Old 05-26-2002, 07:34 PM   #1
RobPA
Guest
Member#:
Default A Fuel Pump Equivelant to a Supra TT Fuel pump??
A friend of mine is working on his nitrous system for his rex.. I am reading on here that most of you who are using nitrous are also using an upgraded fuel pump, mostly the TT pump.. I saw it for like 240$, is there another more affordible option that does the same thing??? Like a 110$ walbro 342??? Thanks a lot for the help!!!
Rob
Old 05-26-2002, 07:52 PM   #2
jmott
Member#: 6713
2007 Prius
brown
if the nitrous kit is a wet kit, there should be no need for a bigger fuel pump
jmott is offline   Reply With Quote
Old 05-26-2002, 10:44 PM   #3
NotoriousWRX
Member#: 9026
For the best price on the Supra TT fuel pump, check out http://www.partznet.com/mitsudsmclub.html
NotoriousWRX is offline   Reply With Quote
Old 06-04-2002, 11:20 AM   #4
Strafe
Member#: 3619
2002 Subaru WRX
Upon the recommendation from Mark at TurboXS, I just ordered the GSS342 (Walbro) pump from http://www.jdsperformance.com. I think it cost $115 shipped. Mark did say to use the stock WRX fuel pickup with the new pump.
-Dennis
Strafe is offline   Reply With Quote
Old 06-04-2002, 12:11 PM   #5
Dmitri
Member#: 18907
Just be warned.. the Wallmart *cough* er, um.. Wallbro fuel pumps are LOUD. You will get a constant hum when your car is on.
-Dmitri
Dmitri is offline   Reply With Quote
Old 06-04-2002, 12:22 PM   #6
pace
Member#: 11606
2004 Pilot
1995 Miata
FYI my GSS342 is quiet. Can only be heard at idle with the vehicle in a quiet location.
pace is offline   Reply With Quote
Old 06-04-2002, 12:37 PM   #7
AmSFighter
Member#: 8923
2007 BMW 433whp N54
Gray
I can't hear my gss342...maybe it's cause the catless mk3 covers up all other sounds. I got mine new for 101 shipped (EP performance in NC). Total drop-in replacement. All that needed to be done was to bend the bottom bracket slightly since the larger pump is longer than stock.
AmSFighter is offline   Reply With Quote
Old 06-04-2002, 03:08 PM   #8
Austin
Member#: 7089
2016 STi
What's the difference between the 340 and the 342?
Austin is offline   Reply With Quote
Old 06-04-2002, 03:26 PM   #9
krave
Member#: 13908
2002 WRX Sedan
296 whp
haven't heard any difference in sound with my supra fuel pump, and haven't had any problems with it so far....does require a little soldering and im reusing the stock strainer
krave is offline   Reply With Quote
Old 06-04-2002, 03:27 PM   #10
replacement killer
Member#: 19368
2003 WRX
-Dmitri
Dmitri,
Hey bud, did you get your WRX yet? How 'bout your MR2, have you sold it already.
Back to the subject. I had a Supra TT pump in my previous MR2 and was very happy with it, a friend did a fuel pump upgrade at around the same time and went with the Walbro, it is noticably louder but then again the fuel tank on a MR2 is right in the center tunnel of the passenger compartment.
replacement killer is offline   Reply With Quote
Supra TT fuel pump for sale! PAWRX Private 'For Sale' Classifieds 1 12-04-2003 04:31 AM
Supra TT fuel pump part # PHATsuby Normally Aspirated with bolt-on Forced Induction Powertrain 2 04-30-2003 11:28 AM
Supra TT Fuel Pump preza Normally Aspirated with bolt-on Forced Induction Powertrain 7 01-30-2002 12:17 PM
Those of you using Supra TT fuel pumps, please answer quick question! Tim Prudence Technical Forum Archive 10 07-07-2000 11:20 AM
Where can I buy a Supra TT fuel pump? Sean McElderry Technical Forum Archive 5 06-28-2000 07:30 PM
