Old 02-05-2010, 05:29 PM   #1
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Default Instructions on removing A6 front axles
CN: 2000 Audi A6 quattro 2.8L instructions on removing both front driveshafts please.
OK OT, I'm asking you to do my homework.
My girlfriend's 2000 A6 Quattro (2.8L) needs both front CV boots replaced. Being the lazy bastard I am instead of doing the annoying and messy job of putting new boots on I simply bought two new front axles. Problem solved!
I had plans to do this work myself but have been traveling like a mad man and haven't had the time. Thankfully my girlfriend's father stepped up to the plate and is going to do it for her (us) this weekend.
I know how the whole thing works. In other words...I was going to wing it with no formal instructions. I've done this job on many other cars in the past.
However, per the request of her father, he wants some written instructions on the process. I've found a couple examples online but most of them are from crappy ask.com or how.com or other garbage things.
I did a quick search on the Audi forums and didn't come up with any great results.
I'd LOVE to be able to print out these instructions from work as my printer at home isn't working. And I've got a deadline on a couple items so can't do the searching right now at work.
So...OT...will you find me a good set of instructions on how to do this?
IB the time it took you to post this I could have found them
IB do your own homework
IB pictures of gf or dad
Reciprocity is offline   Reply With Quote
Old 02-05-2010, 05:30 PM   #2
RaceCarRiot
Member#: 6542
1997 Ver IV
RaceCarRiot is offline   Reply With Quote
Old 02-05-2010, 05:30 PM   #3
nickgomez
Member#: 16820
88 535i
alpinweiss
Drive Axle, Removing and Installing
Removing
* Remove hubcap, for light-alloy wheels pull off center cap (use pulling hook in vehicle tools).
* Loosen hex bolt for outer joint of drive axle a maximum of 90 (vehicle is standing on its wheels).
* Remove wheel.
* Thread in all five wheel bolts again.
* Remove hex bolt for outer joint of drive axle (vehicle has been raised using a lift). (if necessary, have a second technician operate brake)
* Unscrew drive axle from flange shaft/transmission.
1. hexagon socket head bolts
o Pull cable of ABS wheel speed sensor out of bracket on brake caliper (arrow).
o Pull ABS wheel speed sensor slightly out of wheel bearing housing.
* Remove nut -1- and hex bolt, and lift out both control arms -2-.
* Slits in wheel bearing housing may not be widened with a chisel or similar tool!
Note: Do not remove bolts -3- and -4-, otherwise the adjustment of the front axle will change!
* Swing away wheel bearing housing toward side, in direction of arrow.
* Remove drive axle.
Installing
* Insert drive axle into wheel bearing housing.
* Insert both upper control arms, tighten nuts to 40 Nm .
* While tightening, press control arm as far as possible in the direction of the wheel bearing housing.
* Bolt drive axle onto transmission.
* Tightening torques: M8 = 40 Nm , M10 = 70 Nm .
* Press ABS wheel speed sensor into wheel bearing housing until impact and insert cable into bracket on brake caliper.
* Bolt in outer joint of drive axle
Note: Vehicle must not contact ground when tightening outer joint of drive axle.
A second technician is required for the next work step:
* Technician 1: sits in car and operates the foot brake
* Technician 2: tightens hex bolt for drive axle Hex bolt M 14: 115 Nm
Hex bolt M 16: 190 Nm
* Mount wheel.
* Tighten hex bolt for drive axle. Only tighten when vehicle is standing on its wheels: accident danger. Hex bolt M14: 115 Nm + turn another 180
Hex bolt M16: 190 Nm + turn another 180
nickgomez is offline   Reply With Quote
Old 02-05-2010, 05:33 PM   #4
KidCorporate
Member#: 199947
Step 1:
Get out your checkbook.
Step 2:
Kiss it goodbye.
KidCorporate is offline   Reply With Quote
Old 02-05-2010, 05:35 PM   #5
VpointVick
Member#: 93193
'03 325iT
Mysticblau
http://audiworld.com/tech/
Scroll down to "Changing a front axle on a B5".
Should hook him right up.
VpointVick is offline   Reply With Quote
Old 02-05-2010, 05:45 PM   #6
acke61
Member#: 226553
2003 mkIV vw
Make sure you have
and
http://www.germanautoparts.com/Tools...+bearing+tools
edit: you can get the 17mm axle socket on there too...usually the triple square is hard to find locally if you dont have it, i know napa and advance auto dont carry them.
If you need one right away i know the snap on guy does carry them in his truck.
acke61 is offline   Reply With Quote
Old 02-05-2010, 06:12 PM   #7
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
You all are to be commended for the responses.
Old 02-05-2010, 06:24 PM   #8
alacrity024
Review Crew
Member#: 49476
if there is a spring pin holding the axle against the transmission, you will need an appropriate size punch and a lot of tricep strength.
alacrity024 is offline   Reply With Quote
Old 02-05-2010, 06:26 PM   #9
Howl
Member#: 57830
Howl is offline   Reply With Quote
Old 02-05-2010, 06:27 PM   #10
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
I have nothing more to add than "you did the right thing" by buying new axles. CV boots are a bitch.
cucamelsmd15 is offline   Reply With Quote
Old 02-05-2010, 06:48 PM   #11
psi365
Member#: 120001
08 LGT spec B
QSM
tools;
17mm allen
6mm allen (preferably a 6mm 3/8 drive long ball socket allen)
10mm triple square (again a long version works best here)
varying 3/8 extensions (a 2' 3/8 extension comes in real handy)
3/8 socket wrench or 3/8 impact
1/2 drive socket wrench and impact wrench
17mm socket (for the lug bolts)
If no one else is around do the method they suggest in loosening the allen bolt that holds in the drive shaft into the hub.
If someone is there take off the wheel, install 2-3 lug bolts to hold the rotor in place to the hub. With both front wheels off of the ground have someone hold on the brakes and loosen those 2 17mm allens.
After both the 17mm allens are loosened make it so that both front wheels are off of the ground and cycle the key (turn it on and then off but do not remove the key from the ignition). Remove which ever side shield (if not both at the same time) that cover the inner CV joint of the axle with the 6mm allens (3 for each shield). Now you should be able to see the 6 triple square per inner axle bolts. Remove all 6. Now move the inner axle joint as high and as far forward as you can. Steer the wheel in opposite direction of the axle you are pulling (so if you are doing the driver's side steer the front wheels to the right and vice versa). thread in the old 17mm slightly so you can push on the outer joint. With the inner as far forward and as high as you can get it you should be able to sneak the entire axle assembly out by then moving the outer cv joint around some and **** it out towards the rear of the car. You can do this without removing any suspension or brake parts on a 2.8L.
Install in reverse order.
psi365 is offline   Reply With Quote
Punctured gas tank! need instructions on removal a1autosports Service & Maintenance 12 02-11-2007 12:38 AM
Instructions on removing front bumper on 05" STi Gecks Interior & Exterior Modification 0 07-23-2005 02:46 PM
Instructions on removing and installing starter. Dre2932 Normally Aspirated Powertrain 4 08-23-2004 08:29 PM
Need some specific instructions on removing turbo exhaust housing. lupohki Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 07-07-2004 01:56 PM
Any instructions on removing heads? Eric SS Normally Aspirated Powertrain 4 08-21-2001 02:14 PM
