Old 02-07-2010, 02:29 AM   #1
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Default Dyno Tune: 2.5L '09 WRX Completely stock, makes 263whp. <-- dyno reading incorrectly
Event: dyno pull / baseline
Ambient Temp: ~50
Elevation: ~50
Weather: mostly cloudy
Tires: Michelin Pilot Sport A/S Plus, 225/45ZR17
Car: 2009 WRX Sedan
Tuner: None
Dyno Info: Mustang
Peak HP at RPM: 263whp @ ~6200rpm
Peak Torque at RPM: 268wtq @ ~4550rpm
Target Boost: stock
Target AFR: stock
Fuel: pump unleaded 91 (or 92, whatever Oregon sells)
[color=black]Power Modifications: None, all stock. baseline run with 7500miles on the motor.
***EDIT!!!***
Incase you are just comming across this thread, there were some dyno issues.
Latest dyno (which still may be reading a bit on the high side) puts it at 240whp.
Breezio is offline   Reply With Quote
Old 02-07-2010, 02:55 AM   #2
gopsu
Member#: 96448
02 WRX VF34
wow.... pretty impressive number.
gopsu is offline   Reply With Quote
Old 02-07-2010, 03:45 AM   #3
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
wow...
godforbid67 is offline   Reply With Quote
Old 02-07-2010, 09:59 AM   #4
xsnapshot
Member#: 170973
2004 WRX 4EAT
This must be the hopes and dreams dyno.....
xsnapshot is offline   Reply With Quote
Old 02-07-2010, 10:47 AM   #5
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Old 02-07-2010, 10:55 AM   #6
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
wow is that A/F curve safe? it runs really lean from what i can tell up to about 4200rpm and then tapers to 11.3 i guess because dyno sheet says thats the min a/f ratio.
scoobystas is offline   Reply With Quote
Old 02-07-2010, 11:03 AM   #7
Gerkins31
Member#: 52337
meh..
Gerkins31 is offline   Reply With Quote
Old 02-07-2010, 12:25 PM   #8
Breezio
Member#: 234357
2009 WRX
I don't see people complaining about any of the other dyno numbers comming out of CobbTuning/Surgeline.... ?
I thought it was high also, they said it was on the high side, but not much more then they usually get for the 09's.
Safe? Not sure i'd say it's safe or not, it's how it came from subaru. I'd hope they wouldn't release a car that is going to grenade when kept stock. Atleast it does drop to the more 'safe' levels in the higher rpms.
End of summer I'm expecting to do a few things (including tune) to it. We'll see how she does then.
Old 02-07-2010, 12:50 PM   #9
Dragonfueled
Member#: 224941
09 Wrx
Rally blue
Holy crap that's a good running car. My 09 made 259 stage 2 protuned but on a mustang dyno. These 09's sure do run
These cars seem to wake up a bit after 5k miles also. Most dynos I've seen of 09 including mine were with close to 1000 miles lol .
Dragonfueled is offline   Reply With Quote
Old 02-07-2010, 01:06 PM   #10
SVT_WRX
Member#: 164830
G61 III OVE 58e
....with those numbers (if they are accurate) on a mustang dyno, that will put you in the low 13's high-mid 12's with a good driver. I didn't know they had that much power from the factory.... Torque seems right...a little on the high side...but the horsepower.....
SVT_WRX is offline   Reply With Quote
Old 02-07-2010, 01:17 PM   #11
xsnapshot
Member#: 170973
2004 WRX 4EAT
Oh I'm not complaining. I'm just tossing my opinion out there.
Here ya go. Surgeline tuning. Stock 2009 wrx. 92 octane. I doubt this one really makes over 30whp more.
Here's a 2009 STI on their dyno.
Old 02-07-2010, 01:22 PM   #12
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
that sti does not look healthy. must have had a few knock events on the way to redline with the way the power looks like its "pulled" in several rpm regions (3800, 4600, 5400, etc).
to OP, dude enjoy it that motor looks like it loves to make power so mod tastefully
Old 02-07-2010, 01:25 PM   #13
SVT_WRX
Member#: 164830
G61 III OVE 58e
Old 02-07-2010, 01:27 PM   #14
SVT_WRX
Member#: 164830
G61 III OVE 58e
This seems more realistic.
Old 02-07-2010, 01:58 PM   #15
Breezio
Member#: 234357
2009 WRX
That other 09' wrx dyno was pulled on 06/08/09... That had have been practically fresh off the line and next to no miles on it. I could see that having some affect.
EDIT: sorry, totally mis-read that, I thought it said 2008 the pull was done, my bad.
Surgeline said mine was 'high but beleivable'. It's more then I expected, but the car does pull pretty hard (butt dyno). They also said they usually get 250-255whp with the 09's. So I do'nt know what's up with the other dyno posted.
In anycase, I plan to get a couple time slips with it in a few months when the weather clears up. I'm curious what I can get out of it. I'm an ok driver, but haven't ran an awd car on the track yet.
Just thought I'd share and I do want comments and questions, positive or negative.
Old 02-07-2010, 02:07 PM   #16
SVT_WRX
Member#: 164830
G61 III OVE 58e
You may or may not have a factory freak. If you do, be careful with that motor. They have been known to blow pretty quickly STOCK! Perhaps they were "over-tuned" straight out of the factory. There are a few articles out there that indicate the stock 09' WRX is almost as quick, if not quicker than the 09' STI.
