Old 02-09-2010, 08:47 PM   #1
wrxnevox
Member#: 225281
08 Evo X,IS 300
Rally Red,Black
Default need advise or help installing DP
i did try and install godspeed DP catless but one of the stud in the turbo don't line up what can i do to make it fit
wrxnevox is offline   Reply With Quote
Old 02-09-2010, 08:50 PM   #2
surfrjag
Member#: 225671
2002 wrx impreza
the black pearl
you need a 3'' flange on your im guessing stock exhaust.
surfrjag is offline   Reply With Quote
Old 02-09-2010, 09:12 PM   #3
wrxnevox
Member#: 225281
08 Evo X,IS 300
Rally Red,Black
nope in the turbo and i got cat back already installed
Old 02-09-2010, 09:19 PM   #4
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
Capitalization and punctuation helps a lot.
Drill the hole in the down pipe out slightly bigger. Find a drill bit that fits in the hole, use the next biggest size to drill it out, try fitting it again, if necessary rinse and repeat.
FourOnTheFloor65 is offline   Reply With Quote
Old 02-09-2010, 09:19 PM   #5
Godspeed55
Member#: 186553
Ohh dang. I would rather modify the downpipe then the turbo though...
Godspeed55 is offline   Reply With Quote
Old 02-09-2010, 10:49 PM   #6
surfrjag
Member#: 225671
2002 wrx impreza
the black pearl
pm me ill take a look at it if you like. im local...
Old 02-10-2010, 09:28 AM   #7
subaragnarok
Member#: 211986
You said it was a stud coming from the turbo, no? So drill out the hole on the DP...
subaragnarok is offline   Reply With Quote
Old 02-10-2010, 01:22 PM   #8
lotarg
Member#: 90940
Are you trying to install the entire turboback to the turbo? Meaning the catback and downpipe are connected right now? If so, try taking the catback off and just installing the downpipe first, then reattaching the catback.
lotarg is offline   Reply With Quote
Old 02-10-2010, 05:32 PM   #9
wrxnevox
Member#: 225281
08 Evo X,IS 300
Rally Red,Black
thats what i going to do make the hole bigger of the DP
Old 02-10-2010, 07:14 PM   #10
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
You do understand that we are talking about the holes where the down pipe slides over the studs on the back of the turbo? If they are slightly bigger it doesn't make any difference. It really is OK to do this. Don't go overboard but making the hole 1/32'' or 1/16'' bigger isn't going to hurt anything.
I helped install an early model/prototype of Moore Performance's TBE, with the company owner. We had to do this on his DP because it was mocked up on a car without an anti-lift kit. The pipe was hitting the car's ALK and wouldn't slide on the studs. We drilled the mount holes out where the studs went through the flange and it slid right on. They then changed the production version's hole size to correct this problem.
The moral of the story is, companies do this sort of thing there is no problem with you doing it.
Old 02-10-2010, 09:59 PM   #11
wrxnevox
Member#: 225281
08 Evo X,IS 300
Rally Red,Black
i'm going to do that
Old 02-10-2010, 10:02 PM   #12
bjwk89
Member#: 175615
2005 STi
Black Stg. 2
godspeed sucks, the drill will probably work, but a lot of their parts have problems. They are one of the lower quality ebay based brands. I am sure some people like their parts, but it is something I'd avoid if possible.
bjwk89 is offline   Reply With Quote
Old 02-11-2010, 09:16 PM   #13
wrxnevox
Member#: 225281
08 Evo X,IS 300
Rally Red,Black
i think so
Help install DP on Monday?? C-grunt South West Impreza Club Forum -- SWIC 35 09-18-2007 11:44 AM
Helix VS Pde??? Need advise or comments!!!! BBBsti LTD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-23-2006 07:16 AM
Help! Installed DP, AP Stage 2 and no boost, stalls! idkew Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 11-20-2005 04:48 PM
need help installing dp on sti in bowie md mpower22 Mid Atlantic Impreza Club -- MAIC 3 10-27-2004 09:04 PM
I damaged my new shoes 2day and need advise or help iclubber Mid Atlantic Impreza Club -- MAIC 6 01-04-2002 09:23 PM
