Old 02-08-2010, 10:25 PM   #1
weaponstroop
Member#: 180842
2008 WRX STi
Default Cobb AP noob question.
so i got my AP today from Perrin, dowloaded the AP updater and AP manager and flashed my car to the perrin stage 1 map.
ok my question is this; where is my stock map? when i hook up the AP to my computer i can see all the COBB maps and the Perrin map but i dont see my stock map. the only reason i was looking for it was to save it somewhere on a disk or thumbdrive for safe keeping in case something happens to my computer or AP or whatever. thanks in advance
weaponstroop is offline   Reply With Quote
Old 02-08-2010, 10:35 PM   #2
Jayknux
Member#: 236450
09 WRX HB
Dark Grey Met
When you hook up your AP it will verify the vehicle first and then ask you to install. After the install it will ask you to chose a map. When you choose the map and press ok it will automatically save the stock ecu tune and then install your selected map. Once installation is done you turn your car key to the off position. When you turn your car back on you can verify which map is installed and you can also see the other maps stored in the AP. The stock tune ecu map is at the bottom of all your maps after Valet. Hope this helps you find it. If the AP didn't save your stock map you did something wrong....
Jayknux is offline   Reply With Quote
Old 02-08-2010, 10:38 PM   #3
Jayknux
Member#: 236450
09 WRX HB
Dark Grey Met
plus...you should not of had to update your AP anyway because Perrin downloaded there map into your AP before they shipped it and they make sure you are running the most current version. I know a person at Perrin.
Old 02-09-2010, 01:59 AM   #4
arghx7
Member#: 232940
download accesstuner race and you can see the stock calibration
arghx7 is offline   Reply With Quote
Old 02-09-2010, 07:13 AM   #5
weaponstroop
Member#: 180842
2008 WRX STi
thanks for the replies. i will check again and see if the stock ROM is there. if not i might uninstall and re-install the AP
Old 02-09-2010, 02:20 PM   #6
memma
Member#: 231197
2010 WRB WRX 5dr
Precision Tuned
Hey I dont mean to hijack the OPs topic but I also have a noob question too. Can you use the AP on more than 1 vehicle?
memma is offline   Reply With Quote
Old 02-09-2010, 02:24 PM   #7
CEGLEX
Member#: 201976
2003 WRX Sedan PSM
Stage 2
Nope. Search and read the Cobb website as well. The AP is "married" to one vehicle at a time. The only way to use it on another is to "unmarry" it from the current vehicle.
CEGLEX is offline   Reply With Quote
Old 02-09-2010, 02:25 PM   #8
memma
Member#: 231197
2010 WRB WRX 5dr
Precision Tuned
Thanks
Old 02-09-2010, 09:31 PM   #9
weaponstroop
Member#: 180842
2008 WRX STi
so i got the accesstuner race program from Cobb. when i hooked up my AP and ran the program it only showed one map named "2008-2009 USDM Imprezza WRX STI-<stock mapping>" i am assuming this is the map the AP downloaded when it was installing thhe Perrinn map on my car. can anyone comfirm
Old 02-09-2010, 09:43 PM   #10
Jayknux
Member#: 236450
09 WRX HB
Dark Grey Met
yes....if you read my first post that is what i told you....now you can rest that your stock tune is safe and sound
Old 02-09-2010, 09:46 PM   #11
Jayknux
Member#: 236450
09 WRX HB
Dark Grey Met
you should be able to see all the other maps installed too....valet mode,theft mode, stage 1, stage 2 and so on
Old 02-09-2010, 09:55 PM   #12
weaponstroop
Member#: 180842
2008 WRX STi
i understood your first post. what i wasnt sure about was the naming of the stock map. when i look at the maps on my comp i can see all the stage maps, valet, anti theft, and perrin, there is one labeled "installed stock mode v104..... what was throwing me off is the vendor says "Cobb tuning" so i was thinking was i couldnt "see" my stock map and the map labled "stock mode" was a pre-map from Cobb.
thanks for the help, i guess i wasnt asking the right question or leaving too much info out.
AP Noob question... Sorry in advance! Sc00byD00d AccessPort 2 07-22-2006 09:19 PM
cobb uppipe noob question clawdnb Newbies & FAQs 8 02-10-2006 07:00 PM
AP noob question. Should I keep it in the car? Badkarma Engine Management & Tuning 9 12-07-2005 06:51 PM
Cobb AP noob question wrxetta Engine Management & Tuning 2 05-20-2005 12:04 PM
Cobb Ap upgrade question Jduke Engine Management & Tuning 11 02-19-2005 03:00 PM
