Old 02-05-2010, 09:51 PM   #1
Motion Lab Tuning
Member#: 228856
Default 2005 Saabaru - stock 2.0 - Super16G - 352/304 whp/wtq - 93 octane
For reference the lower dashed lines were tuned on a competitor's Mustang dyno. We used that as our baseline pull. When it was tuned by the previuos shop it made 312whp. Our base-line run showed 308whp so the dynos were pretty darned close.
Saab 92x, aka just a WRX reskined in Saab panels.
Event: Dyno Tune
Ambient Temp: 40 F
Elevation: 900 ft. ABS
Weather: Cloudy / Rain
Tires: N/A
Car: Saabaru 92x 2.0L
Tuner: Todd @ Motion Lab Tuning
Dyno Info: Mustang 500
Peak HP at RPM: 352whp @ 6520rpm (SAE Corrected)
Peak Torque at RPM: 304ft.lbs @ 5560rpm (SAE Corrected)
Baseline hp/tq for a stock on same dyno: 180whp
Target Boost: 24 psi
Target AFR: 11.8:1
Fuel: 93 octane unleaded
Engine/Power Modifications:
3'' high flow downpipe
06 blue injectors (650)
STi fuel regulator
Walboro 255 fuel pump
Deadbolt Super 16g (port/polish)
TGV (port/polish)
CAI
Turbo intake
UEL headers
STi gutted catback
Driveline Modifications: Factory
Suspension Modifications: Unknown
Motion Lab Tuning is offline   Reply With Quote
Old 02-06-2010, 08:42 AM   #2
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
Big power with small injectors. What gas?
No problem pegging the stock MAF?
mapleleaf is offline   Reply With Quote
Old 02-06-2010, 08:56 AM   #3
Motion Lab Tuning
Member#: 228856
Oops. Yeah it's an APS 70mm. For got to mention that above. Will edit the first post to reflect that. The injectors were maxed.
Old 02-06-2010, 12:09 PM   #4
heavyduty
Member#: 216273
05 9-2x
Hey Todd,
Thanks again for spending so much time and diligence on my tune. I never could have imagined getting those numbers and still having a good safe tune. Everyone I have spoke with is blown away. It is wicked fast and as long as I can keep the pokee of my tail should be fun for years to come. I could not be more pleased.
The tune was on 93 pump gas. Im running headers as well.
heavyduty is offline   Reply With Quote
Old 02-06-2010, 12:30 PM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
was the previous tuner scared to run any boost? looks like you just added 4 psi across the board.
Old 02-06-2010, 01:41 PM   #6
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Pics of the car?
Splinter is offline   Reply With Quote
Old 02-06-2010, 01:56 PM   #7
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
He added about 15% power.
It's reasonably common for a conservative tuner to consider 85% injector duty cycle maxed, so I wouldn't be too surprised at someone being uncomfortable stopping there.
The OP says the injectors were maxed, so this is my assumption... some tuners are comfortable with 95+% duty cycles, other tuners are not. I don't think I've seen any engine issues attributable with high duty cycles, but still, I'm not sure I'd fault a tuner for wanting to keep some margin in the injectors.
Now I admit, I don't know the whole story, but playing devil's advocate, I can certainly see at least one reason why the previous tuner wouldn't have pushed. Though if this were the case, you'd probably see some kind of boost taper so he could get to high duty cycles earlier, then maintain. And you'd expect the spool-up range to be better tuned, so
Concillian is offline   Reply With Quote
Old 02-06-2010, 05:30 PM   #8
absolutexk
Member#: 91530
2005 WRX
What turbo??
absolutexk is offline   Reply With Quote
Old 02-06-2010, 05:36 PM   #9
1cleenwrx
Member#: 170542
08 AGILEbuilt-STI
93Soarer/01RSTI/06SPEC-B
nice!
1cleenwrx is offline   Reply With Quote
Old 02-06-2010, 05:53 PM   #10
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Originally Posted by absolutexk View Post
What turbo??
TD05 big 16G
Old 02-06-2010, 06:14 PM   #11
JazzyJake
Member#: 153476
2005 VF39 6spd FXT
Originally Posted by Splinter View Post
Pics of the car?
This.
JazzyJake is offline   Reply With Quote
Old 02-06-2010, 06:26 PM   #12
absolutexk
Member#: 91530
2005 WRX
Originally Posted by juanmedina View Post
lol.. i totally missed that part... These Saabaru's arent they the 2.0L, how the hell did you get 350whp out of a 16g?
