Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Private Classifieds
Old 02-08-2010, 01:39 AM   #1
M E R C U R Y
Member Sales Rating: (17)
Member#: 2007
2000 2.5RS BRP
NewImageMotorsports.com
Default Fs: Vf23 $500
SOLD
DIRECT bolt-on replacement turbo for 2002+ Subaru WRX and EJ20 STI engines. Not intended for the EJ25 STI.
APEX AX53B60-P20 / IHI VF23 BALL BEARING TURBOCHARGER 22B power
This turbo was never installed went with a bigger custom setup.
This turbo is considered a great all-around turbo. Like the VF22 it utilizes the LARGEST P20 housing that is mated with a smaller compresser housing from the VF24. This turbo is considered optimal in applications with range from mild to slightly wild. It doesnt have the same top end power of the VF22, but spools up significantly quicker. -quoted from Gruppe-S
Ball Bearing
Water and Oil cooled
Compressor Trim: 57
Compressor Inducer(mm): 46
Compressor Major(mm): 60
Turbine Trim: 82
Turbine Major(mm): 53
Turbine Exducer(mm): 48
Exhaust Housing A/R: .79
P20 Exhaust housing
Internally Wastegated (1 kilo~ 14.223 psi)
Rated: 250-350hp
Flange: Subaru OEM turbo flange
Same turbo as originally equipped on JDM Ver.3 STi models (22B). Similar to the VF22, as it utilizes the same P20 exhaust housing (largest of the P-series exhaust housings). Uses the smaller compressor housing of the VF24 for faster response and excellent low and mid-range with considerably less turbo lag than the VF22. Full boost expected between 2800-3200rpm.
asking $500
will take trades for 4th gen itouch 32gb plus cash
M E R C U R Y is offline   Reply With Quote
Old 02-08-2010, 01:51 AM   #2
TheNailman
Member Sales Rating: (46)
Member#: 133676
2005 WRX
nice turbo. bump for you
TheNailman is offline   Reply With Quote
Old 02-08-2010, 07:05 AM   #3
sleepyS14
Member Sales Rating: (27)
Member#: 171688
2006 Saabaru 9-2x
Aero Wagon Midnight Black
bump for you merc =p
sleepyS14 is offline   Reply With Quote
Fs: Vf23 epaplia Private 'For Sale' Classifieds 117 04-22-2006 12:16 PM
Fs: Vf23 WRX_scott Private 'For Sale' Classifieds 10 10-16-2005 06:18 PM
Fs: Vf23 WRX_scott Mid Atlantic Impreza Club -- MAIC 10 10-15-2005 07:16 PM
Fs: Vf23 Snoody J Private 'For Sale' Classifieds 0 02-21-2004 05:44 PM
FS: vf23 TYPE wRx Tri-State Area Forum 15 06-25-2003 03:34 PM
