Go Back   NASIOC > NASIOC General > Motorsports > Press Releases
Old 03-09-2010, 12:26 PM   #101
MSP608
Member#: 149631
ST-3 STi
2.3L Evo
When exactly would you guys be using anti lag?
MSP608 is offline   Reply With Quote
Old 03-09-2010, 04:46 PM   #102
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
It will be awesome for coming out of corners with a larger turbo. Turbo should always be above boost threshold and ready to go.
Tony
Old 03-10-2010, 01:02 AM   #103
RallyLegacy
Member#: 114353
97 Legacy,
05 BMW M3
Tony
Since this is a full blown race car now I know this is less of an issue, but isn't that going to severely decrease the life of the turbo?
RallyLegacy is offline   Reply With Quote
Old 03-10-2010, 01:13 AM   #104
MSP608
Member#: 149631
ST-3 STi
2.3L Evo
I was wondering the same thing.
Old 03-10-2010, 07:53 AM   #105
growling_boxer
Member#: 165744
2000 LGT
2007 STi
that's why you usually don't see anti-lag on the track...significant increase in wear, and the lag is something you can work with by rolling on the gas sooner in the turn. If you can use full boost in the middle of the turn on a high hp car, it usually means you entered the turn too slowly. I certainly do love hearing it on rally cars, though.
growling_boxer is offline   Reply With Quote
Old 03-10-2010, 08:06 AM   #106
R1Z4T
Member#: 176105
1912 Alco
Red
Originally Posted by PitwrkzZ1 View Post
Have you thought about flocking the dash since its out of the car? It cuts down on glare on the windshield big time and it only takes the afternoon if you get the DIY kit.
More info please
R1Z4T is offline   Reply With Quote
Old 03-10-2010, 10:00 AM   #107
Turn in Concepts
Member#: 93646
Many Track Records
With the rate we replace items on the car anyway it wouldn't matter. Turbos are replaced yearly anyway along with engine. It's just part of the maintenance plan which when adhered to keeps the car reliable.
Tony
Old 03-10-2010, 11:05 AM   #108
growling_boxer
Member#: 165744
2000 LGT
2007 STi
I assumed you planned on having a shorter maintenance schedule anyway, and that's why you decided to do it. I hope you guys come out to the east coast this year, so I can watch this thing run in person.
Old 03-10-2010, 09:37 PM   #109
Turn in Concepts
Member#: 93646
Many Track Records
We are only running east coast Redline events this year.
Old 03-11-2010, 03:21 PM   #110
growling_boxer
Member#: 165744
2000 LGT
2007 STi
excellent. I saw you guys at E-town last year. I might make it out to one of the April days at NJMP, but I'll be at Pocono on 4/11, so I'm not sure yet.
How many east coast events do they actually have? Is it just the one at NJMP and the one at Autobahn in IL?
Old 03-11-2010, 07:16 PM   #111
wrxd1
Member#: 240427
04 rexx
187 murderrd
i went to E- town too!! some of the faster guys said the course wasnt all that great, something about the asphalt was breaking up!! but tic's car definitely boogied there.. so its definitely gonna rotate the earth now!!
wrxd1 is offline   Reply With Quote
Old 03-16-2010, 10:20 AM   #112
Turn in Concepts
Member#: 93646
Many Track Records
Some more pics as the engine goes together this week.
Didn't like the hone on the cylinders of the new block we got so we rehoned it. This is the same procedure we used on our last engine that lasted two years. Hopefully we are as lucky with this one.
Stock: almost looks polished. Not good.
Rough hone.
Finish hone
Also got the pistons back from Swaintech, but forgot to take pics. We had the tops and skirts coated. Sized them last night to the bores and we have just around 4 thou on all four. Our last motor ran at 5 thou which was just a bit loose. Gapping the rings will be tonight.
Tony
Old 03-16-2010, 10:31 AM   #113
jdblock
Member#: 235211
2004 STi
That bottom pic is awesome.
jdblock is offline   Reply With Quote
Old 03-17-2010, 04:18 PM   #114
Rokkit
Member#: 84181
NASA #530 GTS2
Not knocking you at all - just curious
The stock piston to cylinder clearances say .0004-.0012 with a limit of .0020 -
You guys have .0040?