Old 02-06-2010, 07:01 PM   #13
heavyduty
Member#: 216273
05 9-2x
It is a deadbolt super 16g ported and coated, pushes about 10 cfm less than a 18g. Unless I am mistaken Todd said the duty cycle on the injectors did not exceed 87%. Maybe 87% is maxed out as far as his tunes are concerned but I am just guessing. It is a 2.0, I port matched and polished everything even a little on the heads. Wrapped everything from block to dp,turbo blanket, even wrapped the intake. I,m running the biggest top mount I could fit, even had to put rubber on my A/C lines to keep from rubbing. I,m running a walbro but a sti fuel regulator which increses the amount of fuel that is available. the 650's are DW and so are spot on. All that and one hell of a tuner and there have it.
Old 02-06-2010, 07:05 PM   #14
heavyduty
Member#: 216273
05 9-2x
And about the pics. I wouldnt hold your breath, the weather here is some kind of nasty and I'm not posting pics of my filthy ride. Its silver, do a search for Saab 9-2x it looks pretty much the same, nothing to fancy.
Old 02-06-2010, 07:07 PM   #15
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
what tranny?
Brother EddieJ. is offline   Reply With Quote
Old 02-06-2010, 07:10 PM   #16
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Hell of a sleeper then
Old 02-06-2010, 07:16 PM   #17
bearpaws1973
Member#: 145025
1992 Typhoon
06 wrx built to the hilt!
Awesome! That is a perfect setup for the 2.0. Everything looks great and I bet it is a blast to drive!
bearpaws1973 is offline   Reply With Quote
Old 02-06-2010, 07:46 PM   #18
absolutexk
Member#: 91530
2005 WRX
no wonder! great set up, great power man!
Old 02-07-2010, 01:01 PM   #19
heavyduty
Member#: 216273
05 9-2x
Thanks for all the compliments. The tranny is the stock 5 speed. I'm going to keep the stock clutch so I can keep the stock 5 speed, if you know what I mean.
Old 02-07-2010, 02:28 PM   #20
boston_errol
Member#: 179007
2005 Legacy GT Wagon
ABP
Post the car up on saab92x.com!
boston_errol is offline   Reply With Quote
Old 02-07-2010, 05:43 PM   #21
heavyduty
Member#: 216273
05 9-2x
Why I think I will do just that.Thank you Sir.
Old 02-07-2010, 05:52 PM   #22
AnthonyA182
Member#: 59990
2011 WRX Hatch
nice numbers man, what are you tuned on? opensource?
AnthonyA182 is offline   Reply With Quote
Old 02-09-2010, 09:27 AM   #23
subydude02
Member#: 140643
04' PSM Limited Wrx
371whp/344wtq E85
I was here for this thing getting tuned. this sucker held power to redline like a champ. 2.0 ftw! i was blown away, here i show up with my new 2.5 block i just installed and this guy blows me away with his stock 2.0 Great job Troy, you really know your stuff and i loved your car, thanks for helping me install that 3-port
subydude02 is offline   Reply With Quote
Old 02-09-2010, 04:18 PM   #24
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Open for bidness
Audiosavvy is offline   Reply With Quote
Old 02-09-2010, 11:01 PM   #25
Silver_Bell_WRX
Member#: 7677
2005 WRX
Nice numbers.. I like the fact that you are pushing 24psi on regular 93 pump gas.
Silver_Bell_WRX is offline   Reply With Quote
Crawford 2.7L + GT35R = 560/565 whp/wtq for NNI Racing Crawford Performance Proven Power Bragging 17 04-29-2010 10:17 AM
Evo warning... 674 whp on 93 octane + meth Innovative Tuning Proven Power Bragging 54 12-28-2009 12:34 AM
Most WHP on stock 2.0 BEAT(Pretty sure) Blanka725 Proven Power Bragging 19 01-17-2005 02:48 AM
New Record! 407 WHP on 93 octane! Tuning Factory Inc. Proven Power Bragging 61 07-29-2004 08:22 AM
Nasty Burnout Video: Not a Subaru, a Nissan 2.0 liter w/ 400+ WHP! BrysImpreza New England Impreza Club Forum -- NESIC 2 05-23-2003 08:29 PM
