Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Closed Thread
Old 02-05-2010, 11:55 AM   #1
subaruwrxparts.com
Vendor Sales Rating: (24)
Member#: 26010
2006 STi
Default Great pricing on AEM UEGO! Defi/STRI/SPT
AIM: SubaruWRXparts
PH: 603.778.0300
E-mail: [email protected]
Hours: M-F 7:30am to 5:30pm and Sat 7:30am-1pm
AEM UEGO Wideband gauges in stock!
AEM's Wideband UEGO Controller is also available in a gauge that includes a single-channel analog output with a Bosch O2 sensor in one unit! AEM's Gauge-Type Wideband UEGO Controller features an LED readout and sweeping LED vneedle" that changes colors as AFR changes from rich to lean. The unit's 52mm (2-1/16") gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. No laptop required for monitoring!
Key Features: Bosch sensor included with the AEM kit, 24 Color-coded LED display lights provide immediate reference to engine's air/fuel ratio (AFR) or Lambda, Integrated three-digit display reveals AFR or Lambda in real time user-programmable 0-5v analog output included for use with data loggers and ANY engine management system, Ideal AFR monitoring tool for carbureted applications and engine dynamometers, does not oscillate AFR like narrow band sensors, serial data stream included for output of AFR (RS 232), accurate to 0.1 AFR, 6 gauges in 1, one part number and you can have black or silver bezel with black or white face with a reading in lamda or AFR
SPT Boost Gauge 08+ WRX/STi
Displays engine vacuum in Hg and boost in PSI. Bright red illumination matches the vehicle instrument panel lighting and goes dark when the engine is turned off. Kit includes mounting cup and bracket.
__________________
[COLOR=Black]
[B]AIM:[/B] SubaruWRXparts
[B]Email: [/B]
[B]PH:[/B] 603.778.0300
[COLOR=Red][B][[/B][/COLOR]
[B][COLOR=Red]][/COLOR][/B] [/COLOR][COLOR=Red][B][[/B][/COLOR][COLOR=Navy]
[/COLOR][COLOR=Black][B][COLOR=Red]][/COLOR][/B][/COLOR][COLOR=Red][B] [[/B][/COLOR][COLOR=Navy]
[/COLOR][COLOR=Black][B][COLOR=Red]] [[/COLOR][/B][COLOR=Indigo]
[/COLOR][/COLOR][COLOR=Black][B][COLOR=Red]]
subaruwrxparts.com is offline
Old 02-05-2010, 11:57 AM   #2
subaruwrxparts.com
Member#: 26010
2006 STi
DEFI Advanced CR Gauges
Available in 52mm or 60mm with Black or White face.
1.2 Bar Boost
2 Bar Boost
EGT (Metric)
Fuel Pressure (Metric)
Intake Manifold Pressure (Metric)
Oil Pressure (Metric)
Oil Temp (Metric)
Defi-Link Meter Advance CR 52mm Gauges utilize Defi's next generation, Defi-Link Advance control unit for ultra precise monitoring and interaction. The Advance CR line of 52mm gauges have a built in warning light that will illuminate if any short, sensor failure, or connection failure is detected. Defi also built in a user-determined "peak" and "warning" setting that will illuminate a light to indicate that one of these value has been reached. The Defi Advance CR system able to record and play back gauge display for up to three minutes.
Additional user controllable features of the Defi-Link Advance CR series are illumination color and opening/closing ceremony style. During night-illumination the white faced gauges can either become black faced with blue numbers or black faced with red numbers. Black faced gauges will retain their black background, but will display numbers as white or as amber/red. Opening and closing ceremonies have a "Two-color" or a "Flash" option that is selected through the Advance Control unit.
Features:
  • Defi-Link Advance Control Unit can control up to 7 Defi-Link Meter Advance CR gauges
  • Driving data can be stored and can be replayed up to 3 minutes.
  • Warning by buzzer sound (defeatable) when the warning LED is on
  • Records peak values and warning values during driving
  • Driving data can be stored and replayed up to 3 minutes
  • Differential pressure between fuel pressure and turbo can be shown if both of fuel pressure meter and turbo meter are installed.
