Old 02-06-2010, 12:12 AM   #1
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
Default Outback Sport VF37 EJ207 Version 8 Dyno @EFI Logics
Car: 2004 Subaru Impreza Outback Sport
Owner: Jordan
Tuner: Chris from EFI Logics
Dyno Info: Mustang
Peak HP at RPM: @ 6700rpm
Peak Torque at RPM: @ 6200rpm
Baseline hp/tq for a stock on same dyno: 125whp
Target Boost: 17psi
Target AFR: unknown
Fuel: Sunoco Sunoco 93 pump
Method: Open Source
What's up everyone. So I posted a little early but I'm getting my 2004 outback sport dynoed and tuned from chris s-k at EFI Logics via open source tomorrow (2/6/10) I will post the results ASAP when I get home from the tune. But in the mean time if people would like to make some estimates on what ill make I would sure like some more ideas on expected power goals.
Mods are...
-20,000km 2004 version 8 JDM STi EJ207
-Twin Scroll VF37 Turbo/manifold/uppipe
-Walbro 255lb/hr
-Invidia N1 Race catback
-Custom Bellmouth Twin scroll catless downpipe
-AMS Oil Synthetic 5w-30
-NGK Irridium 1 step Colder
And I think that's about it...
EFI logics is a mustang dyno. And I am thinking 22psi with 93oct pump gas.
Thanks all and stay tuned!
prokaw875 is offline   Reply With Quote
Old 02-06-2010, 01:31 AM   #2
Deuce Cam
Member#: 130444
'85 AE86 GTS
Sounds cool. I'm interested to see how it does; I love seeing ej207 power.
Deuce Cam is offline   Reply With Quote
Old 02-06-2010, 02:12 AM   #3
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
Thanks dude! Ya, I love my Ver8 207 and have not once regreted the decision over a 257. Letcha know the results tomorrow!
Old 02-06-2010, 04:37 PM   #4
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
So long story short my car wasnt tuned today because of some boost issues that arose during this baseline run. We were getting full boost of wastegate pressure(10ish psi) around 5,000 RPM and just overall a bunch of issues so back to have some troubleshooting done and find out the issue.
Currently the turbo is 110% good because we un plugged the wastegate at hit 25psi around 2,500RPM. Then checked the restrictor pill, vacume lines, wastegate actuator, ect.
I will keep you all posted as when I get my real tune when the issue is resolved hopefully this week.
Old 02-06-2010, 07:09 PM   #5
wichitalegacy
Member#: 116194
sounds like the restrictor pill is on the wrong side of the T. Try swaping them between the compressor and the wastegate
wichitalegacy is offline   Reply With Quote
Old 02-06-2010, 07:40 PM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
You should pick up a EBC for better control. I hate dealing with the stock setup.. bleeding... it's BLEEDING!!!
FuJi K is offline   Reply With Quote
Old 02-06-2010, 08:47 PM   #7
GhoSTI
Member#: 86488
2004 STi
No, it's not. The car was having boost control issues outside of anything mechanical. The person who did the swap is going to be investigating the harness. I was there.
GhoSTI is offline   Reply With Quote
Old 02-06-2010, 09:08 PM   #8
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
Ya, were gonna do a full diagnosis this week and look into everything. I don't think its gonna be having to do with the merge though because the oem controler is getting power and there isn't to much other wiring that could result in the issue... I hope! Eakkkkk :-(
Actuator CHECK, Turbo CHECK, Solenoid CHECK,
Next prolly gonna go into buying a known good restrictor pill and leak test all of the vacume lines. So ill keep ya posted!
Old 02-06-2010, 10:23 PM   #9
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
That's a possibility... I want to speak with my tuner and mechanic before I were to do so because if they perform more similar to an oem set-up that the mbc that my tuner hates to use then that is an option. But... I still need to diagnose and troubleshoot the reason behind these results.
I know this isn't the place and I can "search" but what is the best bang for the buck EBC?
