Old 02-09-2010, 06:54 PM   #1
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
Default Theoretical power output of a td04
I want to know if there is a way to calculate, extrapolate, educated guess etc the power output of a td04 on a 2.5 liter motor, while making full boost(say..18psi) at like say 1500 rpms. This is a theoretical question and if you just want to ask WHY go else where. Also, say after that, Id like to figure the same formula using a vf43. I will do a little research on compressor maps etc, just searching for a formula
Dubstar112 is offline   Reply With Quote
Old 02-09-2010, 07:15 PM   #2
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
You're asking us to make A LOT of assumptions for this theoretical exercise. Probably too many to give you any sort of consistent accurate approximation. :shrug:
Old 02-09-2010, 07:25 PM   #3
oguitar
Member#: 206720
2002 WRX Wagon
There are some good guides online that will teach you how to plot and read the compressor performance maps of specific turbos. Check those out.
oguitar is offline   Reply With Quote
Old 02-09-2010, 08:08 PM   #4
arghx7
Member#: 232940
you talking about the stock TD04-13T or a larger TD04?
arghx7 is offline   Reply With Quote
Old 02-09-2010, 08:29 PM   #5
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
Well, what do I need to search for? Too many variables? figure STP for starters! 13t
Im having a hard time keyword searching this kind of formula as I dont know what to call what im looking for.. any tips?
Can I extrapolate from rom raider logging what happens at 2900-3000 rpms at spool?
BTW i was not asking YOU to give me an approximation. Simply asking if it could be done.
Old 02-09-2010, 08:30 PM   #6
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Did you read the Turbo FAQ?
Old 02-09-2010, 08:33 PM   #7
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
The one in the newbie forum? Sure did
Old 02-09-2010, 08:35 PM   #8
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
Old 02-09-2010, 08:52 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
id say that 18psi is low for a td04...think more like 20-21psi
and stop wasting yer time with a td04 on a 2.5 unless you only use 1-2-3
Old 02-09-2010, 09:31 PM   #10
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
I do only use 1 2 3. most of the time 1 and 2.
456 gettin no love from me! ololo
Old 02-09-2010, 09:42 PM   #11
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Try to find someone with speed density Engine management and a TD04 on a 2.5L (this alone won't be easy). This will effectively already have what you want in two charts:
- 3D chart of VE @ RPM vs PSI
- 2D chart of VE correction @ intake temperature.
If you can combine those variables into an equation for VE, then you can apply already derived equations for VE into power, then you don't have to derive from scratch. You can just make an equation that approximately matches the empirical data already available.
Compressor maps are nice, but you need to combine that information with a turbine map and the various engine parameters (exhaust restriction, intake restriction, intercooler efficiency, etc...) to have anything more than a very basic idea of turbo capabilities.
The engine management VE tables of an ECU that uses speed density will have already done the combination of those variables for you (basically... and assuming it's tuned properly). This means your only task becomes describing what is essentially a 4D array in mathematical terms. translating a 4D array into a mathematical formula is not exactly easy, but it's a LOT easier than deriving such a relationship from the compressor map, turbine map, then making various assumptions about the engine characteristics.
Concillian is offline   Reply With Quote
Old 02-09-2010, 10:36 PM   #12
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
Ok, so, this particular issue will likely require me to start with the base setup tuned, or need some knowledge that isnt readily available. And could be a little bit too far out of my league.
Old 02-09-2010, 11:06 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
ok...since the td04 essentially acts as its own restrictor on a 2.5....
you could just tune it without any real boost control other than max boost---just let it go and do what it will and adjust fuel and timing to suite and see what ya get that way
i know someone who kinda did just that and it is quite entertaining
Old 02-10-2010, 07:12 AM   #14
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
I know you did I had a header and ewg on my td04 and it was quite a bit of fun during auto x. What Im aiming for is, better than insta spool. I was basically wondering with the known flow rate of a td04 and its powerout put diminishing above 4500 is there anything to be had below its current boost threshold?