  • Flat glass and precise scale give more needle accuracy and higher visibility
  • Opening and closing modes can be selected from two variations
  • The illumination at night can be switched between 2 different colors. (White dial: amber red / blue; Black dial: white / amber red)
  • The outer edge of the gauge illuminates red at night
  • Self-diagnosis system turns the warning LED on to indicate any wire disconnection, short circuit or serial communication error
  • Each Advance CR gauge includes a mounting bracket, meter cup, and regular position bezel
  • Defi-Link Meter Advance CR gauges are METRIC ONLY (kPa/Celsius)
  • Defi-Link Advance Control Unit REQUIRED for Defi-Link Meter Advance CR gauge operation
DEFI Blue/Red/White Racer Gauges
Available in Blue/Red/White face in 52mm
Boost
EGT
Fuel Pressure/Oil Pressure
Water/Oil Temperature
Volt
Racer gauges read out in US Measurements (i.e. PSi, Farenheit, etc.) They feature a 52mm (2 1/16") design, and come with a black face and illumination in blue using high-brightness LEDs. Boost, pressure, temperature, exhaust temperature, and volt gauges are available. Defi Blue Racer gauges are standalone gauges, and do not require the Defi-Link Control Unit for use.
Features:
  • Does not require and can't be used with the Defi-Link Control Unit
  • Ignition ON initiates self-luminescence gauge.
  • Lightning-like Opening / Closing mode with Blue illumination using high-brightness LEDs
  • Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup.
  • The red triangle of the regular position bezel can be used as a warning indicator.
  • Full 270 degrees sweep dial provides ultimate visibility.
  • All Gauges are 52mm (2 1/16")
  • Temperature gauge used for Water or Oil- Pressue Gauge used for Fuel or Oil
DEFI Meter BF
Available in 60mm with Red or White face
Boost
EGT
Fuel Pressure
Oil Pressure
Oil Temp
Water Temp
Defi-Link Meter BFs are electronic blacked out gauges which feature high response and refined design. When the car is off they display a flat black face. As soon as the car is turned on, the gauges light up and are in full affect. Defi-Link Meter BFs need to be connected to Defi-Link Control Unit II. Up to 6 gauges can be connected and controlled by one Control Unit II. The name of the connection system is "Defi-Link System." Defi-Link System allows gauges to be attached to Defi-Link Control Unit II with a single "DAISY CHAIN" wiring system. These gauges display in KPA and Celcius units.
  • Features:
  • Brightness adjustment: 10 stages of brightness, 5 stages in the daytime and 5 stages at night.
  • Double Warning function by a meter's LED lamp and a beep
  • If Defi-Link Indicator(sold separately) is connected, it blinks when any of connected meters' warning LED light.
  • Defi-Link Indicators can be connected to each gauge.
  • Differential pressure between fuel pressure and turbo can be shown if both of fuel pressure meter and turbo meter are installed. Gauges have peak hold and warning features
  • All Gauges are 60mm
  • Defi-Link Control Unit II is necessary to operate Defi-Link Meter BF.
DEFI Gauge Pods and Link Controllers
DEFI Link Control Unit II
Up to 6 gauges can be connected and controlled by one Control Unit II. The name of the connection system is "Defi-Link System." Defi-Link System allows gauges to be attached to Defi-Link Control Unit II with a single "DAISY CHAIN" wiring system. These gauges are measured in PSI and degrees fahrenheit.
Required for Defi BF Series Gauges. Can control up to 6 Defi BF meters at one time.
DEFI Advanced Control Unit
Required for Defi-Link Advance CR Gauges. Can control up to 7 Defi Advance CR meters at one time. Advance CR Control Unit includes remote.
__________________
[COLOR=Black]
[B]Email: [/B]
Old 02-05-2010, 11:57 AM   #3
subaruwrxparts.com
Member#: 26010
2006 STi
DEFI 02-07 WRX/STi 3 Meter Unpainted Hood 60mm
This gauge pod comes unpainted, it is painted with a grey primer only, we suggest using model paint from a hobby shop to paint this hood. By far the best looking pod when done correctly. Gauges face the center they do not face the driver.
