Closed Thread
Old 02-09-2010, 06:18 PM   #1
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
Default Blouch Dom 2.5 meth/non meth 2.5L
Mods are blouch dom 2.5 2.4" 8cm
forge bpv
740cc
100% meth
perrin big maf cai
gms turbo inlet
helix dp
greddy ti cbe
walbro
spearco tmic
and lots of other stuff not worth mentioning
So, on the meth map it wasn't holding boost up top on the dyno. I guess there weren't enough fans and I wasn't getting enough air. Once we went to do the road tune though it was boosting and holding up top, so the number shoulda been better but numbers are just numbers.
Anyway, thanks to Scott Siegal great tuner.
k04sti is offline
Old 02-09-2010, 07:02 PM   #2
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
So, what are the numbers? sucky graph.
spools fast, enjoy
juanmedina is offline
Old 02-09-2010, 07:20 PM   #3
subaruNV
Member#: 154549
2006 DOM 3 Powered
WHITE/ EQ Tuned 350Whp
Looks like 374whp and 353tq
subaruNV is offline
Old 02-09-2010, 07:54 PM   #4
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
No.
It's 407 HP / 353 Torque / 20.xx boost @ ~6050 RPM (meth)
Then the other numbers are the pump numbers at ~6050 RPM (which are not the pump gas peaks). 374 HP / 324 Tq, but not being the peaks, those are just 'some numbers'.
Grats OP. I really like to see Dom 2.5 / ATP3071 charts. Seems to me to be a good balance of spool and top end for a DD / weekend warrior.
Concillian is offline
Old 02-09-2010, 08:13 PM   #5
k04sti
Member#: 171773
04 wrx sti
Sorry don't know how to resize it, but yea its 407whp and 450wtq. The non meth went to about 374whp and around 380wtq.
k04sti is offline
Old 02-09-2010, 08:27 PM   #6
moorebl
Member#: 59238
impressive numbers you should be happy there are some 3.0r out there not producing. good job
moorebl is offline
Old 02-09-2010, 08:35 PM   #7
k04sti
Member#: 171773
04 wrx sti
Thanks. I just wish it would've held more boost up top while on the dyno.
k04sti is offline
Old 02-09-2010, 08:38 PM   #8
Imprezha
Member#: 6818
2002 NSX
2010 Gen Cpe,2016 Outback
Some good numbers there. Can't wait to check it out. Gratz!!!
Imprezha is offline
Old 02-09-2010, 08:43 PM   #9
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Damn, this turbo spools just like a vf, maybe 150 rpm later, and makes 50-70 more whp. Very nice dude!
STi Mikey is offline
Old 02-09-2010, 09:27 PM   #10
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
switch to the 10cm
Phatron is offline
Old 02-09-2010, 10:05 PM   #11
k04sti
Member#: 171773
04 wrx sti
I'm thinking something even better for the future
k04sti is offline
Old 02-09-2010, 10:08 PM   #12
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Never mind....Dynomite dyno/
What a stock car make on this dyno?
CoolRex is offline
Old 02-09-2010, 10:28 PM   #13
k04sti
Member#: 171773
04 wrx sti
Numbers are numbers. Could care less. No idea what a stock makes on this dyno, but it is a little on the high side.
k04sti is offline
Old 02-09-2010, 10:29 PM   #14
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Numbers are number but thanks anyways. I'm trying to see how this turbo performs. I have a buddy interested in this turbo and he wants my input on it.
My original response was asking if it was a Land and Sea dyno then I saw the dyno name in the sheet so I edited the post. Sorry.
CoolRex is offline
Old 02-09-2010, 10:32 PM   #15
Trevor723
Member#: 57989
2013 Golf TDI
united gray
Is this IWG?
Trevor723 is offline
Old 02-09-2010, 10:32 PM   #16
juanmedina
Member#: 133146
Its a DomIII non ball bearing, 52lb IIRC. Are this numbers at the crank?
Old 02-09-2010, 10:48 PM   #17
k04sti
Member#: 171773
04 wrx sti
Oh sorry for the misunderstanding. I don't know, because this dyno reads high not sure what a stock would read on it. It depends what your friend wants for his car. I like the turbo and it spools pretty quick and holds power up top pretty well. Even on a low reading dyno I'm pretty sure I could get high 300's if I could hold boost up top on the dyno. I don't think we had enough air blowing through to have it hold boost up top. Also, a little creep might help up top too
Originally Posted by Trevor723 View Post
Is this IWG?
Yea IWG
Are you talking to coolrex? Confused lol
k04sti is offline
Old 02-09-2010, 11:07 PM   #18
juanmedina
Member#: 133146
the first part is for coolrex; the question is for u
Old 02-09-2010, 11:10 PM   #19
k04sti
Member#: 171773
04 wrx sti
No, it's just a high reading dyno....but not that high i hope..
k04sti is offline
Old 02-10-2010, 12:36 AM   #20
j255c
Member#: 89554
2006 EVO SE
Black E85 30PSI dd
jfyi the dom 2.5 is not a dom III non bb. The dom 2.5 is a smaller compressor wheel (i think 49lbs). I ran the Dom II, which is the same compressor rating as the Dom III. Its a journal bearing unit, I made 424whp 420wtq with 28psi tapering to 24 @ redline -meth and pretty aggressive timing.
-Jeff
j255c is offline
Old 02-10-2010, 01:05 AM   #21
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I thought the Dom 2.5 was essentially a 3071 center with mitsu 8cm turbine housing. 3071 is 47 lb/min, about halfway between a 20G and a Dom3.
Old 02-10-2010, 01:17 AM   #22
k04sti
Member#: 171773
04 wrx sti
Yea the dom 2.5 is a 47lb/min bb turbo. All I know is that it spools fast and feels great.
k04sti is offline
Old 02-10-2010, 02:27 AM   #23
Phatron
Member#: 36033
CEO PhatBottiTuning
thats a great setup. pretty much exactly what i was running with the green. be careful though, ur right at the breaking point.
only next steps are big money.....built block, bigger stock location turbo and/or headwork.....
Phatron is offline
Old 02-10-2010, 02:57 AM   #24
k04sti
Member#: 171773
04 wrx sti
Yea I'm thinking about cp drop in pistons and going to a dom 3 XTR or something
k04sti is offline
Old 02-10-2010, 03:13 AM   #25
Phatron
Member#: 36033
CEO PhatBottiTuning
Thats $4500-5000 for not much gain.......
i went from the OG Green to the HTA now to the DOM4XTR and the daily drivability is not that different....
I'd say if ur gonna do that to go 60 lb/min plus or just go rotated. You'll ultimately be happier with rotated as you'll spool quicker than a stock location 60 lb turbo and make more power.
i need to get a video camera so i can take some vids on the street.
Phatron is offline
Closed Thread
What have more power a 2000 2.5 rs non turbo, or a 2.0 turbo wrx 2002? AFAP_Nor_CA Newbies & FAQs 26 07-17-2010 11:49 PM
EQ Tuning Stage 1 Shortblock + Blouch DOM 3.0R + 91 Octane + Meth = 384whp! Equilibrium Tuning Proven Power Bragging 34 03-19-2009 08:52 PM
Cobb Stage 2.5 (VF34) or Stage 2.0+Meth Injection? hampster AccessPort 2 02-14-2007 04:26 PM
3 inch or 2.5 inch Exhuast for 2.5L dingobite Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-03-2006 07:07 AM
WTB:2005 2.5 Legacy non-turbo Intake, HELP? underground-mpyre Legacy Forum 8 11-26-2005 04:43 PM