Old 02-06-2010, 10:44 PM   #10
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
So that dyno sheet is at 10 psi?
godforbid67 is offline   Reply With Quote
Old 02-06-2010, 10:51 PM   #11
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
according to the sheet, its leveling out at 13psi. i tuned a car that make 297 on an EJ205 on a mustang dyno, also torque looks really really low
edit after reading it says base line, do you have graphs of the final?
seanathanq83 is offline   Reply With Quote
Old 02-06-2010, 11:46 PM   #12
Airelpaso
Member#: 139566
2004 Forester XT
Gold
He said he was having some problems and didnt get tuned today.
Airelpaso is offline   Reply With Quote
Old 02-06-2010, 11:54 PM   #13
godforbid67
Member#: 137168
06 Built SGM WRX
That looks pretty good for such low boost.
Thing will wake up with 20+ psi also.
Old 02-07-2010, 12:55 AM   #14
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
Ya, no final tune. The sheet provided was at 13.70 psi and my base map I've been driving around.
But yes, I will update of course when I take care of the boost issue and get tuned hopefully in the next week or 2 I'm shooting for.
Old 02-07-2010, 01:48 AM   #15
Nuke209
Member#: 108089
2003 WRX
NF Performance
go ewg
Nuke209 is offline   Reply With Quote
Old 02-07-2010, 09:15 AM   #16
seanathanq83
Member#: 173241
i have noticed on mine that even with a boost controler, and 18psi IWG actuator i start getting an uncontrolable flutter above 20, as of right now i am just staying with 18psi because my clutch is gone, but and decent EBCS will fix your problem right up looks good so far though
Old 02-07-2010, 11:04 AM   #17
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
to the OP, do you have your avcs working?
to sean,
how does this flutter look like in a log? is it something you hear or can tell by looking at logs?
thanks
scoobystas is offline   Reply With Quote
Old 02-07-2010, 11:19 AM   #18
EFI Logics
Vendor
Member#: 193180
The process to test the OP's issue was as follows..
- Installed USDM WRX restrictor Pill in stock location
- Installed working OEM solenoid to test
- Swapped hoses on the solenoid
- Tested wastegate actuator
- Checked hoses to intercooler
- Set max duty cycles in all WG tables in ECU, verified AVCS functionality ECU commanded exact duty cycle, AVCS executed to commanded values in calibration file
- Removed the line to the wastegate to test the turbo Turbo spiked to 20psi in a momentary WOT blurp.
At this point we are under the assumption there is a wiring issue with the car, the original place that did the swap is investigating, and we are working with them to rectify the issue.
Thanks,
Chris
EFI Logics is offline   Reply With Quote
Old 02-07-2010, 12:02 PM   #19
langsbr
Member#: 209630
2002 WRX / V7 STI
3.9USM6 / PSM
Is the 13.7 psi the stock boost level? I know you are having an issue, but what is stock boost level on a v7 or v8?
I've heard 18psi. I just got done with my v7 swap, but I transferred over the manual boost controller I had, and it is set at 14psi.
Wondering if it will go to 18 controlled by the ECU if I put the stock BCS back on.
Nice power for such low boost!
langsbr is offline   Reply With Quote
Old 02-07-2010, 12:21 PM   #20
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
stock jdm sti has targets of around 18lbs. Some of the 05/06 spec c ra are 19lbs if iirc.
Old 02-07-2010, 01:47 PM   #21
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
Originally Posted by Nuke209 View Post
go ewg
Cant run an External Waste Gate on a twinscroll stock location.
Old 02-07-2010, 01:49 PM   #22
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
to sean,
thanks
Yes according to the tuner my AVCS appeared to be working 100%
Old 02-07-2010, 01:54 PM   #23
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
Thanks,
Chris
Thank you Chris and all the guys over at EFI Logics for the help on trying to target the issue. I will be in touch as we find out the issue
Old 02-07-2010, 01:56 PM   #24
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
It was target to be at the OEM JDM STi level of 17psi but only hit 13.7.(17 is stock jdm sti vs 14.5 being stock usdm sti)
And I am trying to stay away from a manual boost controler at all costs... but if there isnt a choice and we have to go that route then I will most likely go with a aftermarket EBC
Old 02-07-2010, 03:02 PM   #25
Nuke209
Member#: 108089
2003 WRX
NF Performance
why no manual boost controller?