STRI DSD-SLM II Gagues
Available in 52mm or 60mm with Smoked Amber or White lens
Boost
Boost 3 Bar
EGT
Water Temp
Fuel Pressure
Oil Pressure
Oil Temp
Tachometer
Volt
DSD (digital stepper drive) is Controlled and operated by an Advance Digital Microprocessor, and is Stepper Motor Driven (PM Type Gearless). Micro Stepping Movement creates high resolution and accurate readings. Super high torque maintains the pointer accurately in toughest racing environments and prevents pointer from overshooting at high-speed movements. Fast response eliminates reading lag with real time display. DSD gauges are gearless resulting in noiseless operation and durability.
*Note: Unlike conventional gear type stepper motors which are noisy and respond in slower reaction speed, DSD stepper motors have been test proven in the toughest vibration environments which is a general characteristic of race tuned vehicles.
Features:
  • Open / Closing Ceremony in sequences
  • 270 Degree Sweep Wide viewing angle for higher resolution reading
  • Warning Setting - User Preset User preset warning values, alarm by LED
  • Peak Recall On demand, view highest value achieved
  • Automatic Self Calibration - Each DSD meter is equipped with self calibration function that resets the pointer position after each installation. Or can be manually activated by shutting off the constant power source.
  • Short-Circuit Auto Detect if the sensor wire is incorrectly connected or the signal extension wire cut, the meter will detect the error and alarms the driver. (Backlighting will go off / pointer flashing)
  • Dimmer (DSD-SLM II Only) Reduce backlighting brightness for night time driving.
  • Extreme Accuracy Racing Spec Sensors All DSD are equipped with racing spec sensors for accurate reading.
  • Gorgeous Titanium Color Finish Casing
STRI Full Auto Turbo Timer
Stri Auto Timer is one of the smallest timers on the market. The unique multi angle joystick control button allows easy operation. Stri Auto Timer smartly utilizes the factory O2 sensor to display theoretical air fuel ratio. Additional features such as voltage display and user preset low voltage warning. A manual timer mode is also built in for users to preset a desire after idling time. Handbrake safety feature shuts off the vehicle when the handbrake is released without the ignition key.
Ultra Slim Design
Controller Dimension: 76 x 36 x 14 mm
Comes in Flat Black or Gunmetal
ATI Center Dash Pod 52mm-60mm 02-07 WRX/STi
ATi clock pods feature a punch out design that allows you to increase the diameter to accommodate 52mm or 60mm gauges in the same pod, this means you can mix and match 52mm and 60mm gauges. There are optional face plates to customize you pods look. This gauge pod is painted by ATi to match the interior. Gauges face the center they do not face the driver.
ATI Center Dash Gauge Pod Faceplate for 02-07 WRX/STi
Customize your ATi gauge pod with these optional face plates available in Blue, Chrome, & Carbon Fiber. These face plates are to be used with the ATi Triple Gauge Hood only. They mount very easily to the gauge hood utilizing 4 small tabs that snap into place.
Comes in Blue, Carbon Fiber or Chrome
ATI ezPod Center Dash Gauge Pod 60mm 08+ WRX/STi
This ezPod is on the passenger side of the dash and is angled towards the driver. It holds 3 60mm gauges and is color and texture treated to match the interior. It uses double sided tape to secure into place.
ATI 52mm or 60mm Gauge Column 02-07 WRX/STi
This gauge pod comes in a black plastic finish only. This Pod allows rotational and tilt positioning for any viewing angle. This is a direct swap and does include the bottom section replacing the plastic on top of you steering column. Fancy pod, that is well worth the extra money. (Warning may slightly cover some stock gauges).
__________________
[COLOR=Black]
[B]Email: [/B]
Old 02-08-2010, 03:42 PM   #4
subaruwrxparts.com
Member#: 26010
2006 STi
Best deals on AEM UEGOs! All SPEC Clutches shipping for free this week!
__________________
[COLOR=Black]
[B]Email: [/B]
Old 02-11-2010, 02:32 PM   #5
subaruwrxparts.com
Member#: 26010
2006 STi
Adding even more product lines to our inventory. Does your local dealership carry as many performance parts as our Subaru dealership ?
