Old 02-09-2010, 04:32 PM   #1
bachan114
Member#: 99321
2012 WRX (WRB)
"BLU BALZ" is coming 4 u!
Default Bachan114: Hybrid motor + 35r @16psi makes 388whp, Junior tuned
Event: dyno pull
Ambient Temp: 50
Elevation: sea level
Car: 2003, WRX
Tuner: Junior
Dyno Info: Dyno Dynamics
Peak HP at RPM: 388 @ 7550
Peak Torque at RPM: 283 @ 6300
Baseline hp/tq for a stock on same dyno: 240whp on 2.5L
Target Boost: 16psi
Target AFR: 11.0
Fuel: 93
Engine/Power Modifications:
Rallispec built hybrid motor (2.5L SB and 2.0L heads)
-supertech pistons
-kelford 272 cams
-crower rods/springs/retainers/0.5+ oversized valves
-cosworth bearing
-2010 sti black crank
-ARP head studs
Garrett 35r w/ .82 housing
Gruppe-s unequal length headers
Perrin up/downpipe
Perrin Stealth series FMIC
APS 3" exhaust
D-werks 1100cc injectors
JDM Spec C manifold with JDM stainless steel fuel rails
Walbro 255 fuel pump
Utec/openecu Junior tune
Driveline Modifications:
Fully built 4eat racing trans by IPT
-chryo/heat treated gears
-transmission cooler
-upgraded valve body
-built torque converter
-bored case for better cooling and lubrication
Suspension Modifications:
Helix DNA coilovers
front and rear sti pink braces
Gruppe-n engine/tranny mounts
APS engine brace
The car drives like it is stock and pulls with the fury of an angry demon! I want to thank Jodi at rallispec and Jimmy and Junior at the shop for getting the car in such great running order. I am so impressed with the numbers the car made with only 16psi of boost. I can't wait till the warmer weather and run 23-24psi and really let the motor/turbo breathe!
-Cramer
bachan114 is offline   Reply With Quote
Old 02-09-2010, 04:38 PM   #2
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Nice! What is the CF on the dyno? 1.2 Are u really reaving to 8K ? Is this the standard 3K rallispec shortblock? Why only 16psi?
GL
Old 02-09-2010, 04:43 PM   #3
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
GL
Looks like 8400 to me Juan
You can't go wrong with the Rallispec/TheShopCT combo. Reliability at its best for sure.
Nice Job Cramer, and nice to see you in PPB!
STi Mikey is offline   Reply With Quote
Old 02-09-2010, 04:47 PM   #4
fourmicah
Member#: 128760
2017 STI
Nice work! it seems like a very good set up. I can't wait to see what she'll do when you can turn her up.
I love the color too! It's always been one of my favorite colors on the WRX, not sure why they only did it for one year. Post more pictures if you can.
fourmicah is offline   Reply With Quote
Old 02-09-2010, 04:47 PM   #5
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Nice flat-ish tq curve.
CoolRex is offline   Reply With Quote
Old 02-09-2010, 04:52 PM   #6
jays05
Member#: 78165
05 STI 35r + e85
Pretty cool that it has a built 4EAT in it
jays05 is offline   Reply With Quote
Old 02-09-2010, 05:11 PM   #7
bachan114
Member#: 99321
2012 WRX (WRB)
GL
I believe the CF is 1.2, I think STI Mikey had posted in his that it was 1.2. It was built by Rallispec, but it is not one of their pre-determined setups. Yes, it really does rev out to roughly 8300rpms, gotta love them 2.0L heads! The reason for only 16 psi is to just break the motor in and for safety during the winter.
Thanks Mikey!! we need to get out to the track this year!!
I will try and find a few more good pics of the car from the summertime.
Yeah... Im loving the built auto trans. never lose boost and never miss a shift!!!
Old 02-09-2010, 05:18 PM   #8
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
have you launched it yet with this new power?
Old 02-09-2010, 05:24 PM   #9
bachan114
Member#: 99321
2012 WRX (WRB)
I have not launched it with this tune on the car only because I need some new pads and rotors...the car creeps forward when I try to build boost for the launch. From a dead stop and just rolling into the power, once the boost kicks in, all 4 tires break lose and i need to really control the car to keep it straight... its so much fun!!
