Old 02-09-2010, 12:42 PM   #1
Arr
Member#: 201827
1998 Impreza GT
Default knock sensor
few days back i got a check engine message
made self test by connecting two connectors under panel
signal says its knock sensor (beep signals )
so ive got knock sensor glitch, so now i need to replace it,
but before i buy i new one
ive got few questions
1. how do knock sensor become dead? why?
how does it works?
can it be repaired?
thanks and sorry for my bad english
Arr is offline   Reply With Quote
Old 02-09-2010, 01:46 PM   #2
kev m
Member#: 128582
2010 Impreza 2.5 Wgn
2011 Nissan Juke
Most knock sensors are piezoelectric sensors - which mean they generate their own voltage. Basically the motion of vibration causes it to generate a current.
How do they go bad? How does any sensor go bad? Either something inside the sensor physically breaks or there is a problem with the harness.
They are not generally considered repairable, but you never know.
kev m is offline   Reply With Quote
Old 02-10-2010, 03:36 PM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
knock sensors are pretty much a wear item
they cannot be repaired
they should be replaced with a new factory part
and this is every easy to do.
Old 02-10-2010, 03:59 PM   #4
Arr
Member#: 201827
1998 Impreza GT
yeah, but day whene we checked check engine signal, then i called almost all latvians carpart shops - no one has it everywhere i have to wait about 4weeks to get it :/
weve got one nice subaru salvage store only subarus, there you can get also new parts - but they told day ago they sold last new knock sensor, now i have to wait about 3-4 weeks...
damn fuel consumption about 20liters/100km where check engine lights up
Old 02-10-2010, 04:17 PM   #5
kev m
Member#: 128582
2011 Nissan Juke
Bummer - I guess if the knock sensor is bad the ECM may retard ignition timing so as to avoid possible damage to the motor if there was knock it could not detect.
Result = reduced performance/mileage.
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor, ex mani jakesurfin Engine/Power/Exhaust 9 06-15-2009 01:28 PM
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor jakesurfin TXIC Private Classifieds 4 06-15-2009 01:28 PM
2nd Knock Sensor Location, 2nd Knock Sensor Locatoin! SentinelSison UTEC 3 05-24-2006 10:06 PM
Jorge's Daily hash: Knock sensor, false knock, filters and electronics... RiftsWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 09-10-2003 10:49 AM
knock link or msd knock sensor? wrxtcy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-22-2002 07:21 PM