__________________
[COLOR=Black]
[B]Email: [/B]
Old 02-11-2010, 02:46 PM   #6
jsnm
Member Sales Rating: (33)
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
whats the best price on the uego shipped?
jsnm is offline
Old 02-15-2010, 03:45 PM   #7
subaruwrxparts.com
Member#: 26010
2006 STi
Bump for Monday!
__________________
[COLOR=Black]
[B]Email: [/B]
Old 02-17-2010, 03:20 PM   #8
subaruwrxparts.com
Member#: 26010
2006 STi
AEM UEGO's at low pricing, we will beat or match prices!
Nick
__________________
[COLOR=Black]
[B]Email: [/B]
Old 02-22-2010, 03:23 PM   #9
subaruwrxparts.com
Member#: 26010
2006 STi
Monday bump!
__________________
[COLOR=Black]
[B]Email: [/B]
Old 02-25-2010, 01:16 PM   #10
subaruwrxparts.com
Member#: 26010
2006 STi
AEM Widebands always in stock and the best pricing! We'll beat or match!
__________________
[COLOR=Black]
[B]Email: [/B]
Old 02-26-2010, 04:44 PM   #11
subaruwrxparts.com
Member#: 26010
2006 STi
__________________
[COLOR=Black]
[B]Email: [/B]
Old 03-01-2010, 10:16 AM   #12
emsfd125
Member Sales Rating: (1)
Member#: 226975
2005 STi FULLY BUILT
Jr Tuned yo!
whats best deal u can do on AEM UEGO and AEM DIGITAL BOOST GAUGE SHIPPED
emsfd125 is offline
Old 03-01-2010, 11:44 AM   #13
oly kenji
Member Sales Rating: (12)
Member#: 211299
2005 STi
going into 2001 gc
price shipped on red racer boost and aem uego to 985167 please
oly kenji is offline
Old 03-01-2010, 03:21 PM   #14
subaruwrxparts.com
Member#: 26010
2006 STi
Replied to both.
Nick
__________________
[COLOR=Black]
[B]Email: [/B]
Old 03-02-2010, 03:04 PM   #15
subaruwrxparts.com
Member#: 26010
2006 STi
Wholesale pricing on every OEM Replacement part 100% of the time. No gimmicks, no one day sales, just wholesale pricing every day of the year! Exeter Subaru/SubaruWRXparts.com gets our Subaru stocking order daily with thousands of parts in stock all the time. Contact us today with your requests!
__________________
[COLOR=Black]
[B]Email: [/B]
Old 03-04-2010, 04:41 PM   #16
subaruwrxparts.com
Member#: 26010
2006 STi
Bump!
__________________
[COLOR=Black]
[B]Email: [/B]
Old 03-09-2010, 03:56 PM   #17
subaruwrxparts.com
Member#: 26010
2006 STi
Gauge combo packages available. Let us know what you need and we'll get it for you!
__________________
[COLOR=Black]
[B]Email: [/B]
Old 03-15-2010, 01:53 AM   #18
marc10
Member Sales Rating: (5)
Member#: 141000
2006 Impreza Wrx Ltd
Defi blue racer guage shipped to 06109..also does the mount that comes with it like this and shell?http://www.celticmotorsport.com/catalog/images/08BG.JPG
marc10 is offline
Closed Thread
AEM UEGO | DEFI | STRI | SPT and more! subaruwrxparts.com Gauges & Electronics 15 09-07-2010 12:39 PM
Great pricing on STRI, Defi, OEM parts and Accessories, AEM!!!!! subaruwrxparts.com Gauges & Electronics 7 10-29-2009 12:50 PM
Great pricing on Zenesis Alarms/Starters, Defi, STRI, and more!!! subaruwrxparts.com Interior/Dressup/Audio & Security 6 10-29-2009 12:50 PM
Great prices on great gift ideas! JnJassociates Interior/Dressup/Audio & Security 0 11-23-2007 09:06 AM
!!!Great Price on Audiobahn AW1200 Subs!!! MY99 2.5GT Car Audio, Video & Security 0 05-03-2001 01:19 PM
