could be something related to coolant temp sensor, did the truck overheat?
bobturismo is offline   Reply With Quote
Old 02-06-2010, 03:26 PM   #4
2TG8V
Member#: 67335
2015 wrx
I checked all the major connectors at the drivers side junction block and the connectors on the right side of the firewall near the battery.I really did not see any pins bent or bad connections.This was Thursday so I called it a day.Friday I return with a scan tool to pull codes and it just starts so now im gonna take it back apart and see if there is something I messed up on.This will be the last Ford I touch.
Old 02-06-2010, 03:30 PM   #5
bobturismo
Member#: 42145
6-4 jockin da bish-
Well, let me know, I'm excellent at troubleshooting, specially electrical.
Yeah, I've worked on enough Fords that "Friends don't let friends buy Fords".
I told one friend, "if you buy anymore mustangs, I'm not gonna work on them!"
Old 02-09-2010, 07:32 PM   #6
2TG8V
Member#: 67335
2015 wrx
Thank you for everyones ideas.I took the whole dash off like I was doing a heater core.I did not find any wires,connectors or grounds missing or loose.Talk to Ford dealer and they said fuel pump and pcm relays were a very common problem with 97 Expeditions,the intermittent no start was just coincidental with heater core job.This has not been a fun experience,been working on it since Monday at 8am.Tommorow I will be putting it back together.
Official Debut, Saleen S302 At Ford Nationals AVANTI R5 Non-Subaru News & Rumors 3 06-04-2010 02:04 PM
Ford Plant Bans Everything but Fords From Parking Lot Rallyroo Non-Subaru News & Rumors 18 01-31-2006 09:01 AM
Ford Focus WRC Concept / Ford Fiesta JWRC NYCshopper Motorsports 11 11-02-2004 06:57 PM
Ford Guys, Wheres the Ford guys? AdmireWantWillLove Off-Topic 3 04-20-2004 09:09 AM
Why is Ford UK cooler than Ford of America? chkltcow Off-Topic 3 09-04-2003 06:16 PM
