Old 02-05-2010, 08:49 PM   #1
Cobb Tuning
Member#: 4803
Default COBB Tuning Surgeline: Weekly Customer Tunes (1/30-2/6)
2.5L w/HTA68 tuned with AccessPORT
Ambient Temp: 49 F Daily Average
Elevation: Approximately Sea Level
Weather: Indoor
2006 Subaru STi
Tuner: Tim Bailey
Dyno Info: Mustang AWD-500
Peak HP at RPM: 336 [email protected]
Peak Torque at RPM: 365 [email protected]
Baseline hp/tq for a stock on same dyno: 2010 STi: 239 WTQ, 228 WHP
Target Boost: 21 PSI
Target AFR: 11.1:1
Fuel: Pump 93 Octane
Engine/Power Modifications:
- COBB Tuning AccessPORT
- FP HTA68 w/8cm Hotside
- Perrin Turboback
- Gruppe-S UEL Manifold
- Greddy Up Pipe
- 73mm Cold Air Intake
- Gimmick Motorsports Turbo Inlet
- Spearco TMIC
- Walbro Fuel Pump
- Deatschwerks 740cc Injectors
- JDM TGV Deletes
- Prodrive BCS
- Phelonic Thermal Intake Spacers
- Forge Recirculating BOV
Old 02-05-2010, 08:49 PM   #2
Cobb Tuning
Member#: 4803
Default 3.5L (VQ35DE) tuned with AccessPORT
Ambient Temp: 48 F Daily Average
Weather: Indoor
2003 Nissan 350Z
Tuner: Tim Bailey
Peak HP at RPM: 280 [email protected]
Peak Torque at RPM: 243 [email protected]
Target AFR: 13.5:1
Fuel: Pump 92 Octane
- Brian Crower 264 Cams
- Intake Plenum Spacers
- Long Tube Headers
- Catless Exhaust
- Ported Heads
Old 02-05-2010, 08:50 PM   #3
Cobb Tuning
Member#: 4803
Default 2.0L w/20G tuned with AccessPORT
Weather: Indoor
2004 Subaru WRX
Tuner: Tim Bailey
- 20G Turbo
- Walbro Fuel Pump
- Deatschwerks 1000cc Injectors
- Perrin Downpipe
- Perrin Catback
- Perrin Up Pipe
- K&N Typhoon Cold Air Intake
- AVO Top Mount Intercooler
Peak HP at RPM: 281 [email protected]
Peak Torque at RPM: 264 [email protected]
Target Boost: 19 PSI
Target AFR: 11.5:1
Peak HP at RPM: 299 [email protected]
Peak Torque at RPM: 289 [email protected]
Target AFR: 8:1
Fuel: E85
Old 02-05-2010, 08:52 PM   #4
Cobb Tuning
Member#: 4803
Default 2.3L (MS6) w/K04 tuned with AccessPORT
Weather: Indoor
2006 Mazdaspeed 6
Tuner: Tim Bailey
Peak HP at RPM: 272 [email protected]
Peak Torque at RPM: 314 [email protected]
Target AFR: 12:1
- Upgraded TMIC
- COBB Tuning SF Intake
- Turbo Inlet
- 2nd Cat Deleted
- 80mm Catback
Old 02-05-2010, 08:52 PM   #5
Cobb Tuning
Member#: 4803
Default 2.5L w/VF43 tuned with AccessPORT
Weather: Indoor
2006 Subaru WRX
Tuner: Tim Bailey
Peak HP at RPM: 303 [email protected]
Peak Torque at RPM: 344 [email protected]
Target Boost: 18 PSI
Target AFR: 11.5:1
- VF43
- APS TMIC
- Injen CAI
- Invidia Turboback
Old 02-05-2010, 08:53 PM   #6
Cobb Tuning
Member#: 4803
Default 2.5L w/DOM 4.0 tuned with AccessPORT
Weather: Indoor
2006 Subaru WRX
Tuner: Tim Bailey
Peak HP at RPM: 418 [email protected]
Peak Torque at RPM: 333 [email protected]
Target Boost: 22 PSI
Target AFR: 11.5:1
- DOM 4.0
- 850cc Injectors
- Walbro Fuel Pump
- FMIC
- Built Motor
- Turboback Exhaust
Old 02-05-2010, 08:59 PM   #7
Cobb Tuning
Member#: 4803
Here are the results of COBB Tuning Surgeline's tunes for this week. Hopefully you guys don't mind a couple non-Subarus thrown into the mix
Feel free to ask any questions.
