Old 02-08-2010, 09:05 PM   #1
MRX WRX
Member#: 114566
2005 STI
aspen white
Default AP tuner race issues
ok so i get the race tuner setup and i am confused. not everything works and i dont understnd why its there if it does not work.
i have been chasing a surging idle thing for weeks now and no matter what you change in the program idle stays the same . 1500 nothin ,750 nothin it just does not matter. but if i change it with the keypad it works perfect??
target closed loop air fuel DOES NOT DO ANYTHING
REV LIMITS DO NOT WORK EITHER
and to be honest im not even sure if the fuel table works either. i cant seem to get the IDC to change no matter what numbers i put in the table????
ALL of the close loops setting do nothing i attempted to turn CL off at idle and it still chases 14.7. i run E85 and can run leaner and its always chasing 14.7 even with the TARGET map set to 15.5
im no rookie and have been tuning for years and if i use romraider everything works and the car runs great, the main reason for me purchasing the cobb is so i could switch maps whenever i cannot get E85 and the live tuning.
COBB please respond
MRX WRX is offline   Reply With Quote
Old 02-08-2010, 10:11 PM   #2
gagliano
Member#: 39541
2002 WRX & 2004 STI
WR Blue
I don't think Cobb will respond, my understanding is that they provide no support for this since it competes with pro tuner efforts.
gagliano is offline   Reply With Quote
Old 02-08-2010, 11:16 PM   #3
MRX WRX
Member#: 114566
2005 STI
aspen white
i hope that your wrong about that!!!! im not asking for tuning questions but more along the lines of software issues unless this is done on purpose IDK
Old 02-09-2010, 12:24 PM   #4
Cobb Tuning
Member#: 4803
COBB please respond
As far as the primary fuel map and rev limits, remember that your real-time map overrides your base map when one is loaded. So, if you flash a change to your base map and then load a real-time map, the primary fuel and rev limits (and other RT specific tables) will be set to your real-time map. Alternatively, if you have a real-time map loaded and then reset the ECU, you will revert to the base map values.
As far as the "idle speed" tables, I'm not sure what you mean by "changing it with the keypad". The "idle speed" tables are base map tables which mean you have to flash the changes - they are not real-time. That means you have to change the value, save the map, upload it to the AP, and then flash with the AP (connecting the test mode connectors in your case).
As far as running OL at idle, what exactly did you change?
Bill
Old 02-09-2010, 02:51 PM   #5
MRX WRX
Member#: 114566
2005 STI
aspen white
hmmm so if i make a fuel change i have to hard flash it for it to take even though while i am driving around it stays? what i mean on the idle is that if i change the idle values to let say 1k and i real time flash it it will not change, but if i change the idle on the keypad (commander or whatever ya wanna call it) the idle will change and stay that way even when i disconnect the commander. also whn you say "flash" you mean hard flash as in connect the plug right?
Old 02-09-2010, 02:53 PM   #6
MRX WRX
Member#: 114566
2005 STI
aspen white
what would be the easiest way to eliminate CL at idle, i think the car can idle around 900 but because it chases AFR and E85,cams etc etc i need it to just idle with no ECU CL adjustments
Old 02-09-2010, 03:47 PM   #7
Cobb Tuning
Member#: 4803
Only certain tables are real-time capable. Idle speed tables are not. Under the category "realtime tables" are the list of real-time tables for your ECU. If a table is not real-time, you will need to "hard" flash those changes (connect the test mode connector and flash with AP). The idle adjustment that can be done via the Accessport is a separate function from real-time tuning (actually a dealer supported function).
You can force OL all the time by changing the closed loop delays to zero and making sure no cell in your primary fuel map is leaner than 14.4:1 AFR (for your particular ECU). Of course, you will not be able to target leaner than stoich this way.
The closed loop targets tables are actually compensations to the CL target, not the actual target itself. We will change this in a future update to make it more clear and add additional tables that will make it easier to influence/understand the CL target.
Bill
Old 02-09-2010, 06:54 PM   #8
MRX WRX
Member#: 114566
2005 STI
aspen white
so whats the point of the temporary flashes? if i bench tune and then temp flash it only certain changes take place but some dont makes it pointless right , or am i missing something?
Old 02-09-2010, 07:07 PM   #9
MRX WRX
Member#: 114566
2005 STI
aspen white
everything works now, i feel dumb but my thought process was not correct inhow i though it woudl work. it seems to me that i should never temp flash as it really is not needed.
V1 street tuner connect issue rwdeatr AccessPort 2 11-02-2009 01:58 PM
Any good Cobb AP Tuners in the NY/NJ or Phila, PA area? TurismoLou Engine Management & Tuning 1 10-02-2005 03:23 PM
ap tuners protuners socal 949 Engine Management & Tuning 5 08-05-2005 09:56 PM
power numbers with ap tuner on sti 949 Engine Management & Tuning 9 05-18-2005 12:20 AM
Irvine Suby in Import Tuner August Issue Subayai WRX Southern California Impreza Club Forum -- SCIC 2 07-19-2002 12:01 PM