Old 02-07-2010, 02:18 PM   #17
Breezio
Member#: 234357
2009 WRX
Yeah, there is a good chance my motor will get broke, but it's because it's built right in the middle of the 'bad' batch
So.. hopefully it doesn't fail like most of the rest from those couples months of build dates, if so, I just hope the new motor will make close to the same power.. lol.
Old 02-07-2010, 02:29 PM   #18
SVT_WRX
Member#: 164830
G61 III OVE 58e
Yep, spun bearings and broken ringlands. Not sure if anyone has tried this yet. If you're up to it, perhaps change your oil to a viscosity of 10w 30-50 as an experiment. You might loose a smidge of MPG....just throwing it out there.
Old 02-07-2010, 03:09 PM   #19
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Breezio, try to drive conservatively. I really thought subaru fixed at least the AFR problem in their cars.
In 2007, they started running a fuel curve just as shown in your graph. 14.0 @ peak torque = death. I wish I lived closer, I'd flash you for free, just to be sure you were not another statistic.
@ 14.0, through 4000RPM WOT, there will be knocking, and on 91 octane especially your motor is doomed. I understand now at least one of the reasons the 09 bearings chit out quick. Knock at full load causes massive stress on them.
I've been through many ordeals, some have been with SOA. If your car is stock, and your motor blows, they will do everything in their power not to warrenty it.
The fact of the matter is, you will most likely win the battle for a covered motor. But I bet the process takes much of your time, not to mention from broken to fixed will be ~ 2 months.
On another note, I wish I could get my hands on one of these 09's. I think they have tons of potential (probably high 11's on the stock turbo). 263 out of the box is a bit much, as on factory calibrated mustang dyno's a stage 2 sti will put 260-265 out, but they are powerful out of the box nonetheless.
STi Mikey is offline   Reply With Quote
Old 02-07-2010, 03:54 PM   #20
Breezio
Member#: 234357
2009 WRX
Well... according to the thread about the 09' bearing problems, SOA has been good at replacing the motors and getting it done within a few weeks, and it's on a specific build date of cars, thus the problem (with the bearing failures atleast) being bearings/crank themselves and not the fuel map.
That's what I'm reading and hearing atleast.
I could see the factory map certainly causing problems if you get a bad batch of fuel or something.
I've been purposefully driving it on the hard side to see if the bearings are going to crap out.. lol.
I suppose we'll see if/when it happens.
I can't imagine SOA winning the fight if the motor blows up under warrenty because of their fuel map, but I haven't dealt with them yet. First subie I had was an 06' Legacy, never had a problem with it.
On the oil comment. You meaning to run the thicker stuff to save the bearings or to make them crap out faster?
I'm currently running Mobile1 5w30.
Old 02-07-2010, 07:40 PM   #21
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
im confused. Surgeline said that thats what there seeing on 09's and its not out of the question? they see no problem with bone stock cars making the same HP to the wheels as the motor makes to the crank????? people at surgeline are sniffing something! not to mention it takes one person one click of the mouse to make a dyno total number read whatever they want!! funny how all other dyno's (mustangs, dynojet ect), magazines, guys posting on forums, you name it!! bone stock are putting down 220-230hp. i highly highly doubt thats the real number. but hey total number doesnt matter. it matters what you do at the strip and what ever you add on go back and see the increase in power.
P.S. bone stock 09's are running 13.3qt miles. if you really do have 263hp then i need to see 13.0 at least!
synolimit is offline   Reply With Quote
Old 02-07-2010, 07:51 PM   #22
AnthonyA182
Member#: 59990
2011 WRX Hatch
If you don't want spun rod bearings I'd switch over to a different oil IMMEDIATELY. Mobile1 does not agree with these motors. There are a ton of threads about it if you search. Just FYI but it sounds like even if your motor does go your build date guarantees you'd probably get a new motor lol
AnthonyA182 is offline   Reply With Quote
Old 02-07-2010, 07:59 PM   #23
CatfaceType-R
Member#: 81102
no way, not on a mustang dyno at least; that's stronger than some stage 2's
CatfaceType-R is offline   Reply With Quote
Old 02-07-2010, 08:11 PM   #24
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Not 100% sure about this. I see the threads, and hear the gossip about motor failures and mobil 1.
But I ran mobil 1 in an 04 STi for 65k, and in an 07 STi for 60k. However, I have to agree about the oil literally having the viscosity of water. This is a characteristic that tends not to agree with some of our motors.
Old 02-07-2010, 08:16 PM   #25
FSTASNTZ
Member#: 233615
2010 WRX Base
Are these the non-corrected numbers? If so do you happen to have the corrected numbers? They should be slightly lower.
FYI, my 2010 with 1005 miles dynoed at:
236.2 HP & 243.0 TQ
With correction that came to:
227.4 HP & 234.1 TQ
FSTASNTZ is offline   Reply With Quote
Dyno Tune: 2.5L, GT35R, E85-Tuned STI Makes 540whp! Cobb Tuning Proven Power Bragging 45 04-25-2013 04:42 AM
Dyno Tune: 2.5L + HTA3582 + Topspeed (Doug) makes 605whp 07evok1lr Proven Power Bragging 49 06-20-2012 06:07 PM
Dyno Tune: 2.5L, GT35R, makes 439whp apexslider Proven Power Bragging 6 02-09-2010 10:29 AM
Dyno Tune: 2.5L hybrid + VF39 makes 352whp on 92 octane *03wRx* Proven Power Bragging 8 11-08-2009 11:18 PM
Dyno Tune: 2.5L + ATP35 makes 360whp 2gnt2wrx Proven Power Bragging 12 10-31-2009 08:32 AM
