Go Back   NASIOC > NASIOC General > Motorsports > Press Releases
Old 03-26-2010, 03:13 PM   #126
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
One more:
Old 03-26-2010, 03:14 PM   #127
wantsti
Member#: 134764
04 sti
java black pearl
Whats the plate for on the trunk? Couldn't you just open the trunk to get to the fuel cell?
wantsti is offline   Reply With Quote
Old 03-26-2010, 03:19 PM   #128
Turn in Concepts
Member#: 93646
Many Track Records
confusion
Old 03-26-2010, 03:20 PM   #129
Turn in Concepts
Member#: 93646
Many Track Records
No. It hits the wing. Although we are going to raise the wing 4-6 inches so it may clear. If so we will just get a different trunk.
Old 03-26-2010, 03:25 PM   #130
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
Why not just cut the inner skeleton out of the trunk lid and attach it to the car with hood pins? If you get it light enough it should be just as easy to remove the whole trunk as it would be to remove that access panel, and that would make it a lot easier to reach the fuel filler.
boost junkie is offline   Reply With Quote
Old 03-26-2010, 03:37 PM   #131
dunk
Member#: 15359
That's on my project list, but I haven't got to it yet.
-Duncan
dunk is offline   Reply With Quote
Old 03-26-2010, 11:59 PM   #132
Turn in Concepts
Member#: 93646
Many Track Records
Already cut it all out. Problem is the wing uprights are just close enough that we can't get the trunk out without removing the wing. Again, may not be an issue after we raise the wing.
Old 03-28-2010, 10:09 PM   #133
Turn in Concepts
Member#: 93646
Many Track Records
Car runs! New motor is coming along well. First startup with the AEM EMS was pretty easy. Going to be getting it tuned by Jorge sometime this week.
Tony
Old 03-29-2010, 06:09 PM   #134
coolblue05
Member#: 39169
2008 Cayman S, C63
Tuned Perfection
Nice updates!!!! PM'ed you...
coolblue05 is offline   Reply With Quote
Old 03-29-2010, 09:19 PM   #135
JMS Landshark
Member#: 48773
2004 TiC WRX
also '99 BMW M Roadster
Tony
Wit hthe numbers you are looking for, I hope you will have video and plots.
JMS Landshark is offline   Reply With Quote
Old 04-02-2010, 11:31 AM   #136
Turn in Concepts
Member#: 93646
Many Track Records
Got the race car tuned yesterday at P&L with the new 3582. A bit laggy, but considering the car has stock headers and sock heads (other than springs and retainers).
It was pretty hot while on the dyno yesterday as there was not enough airflow. We let the car cool down for 5 minutes then ran it again and it made 20 more hp. What you see on the graph is the hot hp.
The pump gas map is on 19 psi, the race gas on 26. When we go back in a month or so for a retune, after we add some more parts, we are going to do a map at 30 psi and see what happens. So for all those with hybrids out there that don't think they can make any power, here you go.
I always used to think my 08 STI was quick at 400 whp. It's slow compared to this. It's definitely a bit laggy, but won't really matter for road racing.
Tony
Old 04-02-2010, 12:25 PM   #137
Fear-No-Evo
Member#: 165688
2011 Impreza STI
" BLURPLE"
Just out of curiosity, why didnt you guys choose to run the P&L front mount that is designed for a flipped manifold application. Shorter more direct piping would surely reduce the increased lag that your experiencing from running the larger turbo. Just a thought.
Good luck this year guys!!!!
Fear-No-Evo is offline   Reply With Quote
Old 04-02-2010, 12:32 PM   #138
wantsti
Member#: 134764
04 sti
java black pearl
I <3 TiC
Old 04-02-2010, 05:55 PM   #139
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
What race gas? you guys have access to E85?
Token-Negro is online now   Reply With Quote
Old 04-02-2010, 08:26 PM   #140
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Yes, also curious why you didn't go with a reversed intake manifold.