Old 02-09-2010, 05:36 PM   #10
impreza914
Member#: 199499
2007 ford f150
subau coming soon
nice job cramer glad to see/hear its finally running good ! cant wait for the summer to see it running the 24psi!
impreza914 is offline   Reply With Quote
Old 02-09-2010, 06:06 PM   #11
Donzo
Member#: 95337
2012 Jeep Overland
Awesome build! My hat goes off to The Shop and Rallispec for getting this beast up and running reliably. Can't wait to see this thing haul ass like a raped ape all over the place this summer!
Donzo is offline   Reply With Quote
Old 02-09-2010, 06:15 PM   #12
the real suby dude
Member#: 125497
02 Alpine White M3
Rouge Engineering !!!
+11111
the real suby dude is offline   Reply With Quote
Old 02-09-2010, 06:35 PM   #13
guiltyone311
Member#: 189401
2004 sti built!!
jbp w/fp red&meth
what intake setup are you using? i didnt see it listed.. but anyways looks good must be fun to drive with the built auto
guiltyone311 is offline   Reply With Quote
Old 02-10-2010, 08:00 AM   #14
bachan114
Member#: 99321
2012 WRX (WRB)
its kind of a frankenstein intake setup. Its the perrin cold air intake, but it was cut to supply a big MAF. Now that i have switched to utec and speed density, we cut the big MAF portion out and put it back to normal diameter
Old 02-10-2010, 10:27 AM   #15
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
Nice Brian, did you have the heads CC opened to match the 2.5 bore, a thicker gasket, or a stock gasket with oem 2.0 CC volume? Ill deff let you know when I come down...
rexworx is offline   Reply With Quote
Old 02-10-2010, 01:39 PM   #16
bachan114
Member#: 99321
2012 WRX (WRB)
They were machined to allow for the 0.5mm oversived valves. I did not do any porting on them as it wasnt necessary for the end result power goals i have. I am using a Cosworth gasket. I don't recall the exact thickness. I will add the specs for it when i find the paperwork from the build.
Old 02-10-2010, 02:57 PM   #17
Donzo
Member#: 95337
2012 Jeep Overland
I'm waiting for you to post vids of this monster. Let me know when you want to take some rolling shots and make some videos.
...not THAT kind of video. PM the real suby dude for that.
Old 02-10-2010, 03:04 PM   #18
rexworx
Member#: 103232
GTX 3071R'd 11WRX
So the combustion chamber wasnt opened up to 2.5 bore/volume?
Old 02-10-2010, 03:17 PM   #19
bachan114
Member#: 99321
2012 WRX (WRB)
they are factory 2.0 heads from an 04 wrx with the shimless buckets. To my knowledge they were not bored out to a 2.5L bore.
what benefit would there be to a 2.5L bore, apart from the bigger volume? If I port matched them, revving out to 8500+ rpms wouldn't be as safe.
As soon as the snow that just got dumped on us has been cleared from the roads and they are dry again I would love to go take some video/rolling shots... so maybe this weekend!!
Old 02-10-2010, 03:19 PM   #20
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Matching the bores on the heads will correct the quench and drop your compression.
FYI I didn't do mine either and I LOVE my high compression
Old 02-10-2010, 03:27 PM   #21
bachan114
Member#: 99321
2012 WRX (WRB)
oohh. I see. I am pretty certain they were left at 2.0. I love the setup just as it is!
Old 02-10-2010, 03:41 PM   #22
rexworx
Member#: 103232
GTX 3071R'd 11WRX
Ok thanks, I didnt either, just using a thicker gasket. I keep hearing about how much better the setup can be with the larger bore.
Old 02-10-2010, 03:42 PM   #23
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Meh if you know how to tune higher compression rocks. My off boost response is crazy.
Old 02-10-2010, 03:48 PM   #24
IIdiceII
Member#: 90438
i cant wait to see the numbers you put down this summer...almost 400whp with 16psi is AWESOME. you can beat the crap outta this thing right now and not have to worry about a thing
IIdiceII is offline   Reply With Quote
Old 02-10-2010, 03:52 PM   #25
rexworx
Member#: 103232
GTX 3071R'd 11WRX
What about hot spots in the CC causing det? In turn not running as mush timing etc.?