Old 02-05-2010, 09:16 PM   #8
Bailey
Member#: 12572
2004 STi
35R is enough
I'm happy to share data logs of technical details of any tune above. Free free to post here and tell me what you'd like to see.
Regards
Tim Bailey
Bailey is offline   Reply With Quote
Old 02-05-2010, 10:09 PM   #9
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
RE: 2.0 / 20G tune
Looked through your database and the vast majority of 2.0L 16G EvoIII graphs are showing superior all around. Obviously a 16G EvoIII will offer better performance before the 20G reaches max boost, but most of these plots also showed higher or equivalent peak HP as well. I was comparing pump plots to pump plots.
Any indication what might have been holding that 2.0L / 20G back?
Concillian is offline   Reply With Quote
Old 03-01-2010, 04:57 AM   #10
CALI07TR
Member#: 136837
07 WRX TR
Weather: Indoor
2006 Subaru WRX
Tuner: Tim Bailey
Target AFR: 11.5:1
- VF43
- APS TMIC
- Injen CAI
- Invidia Turboback
Did this car have stock injectors ? those are real good numbers for the mods on the car . how much lower would the power be with 91 oct and an STI TMIC ?
CALI07TR is offline   Reply With Quote
Old 03-01-2010, 08:36 AM   #11
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
Weather: Indoor
2006 Subaru STi
Tuner: Tim Bailey
Target AFR: 11.1:1
- Perrin Turboback
- Greddy Up Pipe
- Spearco TMIC
- Walbro Fuel Pump
- JDM TGV Deletes
- Prodrive BCS
Why is the 8cm 68HTA on a 2.5L tuned on 93 octane so close to the VF43 (on a 2.5L) despite the VF43 being tuned on 92 octane? Both cars also have similar TMICs, so its not the intercooling. . . .
scramjett is offline   Reply With Quote
Old 03-01-2010, 12:36 PM   #12
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
uhh... the HTA 68 is like +25-30 HP. That's pretty typical for the difference between a vf48 / vf39 and an HTA68. I usually consider an HTA68 to be a vf39 +20-25 HP, so it's getting a little extra.
check out the other HTA68s in their database, these are pretty typical differences between these two turbos.
Old 03-02-2010, 07:33 AM   #13
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
But its supposed to be the new 20G... Glad I didn't jump onto the turbo of the month band wagon!
Anyway, nice tune on the VF43 and too bad you guys aren't in my area, otherwise I'd you have you tune my 48 before I drop in the 20G I have in my garage. I'd love to see a 1:1 comparison on the same car with the only difference being the turbo.
Old 03-03-2010, 05:08 PM   #14
LittleBlueGT
Member#: 96204
2013 STI GR
Can you comment on differences on performance on the hta68 7cm vs 8cm hotside?
Thanks
LittleBlueGT is offline   Reply With Quote
COBB Tuning Surgeline's Week in Tunes! 5/17-5/21- COBB Tuning STi + 2010 Forester XT! Cobb Tuning Proven Power Bragging 12 06-12-2010 06:50 PM
COBB Tuning Surgeline's Week in Tunes! 5/10-5/14- Subaru Edition v2 Cobb Tuning Proven Power Bragging 7 05-18-2010 12:49 AM
COBB Tuning Surgeline: Weekly Customer Tunes (2/6-2/12) Cobb Tuning Proven Power Bragging 19 02-15-2010 05:13 PM
COBB Tuning Surgeline: Weekly Customer Tunes (1/23-1/29) Cobb Tuning Proven Power Bragging 16 02-02-2010 07:07 AM
COBB Tuning Surgeline: Weekly Customer Tunes (1/18-1/22) Cobb Tuning Proven Power Bragging 15 01-30-2010 07:33 PM