Arnie is offline   Reply With Quote
Old 04-02-2010, 09:23 PM   #141
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Because it does little to NOTHING waste of money and time, unless packaging reasons say you need it.
Old 04-02-2010, 09:33 PM   #142
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
wow, really?
<<< hangs out in suspension forum too much
Old 04-03-2010, 03:03 PM   #143
Turn in Concepts
Member#: 93646
Many Track Records
wow, really?
We measured the difference. The piping reduction was so small that getting the last bit of other parts first would be money and time better spent.
For example, I have some things I want to do on the intake manifold.
I also want to shot peen with large shot at low speed the inside the IC tubes as those are a textbook example of laminar flow and boundary layer losses.
I also need to do the heads. Badly. I have a VERY good idea of what I want done on the intake side (still working out exhaust side). Problem is finding a head shop that will look at it, and go "Ok, we'll try it your way, but look out for this..." Instead I mostly get "No. We do it this way. We've always done it this way, and we're not interested in even looking at your way."
Old 04-03-2010, 06:37 PM   #144
Turn in Concepts
Member#: 93646
Many Track Records
First test day is finished and the car ran very well!
On the race gas map it is absolutely insane! Unfortunately, it was wet in the morning when we were testing with the race gas so we didn't get any good lap times. The speeds at the end of the straight though were dramatically higher than on our old setup with 380 whp. Where we were hitting 132 mph before we were now hitting in the 150-155 range. The powerband on the pump and race gas maps were great even though peak torque comes at almost 5000 rpm. Even rolling on half throttle yeilded more acceleration than at full throttle on the old setup. Realistic estimation on lap time improvement would be 4-5 secs which would put us 3 sec faster than the lap racord for our class car in NASA.
The changes to the suspension were great as well. We replaced the stock lateral links with poly bushings with MSI spherical bearing lat links. We also dialed in 1.2* more neg camber in the rear over last year to -3.4*. These two mods really calmed the rear end of the car down. It is no longer twitchy on transition. It just sticks and allows us to put the power down coming out of corners.
Oh, and for the nae sayers, the stock bov has no problems holding 26 psi and making 530 whp.
I will have some pics up later tonight or tomorrow.
Tony
Old 04-03-2010, 06:38 PM   #145
Turn in Concepts
Member#: 93646
Many Track Records
110 leaded. E85 is too inconsistent and we don't have the means to carry a drum of it with us.
Tony
Old 04-03-2010, 07:16 PM   #146
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
-3.4 in the rear? Wow, how much front camber are you using?
Old 04-04-2010, 07:36 PM   #147
Turn in Concepts
Member#: 93646
Many Track Records
-4.5*
Old 04-05-2010, 04:09 AM   #148
STi-MAN
Member#: 70252
05 STI
blue
You dont feel like thats a bit much? esp with the down force goodies the car has?
STi-MAN is offline   Reply With Quote
Old 04-05-2010, 07:59 AM   #149
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
-4.5*
isn't it great not having to be on street tires anymore?
Frank A is offline   Reply With Quote
Old 04-05-2010, 08:02 AM   #150
RACE211
Member#: 71844
98RS AST Custom 5 sp
TIC GT30R Diffs F&R
Nope! The car felt better than ever and the tires wore even.
RACE211 is offline   Reply With Quote
My 2010 Race Car Build - From the Ground Up boost junkie Motorsports 2800 12-02-2016 05:49 PM
Make your car better thanks to Turn In Concepts Turn in Concepts MWSOC Vendor Classifieds 22 10-21-2007 10:00 AM
Turn In Concepts makes your car handle better Turn in Concepts Suspension/Brakes/Handling 20 10-04-2007 10:38 AM
Turn in concepts STI shifter kit, ssk, bushings etc. NEW IN BOX FREE SHIPPING happy187 Drivetrain 10 04-19-2007 02:32 AM
Some Whiteline bars in stock at Turn In Concepts Turn in Concepts Suspension/Brakes/Handling 5 10-24-2005 11:24 AM
