Old 02-05-2010, 09:45 PM   #1
mack519
Member#: 230440
2006 WRX TR
Default Reglueing window weather stripping
hey my 06 WRXs rear passenger doors window weather stripping is coming off like crazy and causing some mad wind noise coming through. I keep having "dig" the stripping back into the channel but after a day or so its back to being off the track. How can I reglue this weather stripping and what kind of glue can I use?
mack519 is offline   Reply With Quote
Old 02-05-2010, 10:10 PM   #2
pooster.online
Member#: 120461
2004 WRX STi JBP
3m heavy duty double sided tape.
pooster.online is offline   Reply With Quote
Old 02-05-2010, 10:17 PM   #3
Pohenegamook
Member#: 134262
cyka blyat
An 06 - under 36K? If so, warranty glue
Barring that, I vote silicone and not driving for 6-8 hrs
Pohenegamook is offline   Reply With Quote
Old 02-06-2010, 03:05 AM   #4
ayoraider07
Member#: 223688
2004 wrx
I have the same problem with my 04, rear window weather strippin is falling off, exposing metal and making it look like a break-in weak spot..
ayoraider07 is offline   Reply With Quote
Old 02-06-2010, 07:19 AM   #5
PyroX1040
Member#: 223408
2006 STI
On my 06 I finally got fed up with it and decided to remove all my weather stripping on each door and resealed it using Weather Strip Adhesive from the local Napa!!
I used a paint mixing stick to get a good amount of it in there, gotta make sure you create an air-tight seal!
This might be in your future...
PyroX1040 is offline   Reply With Quote
Old 02-06-2010, 09:40 AM   #6
WhiteKnightSTi
Member#: 169250
2001 Schweizer 300CB
(wirlybird)
Yup they make special glue just for attaching weather stripping, you should be able to find it at any autoparts store.
WhiteKnightSTi is offline   Reply With Quote
Window weather strip fell off chimchimm5 Service & Maintenance 13 04-23-2009 12:59 PM
Rear window weather stripping? UGprez Interior & Exterior Modification 15 09-15-2004 11:50 PM
window weather stripping leaks fishfry General Community 0 09-22-2003 12:32 AM
Weather Stripping xtheviperx General Community 1 05-15-2002 12:07 PM
car wash = leaky weather stripping = water in my car M a t t General Forum Archive 10 02-13-2001 12:58 AM