Old 02-10-2010, 08:28 AM   #15
quazimoto
Member#: 70395
So you just want to play make believe?
quazimoto is offline   Reply With Quote
Old 02-10-2010, 08:38 AM   #16
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
only way you're gonna get that 18psi at 1500 is running anti-lag. normally in gear you will not hit that when you punch the gas pedal. your engine speeds will already have past 1500rpms. you need to load up the engine to produce boost.
unhook the wastegate line....... there are plenty if td04's to be had cheap!!
FuJi K is offline   Reply With Quote
Old 02-10-2010, 10:21 AM   #17
David L.
Member#: 130632
2002 Z28 35th Ann.
Pewter
I would say 22psi on a stock tdo4 is very possible and very fun. I actually went for a ride in a car (2.0 litre) setup tuned to this with a EWG setup to help with quicker boost and a little more tourque. And yes it is fun 1-2-3. For a 2.5 litre the boost will peak quicker but fall on its face quicker. I was quite impressed...
Fyi, he runs 13.7's trapping around 103mph on a stock clutch that slips if that heps give an idea...
David L. is offline   Reply With Quote
Old 02-10-2010, 03:26 PM   #18
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
There was a thread on another forum where an 08 WRX, stock turbo, and DW850cc injectors, tuned on E85, broke something like 250whp. Add in headers, full turbo back, EWG, intake.... WHo knows? 260whp? Just a theoretical game to play, but what else is there to do when snowed in today!?
scramjett is offline   Reply With Quote
Old 02-10-2010, 04:04 PM   #19
blackrex13
Member#: 194884
2009 dirty
JSW TDi
..... braden at XPT tuning got 400tq and 270hp on the 08 WRX with stock injectors and e85 + walbro FP.... i ran the map, believe me its badass, but only till about 4k rpm then its no different than gas due to the TD04 pissing out, but meh it holds power till redline which is alright.
scroll down and hes got the dyno plot showing the 18.5psi e85 chart
blackrex13 is offline   Reply With Quote
Old 02-10-2010, 04:08 PM   #20
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
Yes. The only reason I havent mentioned the idea of antilag is all of you nay sayers chime in with gtfh noob not for u blah blah blah your stupid, it ruins everything etc..
So yes, I want to know if antilag on a td04, vf will provide generous torque below your normal boost threshold.
Im not building a widebody car to look good. i want it to play the part aswell.
Im not trying to run any ideas by anyone for approval. Im just doing... Albiet slowly cause its winter and fences dont go up in winter
Thats all good in everything, but my last setup made 241whp and 323 wtq.. Im not switching to e85 for 9 hp plus or minus the brand of dyno And from my experience a header will be negligable in most smaller turbo applications.. Im aiming for a significant expansion of the power band on the low end.. This time around I will have TGV deletes and a ported intake manifold to aid in squeezing everything out.
Old 02-10-2010, 04:23 PM   #21
ibelieveindarwin
Member#: 188542
208 Impreza WRX
I have an 08 wrx with the td-04. It us tuned to hit max boost at 18.5 psi. I am making 250whp and 325 ft/lbs tq.
Other mods include,
tomei header and uppipe,
aem cai,
megan racing dp,
perrin exhaust
and walhbro 255 fuel pump
ibelieveindarwin is offline   Reply With Quote
theoretical power question!! warsong16 Proven Power Bragging 13 09-04-2009 04:55 PM
Power output of stock stereo?Direct speaker replacement options? MaestroB Car Audio, Video & Security 8 10-01-2006 02:18 PM
Subaru WRC Car "actual" power output? Jewbaru Motorsports 8 03-14-2002 05:10 AM
WRX power output curve Imprezard WRX Forum Archive 3 01-25-2001 02:15 PM
What's the power output of the new H6? MrSube2pt5 General Forum Archive 4 11-25-2000 11:06 PM
