Old 02-07-2010, 12:28 PM   #1
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Default Would replacing my helper spring with a stiffer tender spring make my car ride better
"Cheap" coilovers, running 8k/6k setup with helper springs. Its starting to get annoying. Its a bit too firm for daily driving.
Would swapping out the helper springs for a tender spring soften it up a bit?
Old 02-07-2010, 03:44 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Nope. Problem is actually more in the lack of travel and damping. Can't fix that without getting something else.
You could replace the springs with softer ones, but it won't affect the ride quality much if at all.
Tony
Help my friend make his car look better Jubert69 Interior & Exterior Modification 45 01-11-2009 01:30 PM
What would make this car look better?? maramaralula Member's Car Gallery 42 06-22-2008 02:49 PM
Turn In Concepts makes your car handle better Turn in Concepts Suspension/Brakes/Handling 20 10-04-2007 09:38 AM
Benefits replacing helper spring with longer main spring? Hyper Brakes, Steering & Suspension 5 10-11-2006 06:13 AM
There IS a difference between a tender spring and a helper spring Arnie Brakes, Steering & Suspension 5 09-06-2005 11:00 AM