Does it burn oil? Must be a forged piston thing?
Rokkit is offline   Reply With Quote
Old 03-17-2010, 04:34 PM   #115
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Forged pistons do grow, especially in endurance situations...If they are doing an endurance motor, I'd suggest a hone with a bit less angle and finishing it with a plateau brush
Old 03-17-2010, 04:35 PM   #116
MSI
Member#: 95419
4 tenths of a thou to 2 thou is a huge difference .... (in tolerance gibbersh).
Perhaps mixing up metric and inch values you guys? SUBARU lists in mm, not in inch.
Perhaps not as well, I am a chassis guy, not an engine nerd!
factor of 25.4 is the difference (1 inch - 25.4mm)
-mark
MSI is offline   Reply With Quote
Old 03-17-2010, 04:57 PM   #117
Homemade WRX
Member#: 33782
96 bastard child
.004" is large. I run that on a big power 4" bore subie setups. Then again they don't run events where they are being flogged for 25 hours at a time
not sure why they put their PW clearance so large.
Old 03-17-2010, 05:40 PM   #118
Turn in Concepts
Member#: 93646
Many Track Records
I believe .004 is a little tighter than what we ran on the last motor, and we were REALLY happy with how that one did.
Old 03-18-2010, 08:16 AM   #119
Rokkit
Member#: 84181
NASA #530 GTS2
Well whatever works - I was more interested in the thought process behind it because I just rebuilt my track motor which was .002 out of round and i was worried it would burn oil like a pig...
Old 03-19-2010, 04:43 PM   #120
Turn in Concepts
Member#: 93646
Many Track Records
We ran .005 PWC on the last motor that went 2 years and 20000 HARD miles. It burnt almost no oil. We used .018 on top ring and .022 on the second. This time we are doing .22 on the top and .25 on the second. The recommendations from CP on both PWC and REG are MUCH greater than that. For what we do with the car, this works and has been tested for time attack, street driving and endurance racing. The factory specs would cause engine failure in short order!
Tony
Old 03-19-2010, 04:53 PM   #121
dunk
Member#: 15359
Less talking and more pictures!
-Duncan
dunk is offline   Reply With Quote
Old 03-19-2010, 05:09 PM   #122
Turn in Concepts
Member#: 93646
Many Track Records
Sort of a turbo pic. Should not let Clint be in charge of taking pics.
Blouch, who is a new sponsor, sent out the turbo to us the other day. It's a 3582 with their custom billet comp wheel. .82 hotside which will hopefully spool decently.
Engine is going together this weekend and car should be running by Monday.
Old 03-19-2010, 06:20 PM   #123
Turn in Concepts
Member#: 93646
Many Track Records
-Clint
Old 03-22-2010, 10:43 PM   #124
Suburroo
Member#: 125458
Post
Really liking the build journal guys! Maybe a little video when the car is running? Hoping to see you guys up at Joliet this year!
Suburroo is offline   Reply With Quote
Old 03-26-2010, 02:09 PM   #125
Turn in Concepts
Member#: 93646
Many Track Records
More pics. Engine is in and we are mocking everything up. Fuel system is finished. Steering wheel adapter is finished.
We had to custom make an adapter for the quick release wheel. Didn't like the hub adapter as it spaced the wheel out too far. We took the center splined section out of the stock wheel and mated it to the quick release spline. Then we machined a nut to fit inside it to hold it to the column. Works great and gets our hands and arms in the position we want.
My 2010 Race Car Build - From the Ground Up boost junkie Motorsports 2678 08-19-2016 10:54 AM
Make your car better thanks to Turn In Concepts Turn in Concepts MWSOC Vendor Classifieds 22 10-21-2007 09:00 AM
Turn In Concepts makes your car handle better Turn in Concepts Suspension/Brakes/Handling 20 10-04-2007 09:38 AM
Turn in concepts STI shifter kit, ssk, bushings etc. NEW IN BOX FREE SHIPPING happy187 Drivetrain 10 04-19-2007 01:32 AM
Some Whiteline bars in stock at Turn In Concepts Turn in Concepts Suspension/Brakes/Handling 5 10-24-2005 10:24 AM
